Question about Headers 70-1118 for 88-89 Ford Ranger, Bronco II, 2.9L, 4WD, exc. column shift
1988 ford ranger wont start. Need to go through gears then put back in park then it will start
    New Friend:
Sounds like a neutral safety switch loosing contact and when you go through the gears and back up it makes contact again
Posted on Oct 20, 2013
Testimonial: "This sounds like a good place to start. Probably the issue but do not know where to look for or find the Neutral Safety Switch."
  • Linda Austin Oct 20, 2013
    where do i find the neutral safety switch? It has no mention of it in the owners manual. Thank you for your suggestions
1988 ford ranger autmatic on floor, wont shift into park.
CHECK LIKAGE CABLE FROM YOUR SHIFTER IT MAY HAVE HAVE GOTTEN BEND SUM WAY
Mar 13, 2011 | 1988 Ford Ranger
Selecting reverse gear on the steering column does not appear to engage. All forward gears normal. Is there an ey fix.
Can you get reverse at all? If not, check you fluid level --when the vehicle is "hot" or at running temp, put into park, pull the dipstick out, wipe it off, reinstall, pull it out again and read the level. If you are good on level, Sounds like reverse pump issue internal to tranny.
Oct 03, 2010 | 1988 Ford Ranger
1988 Ford Ranger 4x4- gear shifter moves into gear, but nothing happens. Truck appears to be in R, D, etc, but when I push the gas pedal the engine revs and the truck doesn't move.
check your lincage to be sure ite actually going into gear you will have to block the tires and have someone shift it from p to 1 then back again, if it does this then check the fluid level but it sounds like your transmission is bad.
Aug 25, 2010 | 1988 Ford Ranger
1988 Ford Ranger truck, new battery and new
Of coarse it does. The battery was probably okey. The Alternator has nothing to do, with starting a vehicle,but the solenoid on the starter does.
Pull the starter and put on a new solenoid.
May 12, 2010 | 1988 Ford Ranger
What is timing gear setting diagram, for a 1988 2.3L ford Ranger
i have yet to figure out how to transfer pictures on my computer, you can go to either the Dayco or gates belt web sight for these pictures.
Feb 28, 2010 | 1988 Ford Ranger
I need wiring diagram for my truck
Try WWW.Crutchfield.com they have all the connectors you need to connect aftermarket units to the factory wiring.
Feb 07, 2010 | 1988 Ford Ranger
Put new tranny in truck the linkage seems to be
Hold the brake pedal down,and try and start the engine in neutral,and drive,and between the gears.You can adjust the gear linkage under the truck ,on the transmission.
Dec 15, 2009 | 1988 Ford Ranger
Grinding when in reverse and tries bogging down at lights
stop shifting so hard. your reverse gear is the same exact gear as your first, so if you shift hard and grind that gear a little then reverse will be harder to get into. you probably need your transmission rebuilt the harder your engine has to work the more its going to bogg down
May 14, 2009 | 1987 Ford Ranger
Headers 70-1118 for 88-89 Ford Ranger, Bronco II, 2.9L, 4WD, exc. column shift Logo
95 people viewed this question
Top Pacesetter Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Pacesetter Vehicle Part and Accessory Expert? Answer questions, earn points and help others
