Question about Minolta Photography
Reset factory default ip settings
I purchased a camera and bought new batteries. Now nothing works and nothing shows in the window that is supposed to say, low battery, the shutter speed etc. It blinks the information but doesn't stay on there and I cannot take a picture. I don't know if I locked something. The seller told me to try to set to factory defaults. I have searched every manual and it says to turn to page 115 and there is only 65 pages. Please let me know how to do this. The seller said that it worked. I did go nuts and hit a lot of buttons before learning how to use. I probably locked it out somehow.
    Novelist:
  • Minolta Expert
  • 357 Answers
Model? symptom sounds like low/bad battery
Posted on Oct 23, 2013
Gryfox
  • 216 Answers
SOURCE: shutter jammed
Did you set the camera to M90 AFTER you installed new batteries? The camera will work without batteries in the B and M90 settings, but when you install new batteries, reset the mirror by turning the dial to M90. If this doesn't correct it, I wouldn't recommend opening the camera - take it to a repair shop.
Posted on Nov 24, 2006
SOURCE: T90 shutter
Hi Tim, I had the same problem , I took it to get it repaired & was told that it needed a new shutter solinoid , the repair cost £90 5years ago, you are probably looking at around £140+ today. mine has gone again & I am reluctant to spend that sort of money on it again. If you manage to get it repaired & there are periods of time when you wont be useing it take it out periodicly & just run the shutter a few times, it helps to stop it sticking. Good luck with whatever you decide to do . regards dave.preece@ukonline.co.uk
Posted on Apr 27, 2007
Paul319581
  • 101 Answers
SOURCE: Camera Seems to be Locked Up
Try reseting the Cam !
Posted on Mar 10, 2008
  • 302 Answers
SOURCE: Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Posted on Feb 03, 2010
  • 3287 Answers
SOURCE: om-4ti film advance lever will not advance.
I don't know if this is you first film camera or if you've owned one for years - so pardon some beginner suggestion.
If there's film in the camera, you may have reached the end of the roll. What you're describing sounds very much like this is the case. There is a window to indicate of how many exposures have been taken next to the film advance lever. Most 35mm film manufacturers offer 12, 24 and 36 exposure rolls. Check to see the number shown in the window. If at the end of the roll, you may have advanced the film so far that the number is half in the display and half blocked.
If there is film in the camera and since it will no longer allow any more exposures, you'll need to remove the film. Locate and press the R button next to the film advance lever. Unfold the crank handle from the knob on the top of the left side of the camera (as viewed from behind - in picture taking position). Twist the crank in a clockwise direction (viewed from above) to rewind the film into the film canister. As you get closer to the end of the film, more resistance will be felt until finally, the handle spins freely. This indicates that all the film has been safely rewound and stored in the canister. Next, lift the knob that the crank attached to up and away from the camera body. The back door of the camera should pop open. You can now remove the film from the camera and have prints made from it.
You can get a copy of the manual for your camera here. There is no charge to download it - but a donation is accepted by the person that is making it available.
I hope this helps and good luck! Please rate my reply - thank you.
Posted on Mar 13, 2011
Hello. How can I reset Panasonic Lumix DMC-TZ60 to factory default? (Can I reset software and hardware?) Thank you for answer
Resetting by 'Software'
Resetting to the Factory Default Settings from the interface:
  1. Go to the interface of your camera by typing in the camera's IP address in the browser. Example: http://192.168.1.253/
  2. Click Setup, Maintenance, Default Reset, Reset to default and then click Execute.
Resetting by 'Hardware' Resetting to the Factory Default Settings using the Control button:
  1. Disconnect the 'DC IN' cable from the camera.
  2. Hold down the 'Initial Set' button.
  3. Reconnect the power adapter using the 'DC IN' jack while holding down the 'Initial Set' button. Release the 'Initial Set' button after 5 seconds. (The reset could take up to 180 seconds)
  4. When the 'Status' indicator changes to green, the process is completed and the camera had a Factory Default Reset.
Sep 11, 2016 | Panasonic Cameras
Factory Reset Grandstream GXP 2000 w/o using the menu?
