Question about Waring RB75 Specialty Blender Stainless Steel 3 Speed Blender
HOW TO REMOVE THE BLADE ASSEMBLY FROM MONTEL HEALTHMASTER PITCHER
How to replace the blade assembly on my Vitamix commercial 4000 (stainless steel pitcher) I have the blade assembly but it's more complicated to replace than I thought. HELP.
there is a wrench (by Vitamix) for under $10. you can get it from amazon. it makes the job of removing a blade assembly much easier.
Jul 01, 2016 | Vitamix Blenders
Motor leaking dark liquid
Hi, my wife and I purchased the Health master blender about 6yrs ago. I recently noticed that the liquid was leaking from the bottom of the container. The blade is totally loose. How can I tighten it if at al?
Apr 14, 2014 | Montel Williams Living Well Healthmaster...
MY MONTEL WILLIAMS BLENDER JUST QUIT WORKING IN
If the device is under warranty, contact the manufacturer for repair or replacement. Otherwise, get a new one. Everything breaks eventually, some things much earlier than others.
Jul 01, 2013 | Montel Williams Living Well Healthmaster...
How do you reset
The clutch is loose on my Health Master. I can't use it. I need some help please.
Apr 30, 2013 | Montel Williams Living Well Healthmaster...
How do I fix or replace my kitchenaid blender blade KSB560BF (Polycarb Jar)? It's leaked thru the blade assembly.
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Jun 15, 2011 | KitchenAid KSB560 5 Speed Blender
Healthmaster montel williams
You did not state the nature of your problem however the website for this product can be found here:
http://www.myhealthmaster.com/
Parts & Accessories: https://www.unitycart.com/healthmaster2/cart/parts.asp
Instructional Videos: http://www.myhealthmaster.com/how_to/
FAQs: http://www.myhealthmaster.com/faqs/
Trust this helps resolve your issue.
Feb 05, 2011 | Blenders
I need a replacement pitcher for my Bobby Flay blender but can't find one...
I actually have the pitcher, it comes w/the chigger and the blade that connects to the bottom of it.
this part is brand new, let me know if you still need one.
Jun 16, 2009 | Blenders
Waring RB75 Specialty Blender Stainless Steel 3 Speed Blender Logo
237 people viewed this question
Top Waring Blenders Experts
AZBen
AZBen
eyecam
Are you a Waring Blender Expert? Answer questions, earn points and help others
