Question about Exercise & Fitness
I'm replacing the deck on a Horizon DT850. The side rails don't loosen when struck with a mallet. Is the rail fastened to the frame? Or should I just hit it harder?
    Top Expert:
  • 12,223 Answers
See the video attached.
Posted on Oct 21, 2013
3 Suggested Answers
  • 10865 Answers
SOURCE: I purchased a pro form 585 treadmill around 1999.
Hello. These proform treadmills are prone to the problem you have. Go to http://www.proform.com/ and contact customer support. They should send you free replacement parts as these white metal parts are prone to breaking. Regards, Joe
ps - kindly rate my anser as helpful. thanks.
Posted on Feb 16, 2010
ercupa190
  • 12223 Answers
SOURCE: on my horizon ex 79 elliptical the incline bracket and the guide rail do not line up
must be not align, to due some bend. Try to adjust it with some little hammer and fix it.
God bless you
Posted on May 16, 2012
How can I remove the deck to replace the belt?
Hi There, yep, you're right, most treadmills allow the deck to be unscrewed from the topside, but some are installed from the bottomside. Screws under the rails. Here's a trick ;o) Usually.....
a servicer can remove the front roller on the side that doesn't have the drive belt on it, which comes off anyway, but should give you more room to see things. Then, try to gently lift one-side of the deck enough to slip the old belt off and the new belt on if there are no frame rails in the way. It's much easier with two people. Rollers may need to come off to get that deck off. What make of treadmill?
Feb 07, 2016 | Exercise & Fitness
Kincaid Carriage House Sleigh Bed side rail split
This can happen if the bed is not securely fastened together. The headboard/footboard shouldn't be able to shake without moving whole bed.if they do the joints will fatigue and fail from everyday wear and tear weight probably not a factor as the stressor would be vibration of loose joints not weight stress. Is this common? Depends on design. Bed frames that screw tight it is common.frames that snap together not so much as there is nothing to tighten. design flaw seems more possible in that circumstance.
Dec 01, 2013 | Kincaid Carriage House Sleigh Bed
Roller working side
China famous power cord manufacturer providing free power cord samples
Oct 20, 2013 | Horizon DT850 Motor Control Board
Horizon DT850 treadmill belt won't move
Step 1:
please see the video and lube too the rollers bearing. Happy new year and God bless you
Step 2:
test the input voltage motor, if there are voltage in the motor, the motor NEED repair, see the diagram attached, and see my personal TIPS for motor help.
Step 3:
test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the diagram attached.
Dec 31, 2012 | Horizon DT850 Motor Control Board
Replace shower door
Hi
You did not mention any additional information about your problem except replacing shower door.However use basic hand tools to complete the job.
Try this following general steps :-
1. Remove the doors by lifting up on one door at a time and then pulling each out. The top of the door has rollers attached to it, and the rollers rest on the inside of the top rail of the frame. Set the doors aside.
2. With your drill, remove the two screws on each end of the top rail, located on the inside of the shower frame. Then lift off the top rail of the shower frame.
3. Use your box knife to cut the caulk on the side and bottom rails of the shower frame. Shower frames are caulked on the outside where they meet with the walls and floor of the shower.
4. Use your drill to remove the screws from the side rails. There will be two screws on each rail, securing it to the shower stall. Then, take the rails out. Remove the screws from the bottom rail and take it out.
5. Use your tape measure to measure the old side rails, top rail and bottom rail. With a pencil, mark the lengths on each new rail. Use your hacksaw to cut each rail. Hold a side rail in the exact location where the old rail was located. With your pencil, mark the screw holes on the shower wall. The new shower frame screw holes may not line up with the old shower frame screw holes. Use your drill and 3/16-inch drill bit to drill new holes if necessary. If the shower walls are ceramic, use the concrete drill bit. If the shower walls are fiberglass, use the multipurpose 3/16-inch drill bit.
6. Insert the 3/16-inch anchors into the holes that you drilled. Put the side rail into position and insert the screws into the holes. Use your drill and Phillips head drill bit to tighten the screws. Place the bottom rail into position and mark the holes. Drill new holes if necessary and install the anchors. Insert only one screw at the end where you installed the first side rail. Lift up the loose end of the bottom rail and slide the second side rail into place. Mark the holes. Remove the side rail and drill the new holes using the 3/16-inch drill bit. Insert the anchors and put the side rail back into place. Insert the screws and tighten with your drill using the Phillips head drill bit.
7. Set the top rail directly onto the side rails. In each end of the top rail, insert the two self-drilling screws until the top is secured to the sides. Insert the tube of clear caulk into the caulking gun. Cut the end off of the tube with your box knife. Caulk the side rails and the bottom rail to the shower walls on the outside of the shower. Re-hang the shower doors by lifting each door and placing the rollers on the inside of the top rail.