From the Granstream User Manual (Page 44):
Restore Factory Default Setting
WARNING: Restoring the Factory Default Setting will delete all configuration information of the phone.
Please backup or print all the settings before you restoring factory default settings. Grandstream is not
responsible for restoring lost parameters and cannot connect your device to your VoIP service provider.
INSTRUCTIONS FOR RESTORATION:
Step 1: Press "OK" button to bring up the keypad configuration menu, select "Config", press "OK" to
enter submenu, select "Factory Reset" (Please refer to Table 5-1 of keypad flow chart)
Step 2: Enter the MAC address printed on the bottom of the sticker. Please use the following mapping:
0-9: 0-9
A: 22 (press the "2" key twice, "A" will show on the LCD)
B: 222
C: 2222
D: 33 (press the "3" key twice, "D" will show on the LCD)
E: 333
F: 3333
Example: if the MAC address is 000b8200e395, it should be key in as "0002228200333
395".
NOTE: If there are digits like "22" in the MAC, you need to type "2" then press "->" right arrow key to
move the cursor or wait for 4 seconds to continue to key in another "2".
Step 3: Press the "OK" button to move the cursor to "OK". Press "OK" button again to confirm. If the
MAC address is correct, the phone will reboot. Otherwise, it will exit to previous keypad menu interface.
https://www.grandstream.com/products/gxp_series/general/documents/gxp_usermanual_english.pdf
Apr 03, 2014 | Grandstream GXP-2000 IP Phone
Lynsksy E1200 tried to reset. my passord and network name are of no assistance. After running software, router is not found. Tried using "admin" for both but nothing works. Please advise. ...
Reset your router back to it's factory settings by holding the reset button for about 5 seconds. I have provided a list of the most popular router brands. If it does not work you may need to google what your specific model's default IP address/default username/default passwords are, for example search for "Encore ENHWI-2AN3 default IP address" The default login info can change, it can depend on where you obtained your router. If you purchased it yourself from a store then the standard defaults should work. If you obtained your router from your Internet Provider you may need to contact your service provider. It also may depend whether it's an old or new model router as well. And you may need to press and hold the reset button on your router several times before it actually clears. Make sure you have a wired connection then once you have accessed your router simply run the Setup Wizard. Set your SSID as something you'll remember like "Mavericks Network" and your Password can be something like your phone number for example 3109876543
Belkin - Username: Leave the field blank Password: Leave the field blank Default IP address is: 192.168.2.1
Buffalo - Username: root Password: Leave the field blank Default IP address is: 192.168.11.1
D-Link - Username: admin Password: Leave the field blank Default IP address is: 192.168.0.1
Encore - Username: admin Password: admin Default IP address 192.168.1.1
Linksys - Username: admin Password: admin Default IP address 192.168.1.1
NetGear - Username: admin Password: password Default IP address will be: 192.168.0.1 or 192.168.1.1
TP-Link - Username: admin Password: admin Default IP address 192.168.1.1
TrendNet - Username: admin Password: admin Default IP address 192.168.10.1
Zhone - Username: admin Password: admin Default IP address 192.168.1.1
Zyxel - Username: admin Password: 1234 Default IP address 192.168.10.1
Sep 07, 2011 | Computers & Internet
I keep getting the error 323. I forgot my name and pass to the router and i cant get on the internet through 192.168.1.1 because its not admin i changed that to. can u help and tell me what to do. i have...
Sep 07, 2011 | Linksys WRT54G2 Wireless Router
I can't get this website to work. 192.168.0.253. It's supposed to be the website to configure my BL-131 Network Camera. I got the camera a couple of years ago and just now replaced my router. ...
Replacing the router will not have changed any settings in the camera. The IP address 192.168.0.253 is the factory default for the camera, unless you assigned a new one when you set the camera up.
