Question about Lands Phones
BT6510 RESET RINGING THEN NOBODY THERE
My BT6510 phone rings only three times before going on to answer machine,can I change this to six rings
go in to settings and try going in to ringtone and changing the ring tone
Sep 29, 2016 | Lands Phones
I want Caller Display for a BT6510
You request this Service by contacting you Phone / Service provider.
As it's an extra service they provide, but you have to ask for it. OK
Mar 07, 2015 | Lands Phones
TD-1232 PBX - is is a programming issue or hardware issue?
ok so the first thing you should do is to get to where your PB X connects to the lines and ensure that there is a standing voltage on the lines. usually 50 v dc in the uk.
check each line has 50 volts with a multimeter when nthey are not active.
if line 3 has no voltage your problem is the line.
if line 3 does have voltage at 50 v idle ring the lines out 1 then 2 then 3 foir a analogue line to present ringing bthe voltage increases and is in cadence with the ringing. if again the voltage does not increase during the ringing cycle then the problemn is again with the line.
if the line 3 has 50 v idle and increase in voltage during ringing, then the problem is the line interface in the PBX
hope that this helps all above is for analogue lines only
Mar 10, 2017 | Panasonic Kx-td1232 Super Hybrid Pbx...
My two RTX Dual 3088 handsets do not ring when receiving calls (display light comes on and I can answer if I happen to look at my handset right when someone is calling me) and make no beep when I press...
I have exectly the same problem.After surfing the internet i found out that many people experience such bug and nobody has solved the problem by themselves so far.So if somebody knows what to do, please tell us.
Jul 09, 2011 | RTX DUALphone 3088
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
Panasonic kx-tga101s -- problem regarding making conference call - this is very much helpfull. But i have weird problem, i did call 1 person, and then i asked the person to hold and i made the other call....
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones.
Jan 26, 2011 | Panasonic KX-TG2740 Cordless Phone
I want telephone number to be display when there is a call from outside
Well, you need about 3 things for that to happen. Hardware, programming, and a ringing phone. If others in your system have CID or you see CID when you're talking on the phone line, then it's probably just ringing. If nobody gets CID, then did you buy the CID card (part number ending in 93)? Once you get the card, you still have to tell the system that you're using CID.
Carl
Dec 30, 2010 | Panasonic KX-T7633 Corded Phone
My phone does not ring when a call is received
I've found this to be a problem with regular phone lines (POTS) and Uniden phones. Uniden phones do not seem to support 90v @ 20hz ringing voltage / frequency. They work fine in every aspect except for ringing. These phones do work well with voip, where you aren't connected to the telephone company and have calls routed over the internet. The boxes that handle the voip calls generally produce less than 90v and work well w/ Uniden phones.
Dec 18, 2008 | Uniden TRU8885 Digital Answering Machine
Won't stop ringing
Well, I doubt it's the phone but just to make sure, swap phones around and see if the problem stays at the extension or moves with the phone. I am not familiar with the timed reminder feature but that certainly does sound suspicious... Have you used this feature before? Does it make your phone ring? There may be something special you need to do to answer the timed reminder and make it go away. Possibly canceling the timed reminder was too late after it was set off.
Sep 14, 2007 | Panasonic KX-T7730 Corded Phone
Lands Phones Logo
24 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
