Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
The brushes are turning full speed it sucks when I go forward and throws it all back to my carpet when I go backwards leaving black lines in the carpet.
    Sergeant:
    Champion:
  • 346 Answers
It's stopped up. clean it out between the nozzle intake and where the hose attaches
Posted on Oct 21, 2013
SOURCE: Hoover SpinScrub Carpet Cleaner
I was having the same problem, the black seal under the tank that captures the water was broken, and it wasn't getting any suction.
Posted on Feb 06, 2008
Candyhelp
  • 136 Answers
SOURCE: Hoover Steamvac Ultra
make sure all parts are snapped in again i did the same thing.......
Posted on Mar 17, 2008
SOURCE: brush won't rotate when pushed forward
I had the same problem . The reason it acts like that is due to the cable that runs from the vacuum motor to the brush assembly has an intermittent open. My fix was to find the small cable that was causing my troubles and splice it. Making sure that I recovered the insulation. Of course my local repair station wanted to replace it for $75 labor plus parts and keep it for 3 days. I took it home and did it in 30 minutes .
Posted on Dec 12, 2008
  • 294 Answers
SOURCE: Steamvac won't **** the water into the recovery tank.
This usually means one of a few things:
1. The lower tank is full
2. You did not dispense water (sloution tank empty), when applying solution to the floor.
Posted on Jan 19, 2009
SOURCE: Hoover steam carpet cleaner brushes dont spin
There is a plastic cover over the spinner indicator. If you take the plastic cover off there is also a little filter in that area (almost like the spinner is on the floor and the filter is on the wall). If you clean this filter it may start working again. I had the same problem before and it worked for me. I found the info in the user's manual for my model. Hope this works for you as well.
Posted on Sep 04, 2009
Precision model EL8802...hard to push, sits too low to carpet
An upright cleaner that is in good condition and working properly is always hard to push on loose laid carpet as it is designed to suck the carpet clear of the floor firmly against the mouth of the brush housing. This is so air is drawn through the carpet to aid dust removal and so the brushbar can make full contact with the carpet.
Jun 03, 2017 | Vacuums
My dyson dc14 leaves lines on my carpet why?
Hi Geoff, it's Jack at Dyson.
To answer your question effectively we would need to understand a bit more about the type of lines your DC14 is leaving in the carpeting. The rotating brush bar sweeps into the carpet pile to remove ground-in dirt and pet hair. The bristle tufts can have the effect of raising the pile where it's been trodden flat from use. Equally, as with any upright vacuum, the two rear wheels can leave temporary impressions in the carpet pile, which may be more noticeable in deeper pile carpeting.
We wouldn't expect the machine to leave other types of lines, and we'd like to help you check the soleplate and brush bar are undamaged, and fitted and working correctly.
When you have your DC14 easily to hand, please contact the Dyson Customer Helpline. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Mar 23, 2015 | Dyson Vacuums
I can't push my Dyson Dc33 on my new carpet..it works backwards ok but not pushing forward?
Hi Fran, it's Jack at Dyson.
DC33 is engineered to work effectively on both hard and carpeted flooring. The cleaner head is engineered to adjust automatically for different floor types and carpet piles. You can also turn off the brush bar for hard floors and delicate rugs, using the brush control on the cleaner head.
I'm sorry to hear you're having difficulty pushing your machine forward on this particular type of new carpeting. If your DC33 worked effectively before the new carpeting was fitted, it doesn't sound like there's an issue with the vacuum itself. However, we'd appreciate the opportunity to take some further details about the issue, and may be able to suggest a resolution. You may also want to consider contacting the carpeting manufacturer directly, as they should be able to recommend the best way of caring for this specific carpeting.
When you have your DC33 easily to hand, please give the Dyson Customer Helpline a call on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Feb 13, 2015 | Dyson DC33 Multi-Floor Upright Bagless...
Hoover brush and wash instruction manual
Hi there! To prepare for cleaning, put the solution and water in the top tank. While cleaning, all the dirty water gets sucked into the bottom tank. To clean squeeze trigger to release cleaning solution and slowly push carpet cleaner forward, this equals one wet stroke. Continue to squeeze trigger and slowly pull carpet cleaner back toward you (second wet stroke). Release trigger and slowly push carpet cleaner forward over area just sprayed with solution (dry stroke). Then slowly pull carpet cleaner back toward you without squeezing trigger (dry stroke). To avoid saturating the carpet don't do more than 4 wet strokes over one area. Always end with dry strokes. Here is a link to view the instruction manual if needed.
http://hoover.com/file/604/
Hope this was helpful!
Jun 19, 2014 | Hoover SteamVac Carpet/Upholstery Deep...
Wont move forward or backwards
Generally the belt is probably stretched and needs replacing but I have had several that required modifying the height adjustment assembly. Belt should be a bit of a fight to stretch and get the brush block back in properly to maintain resistance. The higher carpet causes the belt to slip and can even cause burn/wear from the motor shaft spinning in one spot. Sometimes people run them and burn through and break the belt. Generally you smell rubber burning if belt is slipping and burning. The height adjustment modification was a last resort and not easy! Not for the average person! Another post tells how to modify but better be handy!
Dec 07, 2013 | Hoover Vacuums
When i am vacuuming my carpet....it sucks the dirt up when i am pushing it forward, but when i pull it back, the dirt comes back out on the carpet
This is due to a loss of suction. The roller brush sweeps the dirt to the hose area, but with no suction, when you pull the vacuum back, the brush just kicks the dirt back out. This is most likely due to a clog in part of the hose system.
You don't mention whether it's a canister or upright, but check all hoses and tube.
It can also be due to a full bag or clogged filter. Another cause could be a fault in the switch or wiring that turns on the power nozzle (only if it has a separate motor) but not the vacuum.
The fan blades could be broken or worn, which would allow the vacuum to run, but with no airflow/suction.
Or most costly, the motor is worn out and no longer working.
Nov 03, 2010 | Vacuums
Bissell Power Steamer Pro Deluxe will not move forward
tip unit back to lift brushes off floor and roll forward until over carpet edge. tip back unit to sit flush on carpet and unlock handle so it swings freely. now pull backwards ith finger on spray trigger. that's how it works, not by pushing forwad.
May 16, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Wont spray water on the carpet
Same Problem here- The hand piece works fine. Bissell 9500 ProHeat2X.
Both tanks full New Belt on the brushes I can not get cleaner/water to spary when trying to clean the floors.
I've taken my air-compressor and with low psi blown back to make sure teh lines are clear from the spary heads. Still not working...
Apr 17, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bought a new sweeper and brush ( beater bar ) does not turn. The large belt is fine and turns. The small thin belt is also fine but does not turn the brush. It is either the wrong belt or is there...
Jim, To put tension on the brush, tilt machine forward when upright, move carpet selector knob to carpet. then turn vac on. Brush will only spin when vac is tilted back to operate. brush stops when upright and on to use hand tools so the er is no danger to carpet or persons with moving roller.
Sep 29, 2009 | Hoover U6630-900 WindTunnel Bagless...
Nov 05, 2007 | Hoover V1 SteamVac SpinScrub Vacuum
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
46 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
