Question about Canon Cameras
My flash gun for my camera powers up but then stops and just beeps. Will not work. Help!!
  • 281 Answers
Did you check your batteries?
Posted on Nov 27, 2013
How do I reset flash?
Google your flash gun make and model. Look for a review. It may explain how to.
Sep 22, 2015 | Cameras
I have a Sunpak pf30x flash (ETTL II for Canon) and a 550d Canon but the flash will not work. the flash works on my Canon Eos 300 film. Help
Many flashguns deigned for film cameras - even really expensive ones - will not work with DSLRs.
I have a perfectly good pentax gun that cost me almost £300. It is fanstastic on my TOTR Pentax SLR but will only blat at maximum power on my Pentax DSLR. I had to spend another almost £300 to buy the new gun that will work with all the bells and whistles on my DSLR.
It looks as though Canon work theirs the same way.
May 22, 2011 | Sunpak PF30X for Canon Flash
Flash Gun works intermitently
well Jack its all down to the capasitor inside the flash gun its most likley to be fully discharged by now and would need to be "reformed" or fully recharged, what you can try is turning the flash gun on and letting it build up to full power but dont flash it off, just let it stand on full power for an hour or so then fire it off and then do this again for a fuw times,if the capistor recharges fully it should work after that but NEVER look close into the flash gun when you fire it off it will BURN your eyes out! the flash is as hot as the sun when it fires off 6,000* C, and,thats hot! a fuw years ago there was a press guy who was taking photos inside the space shuttle with a flash gun that he fired a fuw times close to one of the windows,,,
and it ---CRACKED IT!!!!! NASA was not pleased!!!!
but they did changed all the windows in the space shuttle to some thing stronger
Jan 12, 2010 | Cameras
Non-syncing Olympus FL-36
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see the flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu. My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
May 12, 2008 | Olympus FL-36 TTL Flash
Olympus Camedia D-565 Problem
you left it too long for a free replacement
But it is worth contacting Olympus as it is know this one was a lemon.
Jan 15, 2008 | Olympus Camedia C-350 Digital Camera
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
OPTIO S4: FAULTY FLASH ... Help please!
Check the settings and be sure you have sufficient power. If you want to test the camera for defaults, remove the batter from the camera for a day or so, then replace it. This will set its defaults. If the flash continues to not work, then I suggest calling Pentax and having it serviced.
Sep 08, 2005 | Pentax Optio S4 Digital Camera
Cameras Logo
48 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
