No power on RCA rs2025 3 cd changer
My friend ask me to help him get his cd to open because it was stuck and on the lcd display it would say release. well i open it to try to unjam the cd carriage , to get to cds there is a metel covering on top, i unscrewed the the cover but i guess that some how the metal touched the the bottom of the elctontronic componets on the broad and now i dont have any power. you see happen because it plug in but the power was turned off thats, since i didn't see any light on the display i assumed my friend had unpluged but to my surprise he had not unplugged and since he had already started taking the screws off i assumed it was unplugged i know better and i know this time i did messed up i was the one who took the metal cover on the cd player. can you please give an idea on what comppnent to check. i already checked the fuse is ok. i checked con401 pin 4 and don't get and voltage. can you please guide me as what could i had burned when the meteal toched the leads of the componets. oh when i was taking the metal and when it might had touched the leads of the componets the power was off and i didn't see and smoke or smelled as if something had been burned. all i know is that after taking the metal covering i dont get and power on this unit. thank you very much for you for help
SOURCE:
SOURCE: Message 'no CD' always appears, but I can see the CD in proper position, but not spinning.
if you shut cd draw with no cd in, does the laser lens move up or down at all. if it does suspect dead laser pickup. it is very common for lasers to fail
Posted on Jan 13, 2007
  • 883 Answers
SOURCE: Pioneer PDR-W839 Jammed Disc Changer (previously posted)
hello poopig1, after further review, I meant to describe this: look for a pinhole in the area of the CD tray to insert a pin...similar to the same pinhole you see on a PC's cd player to eject the tray manually. If there is none, then try this: Open the cover and find the motor that, when turning, performs the tray ejection. Then, turn that motor by hand until the entire tray (or cartridge) is ejected. Then power up and observe the events.
Posted on May 31, 2007
SOURCE: Stuck CD
hi there bguedes
best solution take top cover of and as it says pleasewait and you hear the noise just give the tray a bit of a jolt to help it around but beware of electric wires and static that should fix your problem
hope this helps an please if you have the time please rate me if you dont mind
thank you
fixya
Posted on Jan 12, 2008
  • 23 Answers
SOURCE: Bose Wave Music Sys & 3 CD Changer
I have had a few of these come to my shop. The gears jump out of timing causing the cd lift to jam or become unalligned. The unit will probably have to be disassembled to get the CD out or have it serviced.
Posted on Mar 18, 2009
SOURCE: Friend's Durabrand CD566 CD player will NOT load discs
Honestly, here is what I did.
Your cheap-***, WalMart, DuraBrand, cd player will not work...correct? Trust me I know, I bought one for $2 at a gargage sale and realized when I got it home it would not work on ANY cd...not even with fresh batteries.
So.....I carried that beloved POS upstairs to the balcony of my and and dropped it flat on the ground from about 20 FT up. Of course it was dropped on carpet, but it was a good enough jolt to re-align the laser back up so it would read the disk.
My point is, is that the laser is not correctly aligned to read the disk. If a 20 foot drop does not fix it, palm it in your hand and slam it on a book that is laying on the counter. Don't slam it so hard that the poor thing flies to peices, but enough to make it think that "damn...that dude just dropped me off a balcony, what is next? Oh no...not the book slamming thing!".
Either way, the CD is not working. You can jimmy the laser back into somewhat of alignment, but if not, it sure is fun as hell beating it to death.
Dallas
Posted on Jun 19, 2009
Problem with the cd changer on my RCA Total Power 5 disc changer system
Unfortunately, it sounds like the relay or motor to open the drawer is either stuck or dead, which can cause the entire system not to play the discs even if the drawer is closed. First, try calling RCA Customer Support to see if warranty service/exchange can be made for the unit. Second, try taking it back to where it was purchased. IF all else fails, You can disassemble the unit (this voids the warranty - do at your own risk) and try to identify the motor and drawer mechanism- try removing the main casing to your stereo (unplugged of course) and ensure that the small belts & gears that operate the drawer mechanism are all in good working order by gently operating them by hand. If not, you can replace or try a repair, but it honestly may be cheaper (and better for your sanilty) to buy a new system.
Feb 18, 2013 | Audio Players & Recorders
RCA RS2664 Stereo
Do you know by any chance if a CD might be stuck inside?
Does the device power up?
Apr 09, 2008 | RCA RS2664 Shelf System
OEM CD player is stuck
have you tried disconnecting the battery cables? if this does not work, a CD may be stuck in it! You will have to remove the changer and open it up to remove the cd!
Aug 15, 2012 | 2005 Chevrolet Equinox
CD stuck in my Honda Odyssey CD changer
Turn van off. Open & close drivers door, wait for everything to power down. Turn van back on and push button to close CD/Nav opening. It will close. Having an issue with CD player also.
Mar 19, 2012 | 2008 Honda Odyssey EX-L
It is a 5 disc changer. The drawer will not open and it now has 4 cd's stuck inside the changer. It also will not play any of those "stuck" cd's.
THis happens when the drawer is jammed. Turn off the unit and turn it on and then use the disc skip from the remote so that the cds inside will change and then press the Open button.
Aug 21, 2010 | RCA Audio Players & Recorders
My rca rs 2657 cd changer is stuck. door will not open. any ideas how to correct?
If you hit the open button and you hear a sound like a motor running than it is most likely a belt or connection that physically opens the tray. You'll have to take it apart, locate the cd player and check from there. If no sound of a motor running when the button is pushed then the motor is probably bad.
Oct 17, 2009 | RCA 100-Watt Stereo System With 5-CD...
My rca 5 disk vertically stacked cd changer is stuck. Won't open. How to fix it?
Try this... unplug the unit and turn it upside down.  Have a small screwdriver ready.  No plug the unit in and try to turn the wheel in the large slot clockwize.  When you see the spring clip try to grab the white plastic stop and move it clockwize.  This should eventually open the door.  It did for me.
Aug 03, 2008 | Thomson RCA Bookshelf System with 128 MB...
Pioneer cdx fm653 6 disk changer won't power up
first try to get another display, maybe it's broken (could be the cable cutted), the changer with a motor noise in the moment you plug it, tell me that its ok (95%).
Sep 12, 2007 | Pioneer CDX-FM653 6-Disc CD Changer
Screen only shows "cd"
possible tray stuck, will cause this problem, if you can get the case off, 2 screws on the bottom and 4 or 5 on the back case , if it is jammed the unit will not initialize..I am talking from experience with model and simular models ..I have repaired alot
Aug 22, 2007 | RCA RP8078 5-Disc CD Changer
56 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
