Hyundai coupe loud bubbling sound from petrol tank when ignition is turned on
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 49 Answers
This sound is from your petrolpump starting to get pressure to the rest of your petrol system. when your tank is full you dont hear this sound so good becase the pump is then submerged in petrol in your tank.
Posted on Oct 24, 2013
Hyundai coupe imobelisor problem
sounds like a burnt out fusible link
Feb 26, 2014 | Audi A6 Cars & Trucks
Hyundai coupe water leak from expansion tank
The system is supposed to be able to contain the overflow then pull the extra coolant back into the radiator when needed.
Is the overflow tank fluid level at or below the recommended level ?
Jul 25, 2012 | Cars & Trucks
Remote control receiver unit were is it , and a pic of it to reset key fob on a hyundai coupe se 2000cc year 2002
This reset for key fob Hyundai coupe year 02 to 04
Turn ignition to position two
Press lock or unlock once
Ensure indicators flash once to confirm reset
This will enable fob providing you have no other faults
Good luck barry
May 12, 2010 | 2003 Hyundai Tiburon
Hyundai accent
If the car has had contaminated fuel in then you can just take the fuel pipe off and leave the ignition on the fuel pump will pump the fuel out, if the tank has debris in it then you will most likely have to remove it completely.
Jan 31, 2010 | 2000 Hyundai Accent
Hyundai Coupe 2.7 V6 auto 2002 I have a problem starting my coupe. This is an intermittent problem and has no pattern. so frustrating :( She will turn over but will not start, it take 2-5 times of key...
Main fuel line from tank to fuel pump, Sounds like the pump is sucking the fuel and air is getting in also, only when the fuel system is pressurised and the return line is sending fuel back to the tank will the air pressure in the tank be higher than the outside atmosphere and then air will no longer be sucked into the system - if this is true there will be a fuel leak - maybe only a little - to find if there is a leak, start the car on level ground, turn off the engine and restart it several times, then move the car back and check on the ground for any fuel - also check under the bonnet and sniff around for any strong petrol smells - there will probably be a fuel pipe damp with petrol - tell me what you find - if it is or isn't leaking I can give you the next steps to identifying the problem -
Jan 26, 2010 | 1995 Hyundai Elantra
2004 hyundai accent. trouble filling gas tank
I have a 2005 Hyundai Accent, It is not possible to fill the tank if you are letting the petrol pump run at full speed.Trying to fill up quickly it will only build up pressure and cut off. Next time you fill up just pull the petrol pump handle half way, it will take longer to fill but you wont get the blow back. Modern petrol pumps are getting quicker all the time.Hope this helps you.
Mar 23, 2009 | 2005 Hyundai Accent
Hyundai Elanta still wont start!!!!!!
maybe this timing setup will help...
you also can try spraying a little ether into air intake...
hope this helps
at least rate me "ALMOST THERE" if not fixya!...thanks..
Jul 05, 2008 | Hyundai Motor 1999 Elantra
Hyundai 2004 accent coup
For the 2003-2005MY the fuel filter is incorporated into the fuel pump assembly within the fuel tank.
inside the fuel tank
May 29, 2008 | Hyundai Motor 2004 Accent
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
