Question about Briggs & Stratton Garden
I have a Yardman 21 inch self propelled mulching mower Model 12A-559K401, with B&S Engine - Model 120602, Type 0131E1, Code 000509FA. Gas is fresh, air filter is clean, spark plug gap at .020". Engine will start (although sometimes with more pulls on the starter cord than it used to take), but will only run for 1-2 seconds before it just dies. It will restart, and then immediately die again after running for a second or two.
jj505
  • 195 Answers
SOURCE: Yard-Man Mower model 418D401 doesn't start
Need to remove carberator bowl nut and bowl and activate float to smell new gas coming thru,stuck mostlikey due to storage.
Please rate. Thanks. jj505
Posted on Mar 30, 2009
  • 109 Answers
SOURCE: poulan 21
Try putting a SMALL amount of gas in the carb and see if it will start, if it does, it is a fuel problem, if it does not it is probably an electrical one
Posted on Apr 26, 2009
  • 376 Answers
SOURCE: Hello I have a Craftsman eager 1 Lawn Mower model
The breather hose has nothing to do with it not starting. It starts when you prime the carb and dies when that gas is used up. Being a Tecumseh. it's most likely the bowl nut/jet stopped up. Unscrew the bowl nut and clean it. Look cery carefully at the top of the threads. There is probably a very small hole there also and it will not run if it is not open.
Posted on Jun 20, 2009
Testimonial: "Carb kit was on the money installed it on8/20/09 Started and Runs fine"
SOURCE: Self-Propelled Model Starts, then dies after about 15 seconds
I posted same problem as this couple days ago. Took mower to shop. The governor spring (located just under the air filter) had come off. So glad it was something so minor!
Posted on Jul 25, 2009
  • 582 Answers
SOURCE: my toro 6.5 self propelled mulching mower with
IF THERE IS A PRIMER BULB ON THE CARB CHECK AND SEE IF IT IS HOLDING GAS IF NOT THE CHECK VALVE UNDER THE PRIMER IS BAD AND SUCKING AIR
Posted on Aug 12, 2009
Where is fuel filter on yardman lawn mower
they only have a screen inside the tank and don't use a regular filter
May 19, 2012 | Yard Man YardMan 11A41K3001 21Inch 173cc...
Yard works mower wont start
check the fuel filter if not you need to clean your carburator
May 02, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
What type of oil do you use for 6.5 hp yardman lawn mower mtd 160cc 21 inch self propelled
The manual will call for 30 weight, but 10w30 works just fine. Be careful to not overfill the crankcase. Your machine will take 16 - 18 oz's when the crankcase is empty.
Tim
Oct 06, 2011 | Mtd Yard - Man 160cc, 21" Self - Propelled...
What are the steps to start mower.
I could not locate your exact model for a manual. This machine's manual is very similar. Please read the operating and "How To Start" instructions inside the manual. They can tell you better than I.
http://lawnandgarden.manualsonline.com/manuals/mfg/yardman/120874r.html?idRes=11171312
Sep 11, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
I need to change oil in my yard man lawn mower. Where is the drain plug? I need to change the oil
Hi, you drain it out of the dipstick filler hole by tipping the mower to that side. Remove the sparkplug cap first as a safety precaution. Hope this helps, regards Phil.
May 17, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Hi I need a parts and repair manual for the yardman 12a-978q452 mower , I can not finded on line.
I know this was more than a year ago, but I just got one second hand and had to find the same thing. It's made by MTD in Canada. Here's the site to find it. They don't have the manual for the exact same model number, but I've gone through it enough to know it'll work. http://www.mtdproducts.com/webapp/wcs/stores/servlet/OperatorManualView?storeId=10500&catalogId=20500&langId=-1
May 06, 2011 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
I bought a Yardman 21" Series 560 self-propelled mower used and the belt was missing. What belt does it take? The manual says 754-04080, but I'm looking for a locally available V-belt. Thank you.
Are you sure the belt part number is not 754-04088?
That is a 33 inch belt. I do not know if you need the 1/2 inch or 3/8 inch wide belt. Pulley size would be the key for belt width. I think it is 1/2. Any local source automotive parts or Lawn Mower supply will have this belt in stock. 1/2 x 33 or 2L 33
If by chance I got the belt part number wrong, (I don't think so) just respond here and we can keep searching for your belt.
Thanks for using Fixya.
Kelly
Jun 17, 2010 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Troy Bilt 190cc Z-Start Model 12A-446A011 21"Inch Deck
You need to remove a pulley to put the new belt on.
Jim
Jun 05, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Garden Logo
42 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
