Question about Focal Utopia Audiom TLR Car Tweeter
How to fix acoil from berilium utopia tweeter
There is a hole on the surface of the coil
    Master:
  • 483 Answers
Try the Focal website
Posted on Oct 21, 2013
There is a damage on the surface of the inverted coil berilium tweeter focal utopia .Where can I find new berilium surface to replace it
try the Focal website, surely a company that makes such lofty claims about their product will give you excellent customer service
Oct 20, 2013 | Focal Utopia Audiom TLR Car Tweeter
Tweeter not working
hi,
Remove the tweeter and check the same with one AAA cell. Connect the two leads between the leads of the tweeter. if ther is no crakking noice from the tweeter the its coil is burned. you have to replace the tweeter.
ok
Feb 07, 2011 | Technics SB-T200 Main / Stereo Speaker
I bought a Behringer Eurolive B1220 Pro speaker with my PA system brand new and it sounded great at first. Now it sounds really muddy (the other 2 speakers I bought work fine) almost as if the horn has...
Bad news...you've blown the tweeters. Overdriving the mixer/amp creates distortion on the amplifier which heats up the speaker voice coils and eventually causes damage. Because of their small diameter voice coil windings the tweeters fail first (opens up like a fuse element does) followed by the woofer making a scraping sound (deformed voice coil) or not working as well. Warranty service because you blew out the tweeters? Don't get your hopes up.
1. PLEASE use enough power for the venue that you have. A high powered system will run all night at 10:00 (physical volume knob setting) than an underpowered system set for 2:00.
2. Get speakers off the ground and closer to your audience's ears. Audio from speakers on the floor must battle surfaces that actually absorb some of the sound....carpet, drapes, etc. And besides, legs can't hear that well.
Nov 05, 2010 | Behringer B1520 Pro Eurolive 15" 2-Way...
Colman centrial air conditioner. A coil freezes up solid restricting all air flow. model # on the ID Plate on the A coil is MCB36CQD. Thanks for your help
This is the time of year for icing up acoils. Hot days and cool nights have something to do with it, however you might need to clean the acoil. Use a product called NON RINSE FOAMING COOLING COIL CLEANER from a hardware store. You spray it on and its foam pulls **** out of the acoil from deep within and then it goes down the drainpan and serves to open it up as well. Good stuff.
May 02, 2010 | Heating & Cooling
Can't find specs/maker of klh 900b tweeter
KLH 900B tweeter specifications: 6 ohm, 40 watts. By the way, KLH's QC for speakers could be improved. One of my 900B tweeters quit because the spacing for the voice coil was way off reasonable tolerance and the body of the speaker coil base pillar (ie: magnitized part) was off-center - and cauesd the coil to ware and short. I contacted KLH but they did not respond.
Sep 19, 2009 | KLH 900B Main / Stereo Speaker
H/p is freezing up. and acoil is freezing up.w
Two things cause freezing of the coil, lack of charge or lack of airflow, filters, coil and blower assembly all need to be clean, the thermostat will not cause feezing as it is strictly an on off control for convienience
Jul 19, 2009 | Whirlwind FH-778 Air Conditioner
Speaker was dropped - Tweeter Magnet came off - looks to have been glued on by manufacturer. What type of glue should I use? JBL EON 15 Thanks
Clean the mating surfaces very well, mark on the side of the magnet (arrow or dot) which surface of the magnet was glued (shouldn't make a bit of difference, I'm just a little anal) and then use any brand of quick setting 'super glue.' This glue will not only hold well but will also introduce the thinnest film between the magnet and 'keeper.' Too much space between mating surfaces can weaken the field and reduce the efficiency causing an imbalance in volume relative to the other tweeter. If anything else is loose, the tweeter is junk because any shift of the voice coil will cause the speaker to distort or rattle.
If you need to replace any speaker ever, replace both channels or have possibly lousy matching between channels.
Apr 24, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
Car audio
mike, this is a beautiful and perfect setup! if you dont have a headunit yet i know the #1 perfect one for you CLARION DRZ-9255 .http://www.clarion.com/us/en/products/2008/audio/source_units/cd/DRZ9255/us-en-product-pf_1172385113235.html i have owned every single piece of equipment that you have! my set up was the same exact way except i used focal utopia 33wx for my subs. but JL AUDIO are the masters at making the best subs for the money by far! i have owned every line of subs JL AUDIO has ever mad,my overall favorite. sean314 623 7054 cell
Sep 11, 2008 | Focal Utopia Audiom 6W Car Mid-Range
Tweeters????
Hi oddone
You may have a problem with either blown tweeters, or a faulty cross over, or both. If you have a multimeter, you can remove the tweeter, and check it DC resistance. They normally have their impedance marked on the back of the magnet. If not, you can assume they should measure 8 ohms. If they measure open circuit (high resistance), then they have failed.
A good speaker repair guy can often fix an open circuit tweeter as they often break where the very fine wires attach from the voice coil to the terminal. you can take a turn of the voice coil and reterminate to solve this problem. If the voice coils are burnt, they will need to be replaced.
If the tweeter meters ok, then you may have a problem with the crossover capacitors going dry. Generally they are 2.2uf to 6.8uf in value, the smallest cap in the crossover. If the plastic coating on them is split, or they look a different colour to the rest of the caps, replace them, if they sound "hollow" replace em, if you are not sure, replace em. other than that there is not alot more to look for with a speaker box tweeter Good luck and happy listening.
If you have any dramas, get back to me here and we can talk more about it.
regards
Graeme
Mar 16, 2008 | Audio Players & Recorders
KLH tweeters stopped working
hi, have u first disconnected the tweeters and then checked, as if its on a cross over, the tweeter is in series with a capacitor,if u have a ohms meter or a continuety tester check the tweeter coil if its open,secondly you can have the coil replaced, check if u can get one before buying a new,let me know
Jan 11, 2008 | KLH HT-9930 System
Focal Utopia Audiom TLR Car Tweeter Logo
74 people viewed this question
Top Focal Car Audio & Video Experts
xxxxxx xxx
Are you a Focal Car Audio and Video Expert? Answer questions, earn points and help others
