Question about Kenmore 53092 / 53094 Side by Side Refrigerator
Ice maker wont dump, has ice, model # 106.56584500
catriver
  • 878 Answers
SOURCE: icemaker slow to make ice
Tener, sounds like you have a module going bad. Pull off the white cover of the ice maker and take a look at the center white gear. There should be two clips securing the gear on. A lot of times these clips break and cause the gear not to rotate properly. Part number for the module is 628399. Take a look at this first. Catriver..post back
Posted on Nov 02, 2006
peyton32034
  • 410 Answers
SOURCE: Ice maker has ice in it but will not dump in bin!
before i would worry about the lights flashing lets pull the front cover off of the icemaker and verify that the drive gear is not broken.
on the bottom of the icemaker is 1 screw. remove that screw then just slide the entire icemaker out of the refrig so that you can access the front cover. if the gear is broken just replace the front motor module pt# 8201515
if the gear is fine then located in the toe grille of your refrig is a tech sheet that will help you troubleshoot red light blinking.
Posted on Dec 17, 2007
  • 43 Answers
SOURCE: Mod. GS6NBEXRS01
take the bin out and check for a jammed ice cube in the ice cube making mechanism. Many times they have a rotating finger that gets stuck on a cube that does not drop entirely. Hope this helps
Posted on Jul 13, 2009
  • 181 Answers
SOURCE: ice maker will not dump ice, it has ice just will
ice makers are tough to repair. should look at replacement. fairly simple replacement.
Posted on Aug 30, 2009
  • 512 Answers
SOURCE: Our ice maker is not working, we hear a cliking
Check to see if there is ice jammed in fins. Usually when you here clicking that is the solution.
Posted on Oct 04, 2009
Ice maker dumping water in ice bucket instead of ice
Replace water control valve. If you have questions please let me know, Thanks John Tripp Appliance 911
Oct 07, 2014 | Fisher and Paykel Refrigerators
Ice maker not working
Depends on the model of ice maker you have but most have a removable bin, take the bin out dump out the ice, run water through it and set aside to dry. Make sure the chute is clear and put the bin back. Do this twice a year and you wont have any problem with your ice maker
Aug 25, 2014 | Refrigerators
Kenmore coldspot model 106.58902800 ice maker does not dispense ice
Ice maker will not dump ice, makes it but will not dump ice.
Jan 30, 2012 | Kenmore Refrigerators
Ice maker will not dump ice there is ice in "tray" but wont dump
I.M 6 electronic Ice makers are non servicable, replace the ice maker. throw the other in the trash can.
If ice is in the ice maker then you know it got water but didnt dump the ice. its the ice maker.
Oct 26, 2009 | GE Monogram ZISS480NRSS 48" Built-In...
ICE MAKER NOT WORKING ,MODEL #gss25lgma ww
The problem is most likely the water control valve on the rear of your refrigerator. You can test the ice maker by filling with water and let freeze. If ice dumps then the water valve must be replaced. Your model has 3 different choices of water control valves. If the ice maker does nothing but freeze the water and not cycle or dump the ice then I would say the thermostat inside the ice maker is defective. Thanks, Sea Breeze
Aug 18, 2009 | GE Refrigerators
Frigidaire not dumping the ice
Hi: Dumping the ice is the start of the ice making timer. Before you replace the ice maker... Set the freezer one setting colder. The ice maker wont make ice if the freezer is not at zero degrees F. Just because things are frozen in it dosn't mean it is at zero. This happens a lot in the summertime. After resetting the temp don't open the door every hour to see if it makes ice as you will just dump the cold air out. Listen for the ice to dump, give it 24hrs. I hope this helps, Jeff
Jun 06, 2009 | Frigidaire FRS23KF7AB Side by Side...
Kenmore 53092 / 53094 Side by Side Refrigerator Logo
23 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