This is a wired/wireless camera, and if you're trying to connect wirelessly you probably have a router setup issue. Like any wireless device, the camera needs to provide the right key to connect. If you haven't set up your new router's wireless security yet, or set it up with a different key than the old one, the camera won't be able to connect. If the camera's not on your network, you won't reach it and you'll have the problem you described.
The simplest thing to do is to start fresh. Reset the camera to factory defaults with its rear-panel reset button. The button is recessed and you'll need a pen or other object to press it for a couple of seconds. Connect the camera to the router using a cable, and you'll be able to reach it again on 192.168.0.253. Set up the wireless network in your router (assign network name, security key, etc.). Then go through the camera wireless setup steps so it can connect to your network and you'll be back in business.
If you need a copy, you can download the manual and find other information here from Panasonic.
May 28, 2011 | Panasonic BL-C131 Network Camera
Purchased refurbished phones and they do not have the Factory Defaulted Admin Password. How to reset the Polycom Soundpoint IP501 to Factory Default Admin Password?!?
The factory Admin info is Polycom for the user and 456 for the password. If the password has been changed, you can do a factory reset by holding down 4 keys until it restarts. The four keys are * 4 6 8.
Apr 01, 2011 | Polycom SoundPoint IP 501 IP Phone
1022n print config is showing IP as 0.0.0.0 set in manual. Cold reset does not go back to factory default. Cannot manage/connect using the default web ip
I had the same problem with this printer. I tried cold resets and flashing the firmware on the printer and still came up with an IP of 0.0.0.0 and the printer still set to manual. Here's what worked for me.
When flashing the firmware the first time, I only had the usb connection from the computer to the printer. After a few other attempts, I tried flashing with the usb cable connected AND the network cable connected from the printer to the wall port. After this the configuration page gave me DHCP and a brand new IP Address.
Here is a working link to the firmware for Windows.
So just simply have the network cable connected while flashing the firmware on the printer, hope this helps.
Jan 06, 2011 | HP LaserJet 1022n Printer
I am trying to set up a new printer to a Linksys router model no WRT300 Ver 2.0. I have lost my IP no and also my Network Security Key, Is there any way to retreive these nos Gordon Stephens
The router can be set to factory default by performing either of these two steps:
Resetting the Router Using the Reset Button
Resetting the Router Using the Web-Based Setup Page
NOTE: Pressing the Reset button on the back of the router for 30 seconds will reset your router to its factory default settings. All of the settings of the router will then be erased and the router's IP address will become 192.168.1.1.
Accessing the Router's Web-Based Setup Page
NOTE:To access the router's web-based setup page using Mac, click here.
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
NOTE: If the IP address of the router has been changed, type the router's IP address in the Address bar instead.
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
NOTE
: This procedure will reset your router to factory defaults. Any settings on the router will be erased. The router's IP address will be "192.168.1.1" and the password will be "admin".
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
Aug 21, 2010 | Linksys Wireless-G WRT54G Router
After taking a picture, screen freezes...
Try this...
Start the camera then go to the menu settings. Either reset all to default or use the various settings to set all to default as much as you can see. Some cameras have a RESET ALL option or button on the outside of the camera. This camera has a "RESET" to set all to default factory settings.
Then test the camera.
If it is still not working, check the card you are using to make sure it is good, or use a new memory card of the correct kind for this camera. This camera can take pictures and movies without any card, although limited amount.
Make sure the batteries are either charged or new of the correct type. One thing with batteries, make sure that in the menu settings you have picked what kind of battery this camera has installed. Most cameras which use double-A will give a choice to set the kind of battery in use. If the wrong battery is chosen, it can cause problems of various kinds.
Read your user manual, if you have one. If you do not, then download one from the following: OlympusAmerica.com Download the manual you want and read it with a pdf reader such as Adobe Reader 8. If you don't have it download and install it from adobe.com.
Oct 25, 2009 | Olympus FE-170 Digital Camera
Photography Logo
55 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
