Question about Refrigerators
System 600 fridge
IM LOOKING FOR REPLACEMENT PARTS FOR MY SYSTEM 600 FRIDGE MODEL UR615/1. WHERE IS THE BEST PLACE TO GO?
  • 1314 Answers
SOURCE: odours from fridge
frigidare makes a product called fridge- aid you can get it at lowes or any appliances parts store its made of activated coconut charcole it might solve you promblem
Posted on Jan 15, 2008
  • 518 Answers
SOURCE: fridge parts broken
Try checking HERE.
Hope that gets ya fixed up...
Geno
Posted on Mar 24, 2008
SOURCE: need parts diagram for scandinova fridge LF111D to find out which
To test the stat short out the wires and see if the compressor operates and cools the fridge.
Posted on Jan 06, 2009
SOURCE: Replacement glass shelf required
Not too sure what your glass shelf looks like, but if you can't find replacements it might be easier to just get a sheet of plexiglass and glass cutting tool from a home depo (or the like) and cut it to the correct measurements. That's what I did for mine.
Posted on Jun 16, 2009
  • 56 Answers
SOURCE: LATCH ON TOP OF FRENCH FRIDGE DOOR DOES NOT LOCK IN PLACE
you nedd to replace the door gaskets
Posted on Jul 03, 2009
Please can u suggest a direct suitablee replacment to fit Integrated Ariston BC312 model
for information on this , consult wit a fridge technician as they know the best replacement units for the fridge
Aug 30, 2016 | Washing Machines
Why did fridge stop working, then freezer 4 days later?
how it works. 6 month ago another technician came to this service call and found out that system is low on freon. So he charge it up with freon and add leak dye into the system. Leak was really slow, so he could not find at first. Here Im 6 month later, found leak dye with special light (dye leak set (tools) cost about 180$), did not need to order any parts, but replaced copper tube. Customer paid around 600$ for repair total for this repair. Hope That Helps!
Aug 16, 2015 | GE GDS18LBR Bottom Freezer Refrigerator
After power outage the fridge was displaying codes SY and EF I have Frigidaire model number FGHS2365KF1. Any thoughts?????
Hi.
SY: Defective evaporator system. Check evaporator fan, thermostat and heater.
EF: Evaporator Fan defective. Test and eventually replace the evaporator fan.
The problem is likely the evaporator fan. Before replacing the fan test the other parts comprised in the evaporator system.
Here a tip explaining how to test such parts with a similar fridge model: Fridge not cooling. Procedure is more or less the same with your model.
Here parts and diagrams for your model.
Generally you can find parts and diagrams for most appliances using the links listed on this page:
Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Aug 29, 2011 | Frigidaire FRS3R5EMB Side by Side...
Proline fridge/freezer the fridge is frosting up at the back but food is not cold enough
Hi.
You have a problem with the defrost system. Try disconnecting power overnight and allowing fridge to defrost. The problem will not occur immediately after defrosting, but will probably restart after few days, when the evaporator coils freeze again. In that case the defrost system must be tested and repaired.
The defrost system comprises defrost thermostat, heater, defrost control and fan. The parts that fail more commonly are thermostat and heater. Both parts are located behind freezer firewall and tested reading impedance with a multimeter.
A test on the defrost system can be done by performing a complete defrost manually (remove food and leave power disconnected overnight). If the fridge restarts working after defrost, then problem was the defrost system. In that case the problem may return after few days or weeks, meaning that one part in the defrost system is faulty.Parts must be tested.
If the defrost makes no change, then there is a different problem. The damper ventilation system , the temperature control or the refrigerant gas pressure may be the problem. When the problem is one of these faults you get the compressor is running regularly, but will stay on most of the time.
If the motor is humming and clicking most of the time, but not properly starting, then the problem is usually the starter relay/capacitor. Relay and capacitors can be replaced to fix the problem.
Here a tip explaining how to deal with a similar problem on a different fridge model: Fridge not cooling. Procedure is similar on your model.
You can find parts and diagrams for most appliances here:
Regards.
Aug 08, 2011 | Refrigerators
What does a CE error code on an Electrolux refrigerator (model EW26SS65GS) mean?
My fridge was having the same problem with CE being displayed, light and touch selector not working. With the assistance of one of my sons, we tilted the fridge back slightly and removed the control circuit board. Two of the three 470 u F capacitors were toast. My son drilled out the plastic brads holding the circuit board in the pan, then removed all three of the 470 u F capacitors. He soldered 3 new capacitors in place (0.59 cents each) and used 4 small screws/nuts to secure the board in place. After looking at the capacitors, he said a power surge had caused the damage. We went right out and bought a surge protector for the fridge. My fridge works perfectly now. While protecting tvs and computer from surges, I had never even thought of using a surge protector for the more costly fridge! Hope this helps someone else avoid an shamefully expensive parts replacement.
May 09, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I have a samsung refrigerator model RS253BASB. The freezer stopped working. The fridge is exactly 4 years old. Bought it new at Best Buy. The display shows the temperature being at -10 degrees but it...
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5172308&diagram_id=1337099#d1337099
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 19, 2010 | Refrigerators
Replace Evaporator in mini fridge
The system will definitely have to be recharged; the escaped gas was under pressure and you cannot remove the evaporator without losing its charge.
Since labor costs are not cheap, you might consider looking at craigslist for your area and buy a used one. Even new, they are mostly around $100 US which might be $30 higher than your planned evaporator swap.
Sep 24, 2009 | Refrigerators
Kitchen Aid Fridge Model KBR522K
Most fridges pull between 4 to 5 amps (600 watts) so a 1000 watt generator would cover all of them.
Oct 23, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Haier HRF-488FR/***
hi there, i noticed your post was in 08 did you find a seal to fit your fridge i have a hrf 488 fr/a and fisher and pykel are looking after them now... they advised be that this model is obsolete now and no longer have parts available.
May 19, 2008 | Haier Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
