Question about McCulloch Garden
Mcculloch eager beaver chain saw
Getting gas, has good spark, fresh gas but won't start
    Sergeant:
  • 342 Answers
Hi Mike firstly check the air filter is clear and if so try putting some fresh gas where the spark plug goes into the block. If it fires its the gaskets on the carb. If it doesn't it's the gaskets on the block and it wont fire due to the compression being at fault.
Posted on Oct 20, 2013
  • 42 Answers
SOURCE: I have a McCulloch 10 10 Automatic Chain Saw. What is the oil to
40:1 of two stroke oil roughly 2..5% 40 parts fuel to 1 part oil mixed Good Luck the Yeti
Posted on May 17, 2009
  • 4088 Answers
SOURCE: need to replace gas line inside mcculloch chain
You need to disassemble the case to get to the fuel tank. Pull out the plug fitting and replace the internals with new factory grade parts.
Posted on Jul 04, 2009
davesoucy
  • 148 Answers
SOURCE: need an owner manual for mcculloch eager ****** 300s-16
You would pay the manual about the price of new saw. These are made in china and usually motor or the switch blows. Check that the voltage pass thru the switch and if so and it dont work, throw it away.
Posted on Aug 28, 2009
Testimonial: "not what I was asking about. I wanted a user manual for mcculloch eager ****** 300s-16 electric chain saw. You people can't read."
dontbother10
  • 2220 Answers
SOURCE: Gas, Oil Mix ratio for McCulloch Eager ******
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
Posted on Sep 28, 2009
dontbother10
  • 2220 Answers
SOURCE: I have Mcculloch Mac 10 10 chain saw year unknown
Put a small amount of fuel mix in the carburator. If it sputters investagate fuel system.
Lou
Posted on Oct 08, 2009
I have a 2004 Suzuki LS650 that won't start. Battery says it's charged . Has new spark plug. Gas is good. When I go to start it it does not start, and then the battery is low again.
You say the gas is good? do you mean fresh in the tank? Try draining the card floatbowl using the 10 mm headed bolt on the very bottom of carb. If you smell a foul odor there is varnish buildup in the carb which will require a complete fuel system/ carb cleaning to fix.
Oct 12, 2014 | 2004 Suzuki LS 650 Savage
The motor won't start
Older Homelite's love fresh fuel. Mix up a fresh batch of gas with the recommended oil ratio. Dump out the old gas into an approved container. Remove the spark plug for inspection and make sure that you are getting a good spark. If you are getting a good spark replace the plug and pour some fresh gas mixture in to the tank and follow the manufacturer's starting instructions. Generally they have a primer bulb press that in 5-6 times until it gets firm. Engage the choke and pull on the rope until it attempts to start. Turn the choke off and it should start right up.
If you did not have a spark on inspection replace the plug and repeat the process.
Nov 04, 2013 | Homelite Garden
17 hp briggs stratton ohc
Clean or change air filter. Clean, gap or change spark plug. Empty gas tank add fresh gas with Stabil. When spark plug is removed pull rope several times to blow out cylinder. Spray starter fluid in spark plug hole before replacing spark plug. Clean outside of carb so choke works freely. Spray starter fluid into carb breather hole with air filter removed and try to start. if running replace air filter and cover. If no start disassemble carb and clean. If no start replace carb.
Jun 19, 2013 | Garden
I can not get my craftsman leaf blower to start. I put a new spark plug and fresh gas. Won't start.
Not to sure without seeing or hearing it being pulled over. Compression? Very likely needs some carb work/kit.
Apr 04, 2013 | Garden
2003 suburban has been siting for 3 years and now won't start. I can hear fuel pump working when key is ON. Battery is charged. What could it be? It cranks over like no fuel or spark getting to it
If it's been sitting for 3 years I would do as follows
1. Drain tank of all gas, give it some fresh gas.
2. Change the Spark Plugs
Attempt to start it. (Keep in mind it may take a few times to get all that old gas out of the lines)
Sitting it the worst thing for a rig. I advise never let it go without starting it ATLEAST once a month
If that doesn't work make sure it is getting fuel to the motor.
If so it could be your Distributor or Coil. Good luck
Mar 24, 2013 | 2003 Chevrolet Suburban
Suzuki 650 savage won't start
dump all the old gas out, put in fresh stuff, sometimes you gotta change the spark plugs as well.
cheers bucky
Feb 20, 2013 | Suzuki Motorcycles
Won't start
yes your moving in the right direction if over head valve remove the valve cover and check the rocker arms and for bent push rods if a flat head remove the head and check the valves
Aug 19, 2012 | Briggs & Stratton Garden
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Tecumseh TVT691 not getting spark in one cylinder
Did you check for spark of assume that since the spark plug was not dirty that it is not firing. I am leaning toward water in the gas since you have to keep the choke on and it is blowing white smoke. You may want to drain the fuel tank and carburator and put in fresh gas. Good luck!
Dec 30, 2011 | Garden
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
Garden Logo
95 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
