Dazey stripper motor will not rotate - Audio Players & Recorders
I had a fire and my Dazey chef's pot/stocker recipe and instruction book was destroyed. How can I get another one. Model dcp-640
does some of this information work for you? Please comment
http://www.hungrybrowser.com/phaedrus/Dazey%20Chef%27s%20Pot.pdf
http://www2.ca.uky.edu/hes/fcs/factshts/FN-SSB.003.PDF
http://smittenkitchen.com/blog/2013/05/essential-raised-waffles/
http://www.meba.com/manuals/Dazey-SealAMeal-1968.pdf
http://www.ebay.com/itm/VINTAGE-DAZEYS-CHEFS-POT-RECIPE-INSTRUCTION-BOOK-DCP-6-640-3-325-/390947946118
http://www.mosaiccodes.com/donuts.html
Jul 07, 2015 | Crock Pots & Slow Cookers
I have xerox phaser 8400 : when i turn it on it says : service needed fault 37 002 47:115353\r\ncould anyone help for that . thanks
Service Manual says:
37,020.47 = (8400) Strip Solenoid
37,020.47: Strip Solenoid disconnect.
The strip solenoid is not drawing the
expected power.
The Solenoid (relay) may be bad, or the power to it is low.
The Stripper Solenoid positions the stripper blade. The solenoid mounts on the Upper Inner Duplex guide and activates the strip solenoid lever, which in turn rotates the Stripper Carriage
until it hits the transfix ground pins. This action causes the stripper blade to drop onto the deadband of the Drum.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jun 20, 2011 | Xerox Phaser 8400 Laser Printer
I have a Dazey crock pot model P-500 DTC-1 how can I get another heating probe for it?
Go onto Ebay.com and do a search for Dazey DTC 1. I am selling one right now.
Feb 07, 2010 | Rival SCC658-SS 6.5-Quart
I bought a Dazey crockpot at a yard sale. Do you
NO! water where it might end up in the heating element and the base section should not ever be submerged for cleaning, only the removable crockery.
Oct 24, 2009 | Kitchen Appliances - Others
Once the np 6050 is turned on it displays error code E010 switch off and on again
E010 code is main motor lock. Open front cover, Release Transport/Fixing Unit tray. Pull the tray out untill it stops. Try rotating the larger knob to see if Fixing unit will turn...if not, raise the exit/stripper assembly to check for jammed paper. If no paper present and the Unit turns freely, reinsert Transport/Fixing tray into copier. Latch into place. Close front cover. Power on machine.
It is possible that the main motor has failed, but not likely.
Jun 19, 2009 | Canon NP 6050 Copier
Need replacement crock, Dazey/Presto
FOR THE MONEY JUST BUY A NEW ONE.IT WILL COST YOU LESS MONEY!!!!!!
Mar 07, 2009 | Crock Pots & Slow Cookers
Ice maker won't work
check the position of the strippers in the icemaker. normal "home position" is at the 2 o'clock facing the front of the i/m if the strippers are in any other position most likely you have a bad motor module on the i/m pt# 628366 (whirlpool part number) should fix it up for you.. Good luck Peyton
Jan 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
 Grubhead
Grubhead