Also giving you some links from where you can find a detailed information regarding replacing shower doors.
http://www.diynetwork.com/how-to/how-to-replace-a-shower-door/index.html
http://www.thisoldhouse.com/toh/how-to/intro/0,,214441,00.html
Thanks for contacting fixya.com
Please do get back to us for further query.
Jan 20, 2012 | Home
I need a diagram of the fuel line from the engine to the tank on my 1994 dodge dakota, so i can find a gas leak
There is no such diagram available. You will simply have to follow the fuel lines from the fuel rail on the engine along the truck frame rail towards the tank, or from the fuel tank along the truck frame rail towards the fuel rail on the engine. Some are on the left side frame rail and some are on the right side frame rail, depending on which engine your vehicle is equipped with. You simply have to LOOK.
Sep 05, 2011 | Dodge Dakota Cars & Trucks
Mislaid assembly instructions trying to get a email copy if possible for "Adam Cot Bed"
Here you go: http://www.babystyle.co.uk/pdf/CalgaryCotbed_AI.pdf
May 24, 2011 | Toys
How do i change the power window motor on the drivers door?
Aztek, Rendezvous 2001-2005 Window Systems - Power Windows Removal & Installation
  1. Position the window in the full down position.
  2. Remove the trim panel.
  3. Remove the water deflector.
  4. Remove the outer belt sealing strip.
  5. Remove the window weatherstrip.
  6. Loosen the bolts to the clevice clamps.
  7. Remove the window from the outside of the door.
To install:
  1. Position the window between the inner and the outer door panels.
  2. For front window, point the lower front corner of the window down and pass through the belt opening. For rear window, point the lower rear corner of the window down and pass through the belt opening.
  3. Align the edges with the window weatherstrip channel.
    NOTE Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  4. Turn the window to a horizontal position and align the window with the clevice clamps.
  5. Tighten the clevice clamps bolts to 97 inch lbs. (11 Nm).
  6. Install the window weatherstrip.
    WARNING Do NOT allow the sealing lips on the outer belt sealing strip to roll over and point downwards. If this condition is present the window will not raise properly.
  7. Install the outer belt sealing strip.
  8. Install the water deflector.
  9. Install the inner trim panel.
Window Motor & Regulator
  1. Remove the door trim panel.
  2. Remove the water deflector.
  3. For rear window, remove the rear speaker.
  4. Disconnect the window from the regulator carrier plate.
  5. Position the window in the full up position and tape it to the window frame.
  6. Disconnect the electrical connector from the window regulator motor.
  7. Loosen the bolts on the window regulator motor.
  8. Loosen the bolts on the window regulator rail.
  9. Remove the window regulator, lifting up and out from the key slots on the door inner panel and through the access hole.
To install:
  1. Install the window regulator bolts half way into the window regulator motor and the rail.
  2. Position the window regulator rail through the access hole first.
  3. Position the window regulator motor through the access hole.
  4. Install the window regulator into the key slots. Attach the regulator to the motor and the rail. Secure the regulator with bolts and tighten the bolts to 97 inch lbs. (11Nm).
  5. Remove the tape and position the window to the regulator carrier plate.
  6. Connect the window to the regulator carrier plate.
  7. Connect the electrical connector to the window regulator motor.
  8. For rear window, install the rear speaker.
  9. Install the water deflector.
  10. Install the trim panel.
Hope helps (remember rated this).
Jul 16, 2010 | 2002 Buick Rendezvous
1992 ford e150 fuel pump and filter locations please.....
Diesel Fuel Pump
Fig.: Fuel pump assembly components-1995-96 diesel engine
The Fuel Filter is located under vehicle, driver side, below seating area, near fuel tank, mounted on frame rail in fuel line.
Gasoline Fuel Pump
In-tank Pump
Fig.: Typical in-tank electric fuel pump assembly
Fig.: The external pump is mounted on the frame rail
Hope helped with this. Good luck.
Nov 16, 2009 | 1992 Ford Econoline
"where is the Horn Location for 2001 Chevrolet Malibu"
Horn Replacement Removal Procedure
  1. Remove the right headlamp assembly. Refer to Headlamp Assembly or Headlamp Bulb and/or Cornering, Sidemarker, Park, Turn Signal Bulb Replacement in Lighting Systems.
  2. Disconnect the horn electrical connector.
  3. Remove the horn bracket bolt.
  4. Remove the horn from the front frame rail.
Installation Procedure
  1. Position the horn to the front frame rail. Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
  2. Install the horn bracket bolt. Tighten
    Tighten the bolt to 10 N·m (89 lb in).
  3. Connect the horn electrical connector.
  4. Install the right headlamp assembly. Refer to Headlamp Assembly or Headlamp Bulb and/or Cornering, Sidemarker, Park, Turn Signal Bulb Replacement in Lighting Systems.
May 17, 2009 | 2001 Chevrolet Malibu
Exercise & Fitness Logo
51 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
