Question about Olympus SZ-10 Digital Camera - Silver
Black shadow on bottom of pictures. The shadow disappears when lens is zoomed in.
  • Kim Hix Oct 21, 2013
    No to both questions.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Olympus Master
  • 102,366 Answers
Are you shooting with flash? Do you have a lens shade attached?
Posted on Oct 21, 2013
Testimonial: "No to both questions."
Canon 1400 IS: When I take a picture using flash of a close up object, a shadow is cast on the lower right corner of the picture. For pictures that are not taken close up with flash, or taken from further...
It's most likely the shadow of the lens. The flash is above and to the left of the lens, so the shadow of the lens will be to the right and below.
Feb 10, 2011 | Cameras
Shadow on bottom of picture when I use a flash and 12 mm lens
Are you using a lens hood? That could create the shadow.
Nov 11, 2009 | Nikon D70s Digital Camera
When taking indoor photos, sometimes i get shadows on different placesof the photo
If you're getting shadows on the bottom center of indoor photos when take with a flash, it is most probably due to the length of the lens on the camera.
A long, telephoto / zoom lenses will create the largest amount of shadow, while shorter and wide angle lenses will be least likely cast shadows. You can reduce the amount of shadow in pictures by removing the lens hood that may be on the end of the lens. The lens hood is to primarily to shield the lens from direct (sun) light, and probably isn't needed for indoor flash photography. Also, rely less on the zoom function of the lens on the camera and physically moving closer to your subject instead. The flash will need to provide much less light output and result in more flashes per battery.
You could use a separate flash - held off the camera so that the lens is not obstructing the light of the on camera flash. Using a Nikon Speed Light, you can set the on camera flash to provide a low output, that would be used primarily to trigger a Nikon Speed Light held by someone or arranged on another surface etc. Youtube is a great source for real life, practical "How To" videos for many operations of the camera and accessories.
I hope this was helpful!
Oct 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
We just bought d90 nikon camera and we found a small half-round shadow at the bottom of the pictures taken when we dont use the zoom lens, how do we correct this?
Are these pictures taken using the built-in flash and with the hood on the lens? If so, you're seeing the shadow of the lens hood.
Remove the lens hood when using the built-in flash.
Sep 17, 2009 | Nikon D90 Digital Camera with 18-105mm...
Picture has a blue shadow
Seems convergence out IC is fried in TV so it gives blue shadow.
Check out Convergence Out IC which you need to replace in TV, if you have enough experience of repair of big TV, necessary tools and know basic electronics.
Dec 18, 2008 | Hitachi 51SWX20B 51" Rear Projection...
Pictures have a round corner shadows when using my wide angle zoom on my camera, what is this ?
Do you have any filters on the lens? If so, you might be seeing the filter rim. (round filter, rectangular picture)
If you're using a DX lens on an FX body, you also might see this.
Aug 13, 2008 | Nikon Cameras
Flashing shadow area on olympus e500
While in playback mode, image is blinking, the word shadow appears in lower right hand corner, use the info button repeatedly until all disappears and image is pure.
Mar 25, 2008 | Olympus EVOLT E-500 Digital Camera
Shadow on image
The camera has a main mirror that you see with the lens off and a sub-mirror underneath the main one. It may be the sub-mirror is not flipping up completely when you take a picture. It could be off its hinges or damaged. Any good camera repairman in your area should be able to confirm this
Dec 26, 2007 | Nikon D80 Digital Camera with 18-135mm...
Black spot on picture
My Nikon was having the same problem with the stationary black spot. I used a can of Dust Off ( the original compressed gas duster). I just removed the lens and held the camera upside down (lens facing the floor) and blew my compressed air inside and my black spot disappeared. Just a thought you might like to know !! Good luck.
Aug 08, 2006 | Casio EXILIM ZOOM EX-Z600 Digital Camera
Shadow on image when using built-in Speedlight
The built-in Speedlight on many Nikon cameras is designed to be a convenient way to either light up a dark subject or to add fill light to a daytime scene. The built-in Speedlight cannot replace a full size, external speedlight which should be used when more power or coverage are needed. Because the built-in Speedlight is compact and close to the camera it cannot be used under all conditions. When using a lens that is physically very long, a subject that is very close, or a wide lens hood it is possible that a shadow may be cast upon the subject. Notice, in the sample below, the round shadow in the bottom center of the photo. When the lens is too long or the coverage is too wide with a close subject a shadow of the lens itself is cast. In figure "A" below the lens is casting a shadow. Switching (or zooming) to a shorter lens (figure "B") prevents the shadow and allows even illumination. If your lens, subject, or lens hood choice create a shadow, an external flash (either on the camera's hot-shoe or connected to the camera by a wire or wirelessly) should be used to fully light the subject.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Olympus SZ-10 Digital Camera - Silver Logo
55 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
