Question about Tablets & eReaders
Pls help my arc mobile tab700m got too much pattern attempts on my tablet and i can't go to recovery mode..I'm trying to format my tablet so i would be able to use it again
  • jhongx03
    jhongx03 Nov 02, 2013
    It's not Samsung, it's Arc Mobile Tab700m.
1. With the device off, press and hold Volume Up and Power.
2. Release the Power button when you see the Samsung logo, but continue to holdVolume Up until the recovery screen appears.
3. Use the Volume buttons to navigate the menu and select wipe data / factory reset. Press Home to choose the selection.
4. Press Volume Up continue.
The Galaxy Tab should then go through the hard reset process.
Posted on Nov 01, 2013
Testimonial: "It's not Samsung, it's Arc Mobile Tab700m."
  • Anonymous Nov 02, 2013
    Factory reset should be the same for pretty much all android devices.
I need to reset back to Factory spec's how is this done? I done something wrong last night and now is doing a lot of wired things. Can you help me. Don't know a lot about these things
just try formating the mobile/tablet from the recovery mode or what ever based on your mobile brand but unfortunatly after that step you will lose all your data after this move
May 24, 2016 | Tablets & eReaders
TOO MANY PATTERN ATTEMPTS ON SAMSUNG GALAXY GT-P7100
Pattern Lock- Incorrectly enter pattern 5 times (4 or more points each time) . Pop up message will appear Click Next and you will be prompted for google a/c details or security question for pattern lock.
tap forgotten pattern and on next screen enter google account details. Then next screen allows you to choose a new screen lock option.
Otherwise for a factory reset use recovery mode
The only other solution is a hard reset which is only as a last resort. You need to access Androids Recovery mode. Check your manual. Most devices it is power off then power up holding volume + and power buttons.
Once in this mode use power down button to highlight "wipedata/factory reset option, then use power button to select it.
Vol - button to to scroll and select yes delete all user data option with power button. When device reset select option to reboot now and the device will turn on unlocked but you will have lost your personal data.
Aug 07, 2014 | Samsung Galaxy Tab 101 Tablet...
How to unlock Huawei MediaPad 7 Lite locked after "too many patterns attemts" MediaPad, SpringBoard General. ... for this tablet s7-931w
First solution is to use Google account associated with mobile.You need to log in into your Google account and then you can disable or change the pattern lock.
Second solution is to boot into recovery mode and reset the tablet - you will loose all you data however.
The third solution is only for techies and involves using the Android debug bridge to reset the tablet - not for the faint hearted.
May 11, 2014 | Huawei mediapad 7 s7 931w wifi tablet
FORGOTTEN UNLOCK PATTERN
It is quite normal that after providing an unlock pattern to your tablet or mobile, you forget the pattern and attempt unlocking the device multiple times. In this process, many times your device gets permanently locked, and you no longer get any access to it. If you have forgotten your recovery email, you will not be able to unlock the device using that option as well. More.. How Do Unlock My Tablet if Forgot the Unlock Pattern or Recovery Email
Apr 17, 2014 | Tablets & eReaders
Not connected to wifi and too many pattern attempts
Hi, you can try resetting by following the below steps. It works for most tablets.
1 turn off the tablet
2 press and hold the power button and keep tapping the volume down button at the same time.
3 it should take you to recovery screen. Go to factory reset by using volume button and select by using either the center button on the tablet or the power button if there is no center button.
please reply if it helped
Mar 24, 2014 | Digital Reins 9" Inch X2 Android 4.2.2...
Cannot reset pattern to unlock my phone
You can boot into recovery mode by turning off your phone and then press volume down+power key, which should give you a boot menu. Choose reset phone.
Mar 10, 2014 | Android Tablets & eReaders
Help how do hard reset my proscan tablet plt7035 i for got my pattern to unlock it
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Oct 19, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Archos 101 wont turn on
System recovery
If your ARCHOS does not respond correctly or does not start properly, you can try to remedy this situation with a system recovery. Be very careful with this as there are options to erase all the data on your device.
To enter into the Recovery screen
- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
Recovery mode options
No: Cancels the system recovery.
Update firmware: Allows you to connect your device to a computer in order to copy the latest .AOS file (operating system) to your device and then install it.
Repair System
: Attempts to repair the file structure on the internal memory. This does not erase any data.
No: Return to main recovery screen.
Force Touchscreen Calibration:
Select this and then select no to leave the recovery screen. Upon restarting, the ARCHOS will immediately start the touch-screen calibration utility.
Check Disk: Check and repair the system partition if damaged.
Start USB MSC: Allows you to connect your device to a PC to access the internal memory.
Format System: Formats the internal memory. All data (music, photos, videos, etc.), applications and settings are erased. "
copied from the Archos online manual
Jan 24, 2013 | Archos 101 Internet Tablet 16GB 10.1"...
I can't remember my pattern on my androide tablet
pls i have GALAXY ACE i use my gmail as my pattern password but now i can't use to open on my phone .............on my phone it say TOO MANY PATTERN ATTEMPTS
Dec 03, 2012 | MSI Tablets & eReaders
Tablets & eReaders Logo
782 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
