Question about Electrical Supplies
I have a generator suzuki sv 7500 with a rotor broken and I have no serial number in order to buy it
  • Guillermo Bourguet
    Guillermo Bourguet Oct 22, 2013
    With the find and clarify my question is if anyone knows sellers suzuki generator parts somewhere in the world. thanks
    Master:
  • 342 Answers
Do you mean the armature is actually broken ? if so check out mec alt spa for a replacement alternator
Posted on Nov 04, 2013
My 7500 watt generator doesn't produce any power
If it has sat, it may have lost it's rotor residual magnetism. Disconnect the rotor field wires at the AVR or on the exciter/brushes. Note they are polaroty sensitive. Connect a 12V battery to F+ and F- (note polarity) and momentarilly power from the battery for a few seconds. DO NOT forget to disconnect the rotor/exciter field wires first or the voltage regulator will be damaged. If it hasn't sat check voltage regulator, rotor resistance, and stator resistance, and for shorts to ground.
Jul 31, 2014 | Honeywell 7500 Watt Generator 15 HP Engine...
How to remove the back tire of a suzuki sv 1000
tire shop, paddock stands, loosen the rear tensioners, pull the spindle, take wheel to mechy, buy tire from ebay, musty be cheaper. 5 gbp to change with wheel off
Jun 29, 2014 | 2003 Suzuki SV 1000
Generator suzuki sv7500 manual
Where can I find Manual for Suzuki SV 7500 generator?
May 12, 2014 | Electrical Supplies
How do i flash charge my 7500 watt generator
Remove the end case on the generator end, locate the brushes and also the wires going to the brushes. Crank the engine while measuring the voltage on the brushes, note which lead is B+. Disconnect the brush wires and isolate. To flash the rotor you will need a battery wires with an in line fuse, connect the wires noting B+ to the right brush where you measured earlier (polarity is critical) then toucj on the battery for approx 3 - 5 seconds, this will rebuild the field in the rotor. Disconenct and re-assemble brush wires. When you start generator do not add any load for a while, until the rotor field has chance to re-saturate
Dec 08, 2012 | Coleman Powermate Premium Plus 6250W...
I own a 2004 Suzuki SV1000s sportbike. I removed the baffles from the exhaust and 4 weeks later it acts like there is some sort or govener that activates when I rev it anything ovver 7500 rpm
If this happened 4 weeks after you removed the baffles, then i doubt your problem has anything to do with that.
Check some other things first, clean your air filter, and check your spark plugs, they may be worn out or fouled.
Mabey drain the carbys also?
good luck
Jun 29, 2010 | 2004 Suzuki SV 1000 S
Suzuki Carry 1000cc 1993 Rotor not turning in
remove the distributor, u will find the gear drive worn or broken or the timing belt boken
Oct 01, 2009 | Suzuki Swift Cars & Trucks
How do i test if my magnet/stator is charging my battery and what shoul i do, is there a fuse that i must chheck.
Common problem is broken alternator drive, remove it from rear of moter and it will look likew broken rubber, about eight quid to fix,if ok then voltage regulator is also common suzuki problem and cheaper to fit aftermarket one which dont burn out!
Jul 28, 2009 | 2001 Suzuki SV 650
Rotor replacement
The original spec calls for 310mm discs.
May 02, 2009 | 1996 Suzuki GSX-R 750 T
Generator runs, but does not generate electricity
Reset / tickled? There are resistors and diodes in the end of the alternators rotor (the bit in the middle that spins) If these look ok visually then change the capacitor which is a barrel shaped object usually with 4 prongs on the end. Without a capacitor the genset will not produce a voltage.
Sep 18, 2008 | Electrical Supplies
Electrical Supplies Logo
171 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
