Question about Hitachi 40" Class LCD 1080p 60Hz HDTV, L40C205
My Hitachi Model L40C0205 has sound but no picture screen is black. I purchased this television on 9/10/2012 just over a year ago.
  • 1153 Answers
SOURCE: Hitachi Model 42EDT41
do you have sound?
Posted on Mar 10, 2008
SOURCE: red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Posted on Jun 18, 2009
SOURCE: i have a hitachi tv model 42edt41 year 2004,2005
I have the same tv and had the same problem. I found a posting that stated to re-solder a connection on the cable for the "y" boards. I used this and my tv is perfect now. The part that needs to be re-soldered is the ribbon cables at the bottom of the tv that go from the boards straight to the screen. On the inside of this ribbon cables there are 4 small components that have "100" on them. On each end of each of these pieces, re-solder them. Since I had my tv completely apart I re-soldered all of them across the bottom. No problems now!
Posted on Oct 16, 2009
  • 1039 Answers
SOURCE: Hitachi plasma screen black. blue light on... no picture though.
Replace digital board. Common for this set.
Posted on Nov 09, 2009
  • 110 Answers
SOURCE: Hitachi , L32A01A , LCD, sound but no picture Need
hi, try these steps...
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
good luck!
Posted on Feb 10, 2011
Hitachi tv no picture or sound.
my hitachi projection tv 53uwx10b screen is black with no sound or picture when the power button is on
Dec 29, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Sound, no picture, no display, just a black screen
its a Hitachi DLP
it has a lamp that illuminates the screen
it has most likely failed in your owners manuel it should be more specific and you can order a lamp and replace it your self
and you can order a lamp off of line or call hitachi
Oct 26, 2009 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi model 57SWX20B which has a dark screen
loss of brightness could need the mirror and lens cleaned and also the screen.if the tv is over 8 years old then the crts are getting weak.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Lg lcd tv picture goes in and out with "boxes" on the screen
This sounds like the power supply that feeds your back-light is going out. This repair should be done by a qualified technician
Mar 13, 2009 | LG RZ32LZ50 32 in. LCD Television
Our 50 in. Hitachi floor model TV just stopped working. No SOUND, no picture, just a humming sound. No one in our area deals with Hitachi products. The store where it was purchased twelve years ago went...
I will need the model number of your hitachi in order to help you. Please respond to this same post with the model number and I should be able to assist you with the problem.
Jul 10, 2008 | Hitachi Televison & Video
Sound, but no picture. Standby light blinking 5 times
A few weeks ago my set started flashing to a black screen. Now a couple of weeks later, i have no picture, but the set turns on and i have sound. The standby light is flashing. I purchased the set in 2000 so it is seven years old. This is the first problem. Could it be all three of the bulbs? Could it be all three of the bulbs? no as you say that sound is ok that means your power supply &high voltage section is ok. please check chroma ic luminance section or system control section stand by ckt ihanks
Sep 11, 2007 | Sony KP-53HS10 TV
Will not turn on/ black screen
My Hitachi Tv 43fwx20b turn on but not have sound and picture
Jul 03, 2007 | Hitachi 43FWX20B 43" Rear Projection...
Hitachi 40" Class LCD 1080p 60Hz HDTV, L40C205 Logo
82 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
