Question about Kitchen Appliances - Others
Switched fryer on without oil so it switched off and now won't turn back on
  • 2,113 Answers
The thermal cutoff failed... it looks like a resister or sometimes it is a button type the resister type costs $3 or so. All devices that produce heat have one, or a few.
Posted on Oct 22, 2013
Do I need to put oil in the deep fryer for it to turn on?
no it ,should turn on without that but you should put oil in it first anway.
Oct 30, 2016 | Kitchen Appliances - Others
Why did it stop working?
Big Boss™ Oil-Less Fryer - BedBathandBeyond.com
www.bedbathandbeyond.com/.../big-boss-oil-less-fr...
Bed Bath & BeyondHome > Gifts by Interest > Healthy Living > Big Boss™ Oil-Less Fryer. "Big Boss™Oil-Less ... Right size for family cooking, fried taste without oil, does what it is supposed to do ! ... I purchased a new one when my old Big Boss stopped working.
Big Boss Oil-Less Fryer Reviews and Complaints - Genuine ...
www.asseenontvonsale.com/kitchen/big-boss-oil-less-fryer/
Feb 22, 2012 - The working of Big Boss Oil-Less Fryer is very simple. ..... I am returning it because it does not work (does not turn on) but I don't want another ...
BIG BOSS KITCHEN PRODUCTS - Facebook
Dec 25, 2015 | Big Boss Oil-less Fryer
How do I turn on?
I just tested a Eurodib Model SFE01860-120 that would not turn on.
If you have added oil and plugged it in and pressed the on/off switch but the light does not come on, you have to rotate the thermostat control to the desired oil heating temperature. The red light will then come on and it should start to heat. If not, then the high limit safety cut off switch has tripped. Check the black screw button on the back.
Using a larger flat blade screw driver or your hand, unscrew the cover counter clockwise and push the little pink (red?) rod back in all the way. Replace the cover of the limit switch and all should be good to go. If not, then there must be loose wires inside. The high limit switch could have tripped if the fryer was turned on without oil for any length of time, which would cause the heater element to get hot really fast. Not a good idea.
Hope this helps
Dr Fix-it.
Aug 17, 2015 | Kitchen Appliances - Others
My Phillips airfryer turns itself off after about 15 mins of cooking. When I try to re start it turns itself off
I would refer to the operating instructions
I suspect that the fryer is switching itself off because it has reached the preset temperature or preser cooking time and will wait for a period of time to switch itself back on
The units I have seen do not run continuously but do the cooking in stages
Jun 29, 2015 | Philips AirFryer Healthier Oil-Free Fryer...
Switched the fryer on without oil and it turned off by itself. then turned it on again with oil in it but it never came on.
You blew the thermal cutoff It protects your house against an electrical fire they cost $3 or so at an electronics supply
Oct 20, 2013 | Tefal Easy Pro Fryer, 220 V
Fryer works then shuts down
i think that its is a hi limit switch to prevent a oil fire the fryers at kfc would dothis everyso often and it turned out tobe a bad logicalboard somewhere, check all valves and the switches on them to make sure that the fryer is aware when they are open or closed? let me know if you need more info
~Lee
Jun 23, 2008 | Pitco Frialator 35CS Deep Fryer
Star deep fryer.
Those thermostat bulbs are the thermostat and hi-limit bulbs.They need to be secured to the fryer.The hi limit is tripping out because its sensing that the oil is too hot.Even though the oil isnt that hot the hi limit thinks it is.
May 15, 2008 | Star 530FD Deep Fryer
Garland deep fryer
gas valve not fully turned on
cattering hose not fully pushed into connector
thermostat tube inside oven broken (new valve)
Nov 13, 2007 | Garland AF-5025 Deep Fryer
Kitchen Appliances - Others Logo
24 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
