Question about iSymphony LC42iF56 42 LCD TV
How do I turn off the audio description - iSymphony LC42iF56 42 LCD TV
    Sergeant:
    Champion:
  • 272 Answers
Refrence the manual http://www.isymphonyproducts.com/IM%20LC42iF56.pdf
Simple fix for it--> setup--> reset defaults
Posted on Oct 21, 2013
Sonehow turned on audio description want to turn it off PLEASE Help
You have the second audio program (SAP) enabled. Return to the initial set up procedure and disable it.
Dec 11, 2016 | LG Televison & Video
My 2004 Pontiac grand am se1 acts like door is open and interior light stays on also does t lock on its own when in gear and lights don't blink and horn not honk when locking with key bob
Door ajar switch problem more then likely or wiring issue . The BCM - body control module won't turn off interior light , let door lock because it think's the door is open . The door ajar switch is a input to the BCM .
The first thing would be to have it checked for DTC'S - diagnostic trouble codes . Also check with an enhanced scan tool to see if the BCM shows ajar switch data (open or closed ? Do you know about body electronics ?
Body Control Module
The various BCM input and output circuits are described in the corresponding functional areas indicated on the BCM electrical schematics. The Body Control Module functions include the following:
A/C compressor request. Refer to Air Temperature Description and Operation
Remote Function Control. Refer to Keyless Entry System Description and Operation
A/C cooling Fan. Refer to Air Delivery Description and Operation
Audio Delay Power. Refer to Radio/Audio System Description and Operation
Exterior and interior lighting control. Refer to Exterior Lighting Systems Description and Operation
Daytime running lights (DRL)
Automatic lighting control
Fog lamps
Interior lighting. Refer to Interior Lighting Systems Description and Operation
Battery rundown protection (Inadvertent Power). Refer to Interior Lighting Systems Description and Operation
Chimes. Refer to Audible Warnings Description and Operation
Key-In-Ignition
Head Lamps On
Seat Belt Not Fastened
Turn Signal On
Park Brake Warning
Door Ajar Warning
Check gages
Gage control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Instrument cluster indicator control. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Theft deterrent. Refer to Theft Systems Description and Operation .
Engine coolant level sensing. Refer to Cooling System Description and Operation .
Washer solvent level sensing. Refer to Wiper/Washer System Description and Operation in Wipers/Washer Systems.
Key-in-ignition sensing. Refer to Audible Warnings Description and Operation in Instrument Panel, Gages, and Console.
Seat belt use sensing. Refer to Seat Belt System Description and Operation .
Brake fluid level sensing.
Parking brake state sensing.
Rear compartment interface. Refer to Power Door Locks Description and Operation
Horn interface.
Door lock interface. Refer to Power Door Locks Description and Operation
Bulb Check. Refer to Instrument Cluster Description and Operation in Instrument Panel, Gages, and Console.
Oct 24, 2016 | 2004 Pontiac Grand Am
How do I disable audio description on an LG 55LF6000 TV?
Go to set up or settings and find audio options, then deselect audio description.
Aug 06, 2016 | LG Televison & Video
How do i turn the commentary for the blind off my sony bravia tv
something like Menu - Setup - Disability settings.
I also found two items specific to Sony Bravia
Audio Description (AD) is not part of the subtitle set up. The current Manual includes it in Audio Set-up as a distinct sub-heading "Audio Description".
My Bravia is 3 years old and must have had an update recently which allowed it to make use of AD which is slowly becoming available to a lot of programmes. Unfortunately the update did not update the Tools function so I have the ability to take the AD facility but not the ability to switch it off.
Are you able to turn off Audio Description via..
Go to the Home menu..
Then browse to Settings..
Followed by Digital Set-up..
Then Subtitle Set-up..
Finally Subtitle Setting.?
and If you have Freesat:
Press the Menu button on your remote control.
Select Settings using the up/down arrow button and press OK.
Select Language using the up/down arrow button and press OK.
Select Audio Description and then Enable or Disable using the OK or left/right arrow button.
And specific t o
Jan 24, 2016 | Sony Televison & Video
How do i remove talk over from my 46" bravia
To turn off the audio description on your new Sony KDL32EX723, you have to get your Remote Control. Look for the AD button then click it. The audio description will now be disabled.
Sep 07, 2015 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Im trying to turn off audio description but cannot find the SAP.Model number LS35 / LS34/ CS46 These numbers are listed on the front of the manual..Thankyou
If it is from programs you have recorded, you need to change the settings on your PVR, not the TV. Each PVR is different so you'll need to check the owners manual for your model.
Oct 18, 2014 | LG Televison & Video
How do I turn off audio description Sony bravia
If you mean closed captioning, you should be able to turn it off with your remote
Oct 06, 2012 | Sony BRAVIA KDL-20S3000 20 in. LCD TV
Want to turn off audio description off on my Panasonic Viera. Handbook says go to menu then sound but I can find nothing there.
iv got a panisonic i dont know if its the same but i click on the options buttion witch takes me to the options menu
then it says ad in the multi audio/ad box change this to eng
Jan 01, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
How do I turn off the SAP - there is audio description of what's happening on NCIS which was not there before.
If the remote control has a SAP button, pressing it should cycle through the choices. Keep pressing it until you reach OFF. (That's probably how it got turned on. It's easy to hit a button and not know it.) If the remote doesn't have SAP button, adjust the settings through the set's setup menu. If you are using a cable box, make sure it doesn't have a SAP setting that has gotten turned on.
Apr 17, 2009 | Televison & Video
Background voice, 27 inch "truflat" 2005 model
What you're hearing is the descriptive audio track included on many DVDs for vision-impaired viewers. Does this happen when you're watching regular TV or just with DVDs? If it happens with regular TV, do you have a cable box?
Regular broadcasting sometimes uses SAP (second audio program) to send additional audio, and this descriptive audio may be the SAP channel on some programs. Check your TV's audio settings to make sure you don't have SAP turned on. There may also be settings for SAP in your cable box as well, so check there too.
When playing a DVD, descriptive audio is usually an alternate audio track. Check your DVD player setting to make sure you've selected normal audio for playback.
Apr 04, 2009 | RCA TruFlat 27F520T 27" TV
iSymphony LC42iF56 42 LCD TV Logo
Top iSymphony Televison & Video Experts
Electro Med Services...
John In Milford
John In Milford
Are you an iSymphony Televison and Video Expert? Answer questions, earn points and help others
