Question about Electrical Supplies
Hi I have an older honda es 6500 generator. It has a twin cyl. Liquid cooled engine. It starts n idles good but when u turn the circuit breaker on an start generating power, the engine revs wide open. I noticed the vacuum operated diaphram pump opens all the way when this happens abd when the auto throttle button is on. Please help. Thank you.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Check your governor spring or governor adjustment
Posted on Oct 20, 2013
CarlGehrke
  • 169 Answers
SOURCE: Honda EM 2500 Generator
I posted a general tutorial on troubleshooting this problem here.
Rate me?
Carl
Posted on Dec 05, 2008
CarlGehrke
  • 169 Answers
SOURCE: auto idle on a reddy rgh11000 ie will not idle down
This sounds like the idle control solenoid has become misadjusted. To check that this is the case, locate the throttle lever and follow it back towards the governor arm until you find the solenoid. Start the generator and switch on the idle control while watching the governor arm where it passes near the solenoid, if the arm snaps back and forth you probably have a bad adjustment. To readjust the solenoid loosen the jam nut on the core of the solenoid just enough that you can turn the core by the square bit on the end. Adjust the core 1/4 turn or so at a time until the governor arm stays in position when the idle control is on, then turn idle control off and make sure that the governor arm goes back to the full throttle position. You may have to fiddle with the adjustment a little until you find the right spot. Tighten the jam nut back down and you're good to go.
Carl
Posted on Dec 09, 2008
protek480
  • 1723 Answers
SOURCE: The generator starts up then dies?
Check the oil pressure switch. It will shout you down like that if it doesn't sense oil pressure.
Posted on Oct 01, 2009
  • 251 Answers
SOURCE: Lombardini diesel generator starts and runs fine but no elecpower
remove the covering panel and expose the internals , check for loose/disscontected push on ( lucar ) connectors , if these are fine it is most likely the excitation capacitor is deffective , replace with exactly the same value/voltage rating/duty cycle . the capacitor is usual 1 or up to 3 cylindrical tubes with 2 wires comming from them , always take a note of exactly what wires you have taken off :) hope this helps
Posted on Oct 20, 2009
  • 244 Answers
SOURCE: generator runs, but produces no power
If it's still under warranty take it back to the retailer and tell them it quit working - don't offer any other information.
If you must fix the E/G yourself - On the generator there's a cover on the back; take the cover off so that the back of the windings are exposed. You should see 4 to 6 diodes mounted to the rotor and stator...those diodes are most likely burned out because of temperature failure, due to overload. You have to take them out to isolate them...they should read .6 Ohms one way; reverse the leads and they slhould read about 1.2 Ohms. If there shorted you'll read 0 Ohms and open infinety.
Anyway, replace those diodes and you should re-establish your field winding voltage which develops you A/C output.
Good Luck,
Mike...
Posted on Nov 24, 2009
Why is there gas in crankcase
Hello Ricky, I would check the carburetor needle valve and seat along with the carburetor float. You could get lucky and just need to clean the crud out of the carburetor float bowl.
Nov 04, 2015 | Honda Es 6500 Gas Generator Electric Start...
DEWALT DG6300B NO POWER OUTPUT
Hello avid.....
If there is no power to the receptacles:
1. Turn the circuit breaker switches off and disconnect all electrical loads from the generator.
2. Turn the circuit breakers on and test the GFCI's by following the procedures in this manual
on page 1 -
TO TEST A GFCI:
Start the generator. Turn the auto idle switch off. Push in the TEST button (A) on the receptacle.
The RESET button (B) will pop out. Power is now off at the receptacle.
If the RESET button does not pop out, the GFCI is not working. Do not run
generator until the problem can be corrected. To restore power to receptacle,
push the RESET button in. If the RESET button pops out during operation,
stop the generator and check the generator and equipment for defects.
3. Place the voltage selector to the 120 Volt only positions (unless you are using a tool that
requires 240 Volts).
4. Turn the idle control switch off.
5. Turn the circuit breaker(s) off and reconnect the electrical loads. Be sure that the plugs are
securely connected to the receptacles.
6. Turn the circuit breaker(s) on.
7. If there is still no power at the receptacles, take the generator to an authorized DEWALT
service center. To locate a DEWALT service center nearest to you, call 1-800-4-DEWALT
Joe
Thanks for choosing Fixya!
Nov 27, 2010 | Garden
I need a repair manual for a Honda ES6500 generator, can you tell me were to find it.
