Question about Bosch Classixx KGV28323 Bottom Freezer Refrigerator
Ice is accumulated into freezer, how to manage it, not finding option of defrosting, please suggest.
Clean the grill at the rear, always leave your thermostat at normal range and in the freezer try not to over stuff it will only block the cold air from circulating and therefor causing it to freeze backwards.
Posted on Oct 20, 2013
I have a kitchen aid two sided refrigerator model #KSRB27FHSS04.The freezer part always iecing up, change the thermostat about 3 weeks ago. The fridge part still is not cooling like it should.
Yes I see the panel is covered in frost indicating a failed defrost heater and defrost thermostat. If you changed the timer then you have two more components that need to be replaced=> The 2188175 Defrost Heater Assembly and the=> 2196155 or W10225581 Defrost Thermostat Here is a KSRB27FHSS04 pats manual for your model and the parts are located behind the panel in your photo. Parts are listed on page 17 of the parts manual. You will need to defrost freezer before you will be able to see or replace these parts. Unplug and remove that rear panel and use a hair dryer to melt the ice blocking airflow on the evaporator. Please send another photo of the ice once you get rear cover off in back of the freezer
Appliance 911 Sea Breeze
Oct 05, 2015 | Refrigerators
Ice accumulates on the bottom of the frezzer
if frost free freezer then maybe drain tube plugged up with ice.defrost freezer and restart (unplug till ice melts)or drain hose is dirt plugged
Nov 23, 2011 | Samsung RS2630WW Side by Side Refrigerator
I have a Kenmore bottom freezer model 596.75934401. The refrigerator top has stopped cooling while the bottom freezer is working but showing some accumulation of icing. I have unplugged the regrigerator,...
There are a couple possibilities. You need to make sure the evaporator fan in the freezer is working, it circulates the cool air to the top. More likely your coil in the freezer is iced up due to defrost part failure, either the timer or the heater assembly. The back panel is going to have to come off. If you defrost the coil completely, the unit will work again until it ices up again. You have to have the defrost system diagnosed and the defective part replaced
Jun 25, 2011 | Kenmore Refrigerators
Water pools and freezes at bottom of the freezer. When tray is full water leaks out of freezer onto kitchen floor.
I am uncertain as to what you mean by "when tray is full"? However, you probably have a clogged drain in the freezer compartment. During the defrost cycle, which usually occurs every eight hours, defrost components (defrost thermostat & heater(s) ) melt the ice that has accumulated on the evaporator coil in the freezer compartment. The water from the melted ice drains through a hole in the freezer compartment (behind the freezer's rear panel) and accumulates in a drain pan below the refrigerator. This water should evaporate over time, whereby you should not have to regularly empty the drain pan. If the drain hole is clogged (usually from algae or other debris, etc.), the water finds another path to flow (which is inside the bottom of your freezer compartment). This water will usually freeze. Water will then flow toward the front of your freezer compartment and out of the door on to the floor when you open the door.
Contact an appliance service company to unclog your freezer drain. Also have them check your defrost components (thermostat & heater(s)).
Feb 15, 2010 | Frigidaire Refrigerators
Leeking water inside fridge from top
Defrost drain is clogged. This accessable thru the back wall of the freezer. Also depending on your model some also have removable Bottom floors of freezer that also get ice accumulation. When the defrost drain gets clogged water from the defrost cycle has no where to go so it stays and accumulates ice till eventually it leaks into the fresh food section. Clear the drain completly and you will have no more problems.
Feb 02, 2010 | Freezers
Ice accumulating in bottom of freezer in side by side refridg with water and ice despensers
check that drain at bottom of freezer is not plugged up, check that fan inside freezer is running.
check defrost heating element/defrost timer.
most likely it is a defrost timer.
Oct 11, 2009 | Refrigerators
Fridge ice accumulation inside and water dripping outside
Hi, Are you getting ice build up in the freezer side as well? There is a air shuttle between the fresh food side and the freezer side. thwater might be getting in the freshfood side from there. Look at the bottom rear panel in the freezer for ice build up. Ig=f there is ice, you will need to get to the drain from inside the freezer and check for blockage.
Please let me know if I can help you further.
Vic
May 10, 2009 | Refrigerators
Our Whirlpool SVF15NRHW01 does not defrost it just ices up
Your refrigerator has a defrost timer and this could be the problem. It appears to be inside the refrigerator. Locate and try to turn the timer slowly clockwise until it clicks and compressor stops. The refrigerator should remain off for 20 to 30 minutes and the freezer heating element should come on. The sound of crackling in freezer indicates ice cracking and beginning to melt. Let me know what happens, Thanks, Sea breeze.
Mar 25, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
I am accumulating ice inside my freezer
It needs to be defrosted. If ice builds up quickly again then start shopping for another freezer as the repair is not worth it. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 21, 2008 | Freezers
Bosch Classixx KGV28323 Bottom Freezer Refrigerator Logo
43 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
