Question about Dishwashers
My dishwasher has power but wont work - Dishwashers
  • 26 Answers
Try to shorten the dor switch and if it works replace it!
Posted on Oct 21, 2013
Had a major power surge go through house now dishwasher doesnt work checked circut breaker is ok unit has power to it but wont turn on??
You probably have a fried control board. Better call a repair technician. But if the dishwasher is more than about 8 years old, maybe it would make more sense (cents) to go shopping for a new dishwasher.
Feb 14, 2015 | GE Dishwashers
My dishwasher wont start after the power outage. all the lights are working fuse box is checked also.
please follow this steps and fix it. God bless you
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer or Control Electronic
Replace if defective (note: uncommon problem).
4. Selector switch
Jul 30, 2013 | Kenmore 24 in. 15689 Built-in Dishwasher
Dishwasher won t turn off
As long as you have wired up correctly, your new board is faulty.
If you mean wont power down, as in the lights on the front wont turn off, these lights and the power switch itself are all part of the board.
Take it back for a warranty swap. Occasionally there is the odd faulty new part, there has be some unfortunate person to get them.
Jun 01, 2013 | LG Dishwashers
Dishwasher wont start
there is a switch on the dishwasher were the door shuts and u hear a click that switch tells the dishwasher when the door is shut and can start check the switch
Jul 24, 2012 | Dishwashers
Mekio dishwasher wont turn on dv 80.2
check the power connections check the power supply unit on the left there's a fuse, check control circuit breaker if it does not work email me at snjendu@yahoo.com
Nov 05, 2011 | Meiko DV 80.2 Dishwasher
DU943PWKSO DISHWASHER STOPPED WORKING, ELECTRICAL CURRENT TO PANEL BUT DOES NOT START NOR DOES ANYTHING TURN ON. LAST YEAR HAD THE SAME PROBLEM TECH TOOK FRONT APPART AND THE DISHWASHER STARTED WORKING. I...
Check you electrical power box that feeds to the house. If this dishwasher is hooked up under a sink counter and there is a garbage disposal in the sink area the dishwasher should be hooked up to the same circuit that the dishwasher is hooked to. If the garbage disposal works then the circuit is good your problem is either in the connection from the plug to the dishwasher or in the timer section of the unit. Either way the unit wont operate. Check power into the unit then check power at the hookup from the dishwasher to the plug itself if all is good then timer has gone bad
Good luck hope this helped you some
Dave
Jan 28, 2010 | Whirlpool DU943PWK - Multiple Color...
DISHWASHER WONT POWER UP
HI, there are four problem spots that i recommend checking. these are the most common hot spots for a non responsive dishwasher. Check each area thoroughly to address this issue.
2. Door switch
3. Timer
4. Selector switch
Jul 13, 2009 | Dishwashers
Wont go through cycles or drain the 3inches of water.Is getting power
turn on the dishwasher then go to your circuit breaker and, switch off the power to your dishwasher next: reach in to your dishwasher and remove the cover on your pump then remove any broken glass etc. that has fallen into the pump then put the cover back on and, close the dishwasher turn it on and, turn on the breaker you turned off earlier your machine should work again let me know how it goes...
May 02, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Maytag 300 Quiet Series Dishwasher
Unit will not turn on..had this unit for 6 months..worked fine..all of a sudden wont turn on now..checked power and connections..all were good..im stumped..just wont turn on.
Feb 15, 2008 | Dishwashers
Wont switch on
try replacing on/off button or replacing the door switch.
thees parts sould be examind by technishian befor replacment.
Dec 28, 2007 | De Dietrich 24 in. DVF120J Built-in...
Dishwashers Logo
32 people viewed this question
Top Dishwashers Experts
Owen Barnes