Try ebay thats were i go to find a hard to find manual. Hang onto that generator those es 6500 s are hard to come by . Hope this info helps
Nov 01, 2010 | Honda Electrical Supplies
1997 Honda XRV 750 Africa twin air-fuel mixture adjustment
Hi, Harrythespid it should be noted that the "AIR FUEL" mixture screw adjustment "ONLY" manages your idle and has no effect on any other circuit also any intake leaks must be repaired before the A/F adjustment procedure can be performed otherwise you will never obtain a proper idle and you will waste a lot of time chasing the impossible. The A/F mixture screw's purpose is to fine tune the fuel charge entering the combustion chamber. The following applies to both 2 and 4 stroke engines:
1. The mixture screw may be sealed at the factory with a Welch Plug please review the following video for removal.
https://www.youtube.com/watch?v=wAXcksgvDkM
2. The mixture screw manages a range of 3 complete 360-degree counterclockwise turns from the bottom/closed position.
3. The mixture screw should have a spring and o-ring for tension and sealing integrity.
4. Turn the mixture screw clockwise until it gently bottoms out, this makes the fuel charge very lean and the engine should not idle if it does then the pilot/idle jet is too big and needs to be replaced with the next size smaller.
5. Turn the mixture screw 1 and 1/2 turns counterclockwise to establish a baseline for starting the engine.
6. To fine-tune the idle circuit, adjust the mixture screw 1/4 turn in or out to achieve maximum idle RPM, wait 15 seconds between each adjustment for the idle to settle.
7. Never go past 3 full turns out this will make the fuel charge rich, foul plugs, and produce black smoke out of the exhaust, if the engine RPM keeps increasing past 3 turns the pilot/idle jet is too small and needs to be replaced with the next size larger.
8. After achieving maximum idle back out the mixture screw another 1/8 of a turn then adjust the throttle cable idle stop screw to 950-1050 RPM.
9. This procedure works great on 99% of all engines, for the 1% that demand a more robust throttle response on aftermarket monster fuel delivery systems additional tweaking outside the box may be necessary.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
XRV750 Adjusting the mixture synchronisation How
Honda Shadow VT700C Running Lean Fix Pilot Jet Needle Shim http://service.tanga-moteurs.ro/data/Honda_XRV_750%28Africa_Twin%29%26XL_600-650_V%28Transalp%29_%2787-02_Service_Repair_Manual.pdf
https://www.partsfish.com/page/oem-parts-for-honda
Honda XRV 750 Owner Manual
Sep 20, 2010 | 1997 Honda XRV 750 Africa twin
I have a honda 6500 generator. before startup main main circuit b
you needsto replace the main breaker you can get the part at your honda dealer
Jan 24, 2010 | Hammering
6500 watt diesil generator /as soon as i put any
if by fliping the breaker it shuts off..that means there is a short circuiting in the breaker..try connecting your house,shop..etc..directly ...
that is if the shut off reason is overloading...if not please explaing with details
Aug 23, 2009 | Electrical Supplies
Hi my honda generator runs for a couple of min then turns off this seems to happen more when its cold but happens when warm just not as much anyone have a idea of what it is
First off, Jason, what is the model number of your generator? It helps to know what product you're having trouble with so the correct information can be provided to you to help you solve your problem.
It sounds like the choke is staying on after starting. If you have an automatic choke, check for free movement of the choke spring and lever assembly (behind the carb). If it's a manual choke, remember to push it in once the engine is running smoothly (after 20 seconds).
It could be a fouled sparkplug or clogged air filter element too, but, again, without the model number it is very difficult to solve your problem.
You need to go to the Honda website and download a copy of the owner's manual for your specific generator and follow the step-by-step instructions for operating and troubleshooting your generator.
Here's the link to get your free online owners manual:
http://www.hondapowerequipment.com/products/manuals/
Hope you find this info Very Helpful and best regards!
The following helpful basic steps are from Honda:
To start your generator:
  1. Review your owner's manual to ensure familiarity with your generator's controls and operation.
  2. Move the generator outside.
  3. Check the fuel level and add more fuel if necessary.
  4. Check the oil level and add oil if necessary.
  5. Check the air filter and clean if necessary.
  6. Turn the circuit breaker off.
  7. Turn the fuel valve on.
  8. Start the generator.
  9. Allow the generator the warm up for a few moments before turning the circuit breaker on.
  10. Connect the appliances or the transfer switch if applicable.
Aug 20, 2009 | Electrical Supplies
Honda eu 6500 gen overload indicator light will not shut off
Check the Ground Fault Indicator circuit breaker for triping, and look for the high limit on generator. Reset the main breaker by triping it full right and then back. Vitally
May 22, 2009 | Honda 6370C - Parallel Power Kit For ...
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
