Kenmore 3394715 lid switch not working, wont drain
  • 116 Answers
SOURCE: i think it is the same proble as you discribe
Hey chiki76
You still have a lid switch problem. The switch has to be replaced. The switch usually comes apart or the clips securing them are broken
regards
Posted on Sep 07, 2008
Maytag317
  • 1136 Answers
SOURCE: Kenmore washer wont drain or spin
Hi, Remove the end caps on the control panel. There is 2 screws in the front corners that need to be removed and the control panel will lift up. Locate the lid switch connection disconnect it. Use an insolated wire and jump the two brown wires and see if the washer will spin. The green wire is groun (Do not use that wire)
I hope this helps you.
Vic
Posted on Jul 02, 2009
  • 670 Answers
SOURCE: Kenmore washer, 110.22722100, won't spin
It may be the coupler. see my link to sears parts for exploded view. coupler is number 13. The coupler is behind the motor and will need the main cover (case) removed to replace it. Inspection is also easier with the case removed. It's an $18.00 part and a bout $90.00 in labor to hire it done. I can help. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.22722100&pop=flush at this link choose BRAKE/CLUTCH/GEARCASE/MOTOR/PUMP
Posted on Jul 03, 2009
r_dawg
  • 50 Answers
SOURCE: My kenmore 70 series 110 model washer will not
  1. Bad pump motor
  2. Timmer switch not sending power to pump
Posted on Jul 08, 2009
jsrock516
  • 5911 Answers
SOURCE: Kenmore Mod# 110.25842400 lid switch
The following link gives you step-by-step instructions on how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
If you have any questions about this repair, please let me know. I hope this helps you.
Posted on Jul 15, 2009
Kenmore washer front load 417 wont spin
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Click if helped
Feb 18, 2013 | Kenmore 24032\24036 Top Load Washer
Washer wont drain
when you lift the lid there should be a switch if you push it down with a pen or something it should drain If that does not work then it's the control knob but I'm betting it the the lid switch
Jan 07, 2012 | Kenmore Washing Machines
I have a kenmore 70 series that wont drain. It washes and agitates, but wont drain what could be the problem
It sounds like the lid switch. Open the lid and depress the switch (with a pencil or similar) until it clicks. Then see if it spins. If it does not, replace the switch. If it does spin, check the plastic "pin" on the lid to be sure it hasn't broken off. It has to depress the switch when the lid is closed. The pin should be about 5/8" long.
Dec 31, 2009 | Kenmore Washing Machines
I want to know the production date of Kenmore 3394715, stackable washer/dryer combo.
The production date is determined by the SERIAL NUMBER on your appliance. The following link explains:
http://www.fixya.com/support/r2880489-determining_age_whirlpool_appliance
Kenmore washers are manufactured by Whirlpool. If you still have questions, please let me know. I hope this helps you.
Sep 16, 2009 | Washing Machines
Wont drain or spin
Does it click when closing the lid ? Sometimes , the lid switch arm , will work inserting something into it , but not with the lid closed . Try checking it useing the lid itself . Occasionally , the arm wears to where it has to be pushed farther down to work so the actuator on the lid cannot push it far enough down .if you have to replace the lid switch for it to work properly or bypass the lid switch it needs to be from under the console .do not drop screws in between the tubs
Aug 16, 2009 | Kenmore 24032\24036 Top Load Washer
Washer stops after aggatating and wont drain
My Kenmore 70Series washer goes through the wash cycle then just stops when it is to drain and then spin.
Jun 10, 2009 | Whirlpool Washing Machines
My washing machine water wont drain,it is a kenmore 90 series.
  • first thing to check is the lid switch.
  • if the lid switch is bad it will fill up, then agitate then sit there full of water.
Jul 05, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
