Question about Hasbro U-Build Mousetrap
I need playing instructions for u-build mouse trap
    Problem Solver:
  • 11 Answers
Look it up online HASBRO.com
Posted on Nov 08, 2013
How do I install 72219 wireless mouse?
There are no instructions as it is plug-and-play on both PC and Mac. As long as you hook the receiver up to a USB port, and install batteries in the mouse and ensure it is on, it should auto detect and operate.
Mar 02, 2015 | Computers & Internet
Tip
Hello out side world what can be done to stop cd/dvd/game disc from vibrating ,...
1. Insert your index and middle finger into the memory slot holes, place your thumbs on the bottom of the Xbox (for leverage), and pull the face plate off with a steady force. It should come right off. 2. Break the Microsoft seal off. (Note that this will void your warranty.) 3. Now, flip the Xbox on its side and take a close look at the holes located on the top and bottom of each side. If you look closely, you can see that some of the holes are filled in. This is because the filled-in holes are keeping the grey plastic pieces on the top and bottom of the Xbox in place. 4. To remove the top and bottom grey pieces, use a small pointed object. Locate a grey plastic tab by peering into the holes, then use your pointed object to carefully push down and lever out the grey top/bottom cover. Both pieces have three tabs/clips per side, with a total of six per piece. To remove the top grey piece, you will have to remove the rubber pad. This is the only rubber pad you will have to remove. 5. With the grey pieces removed, take a close look at the back side of the Xbox. On the right and left side there are small notches that will require closer inspection. You again will need a small screw driver or narrow probe. 6. Using the probe, start on the left side (near power plug socket) and push the catch a bit into the Xbox until it clicks, then use a screw driver to keep the two sides apart. Once the left side is done, start on the right side and do the same thing to the rest of the catches. 7. Once they are all separated, the bottom of the Xbox will lift away. At this point slide it around to the front side and undo the four catches, keeping the case together. 8. Now grab your Torx driver set. You can use a T10 and T8 to do the job. You do not need a T12. 9. Unscrew the six T10 black screws, then use the T10 to unscrew all the silver screws. Finally, unscrew the black screws with your T8 driver . 10. Carefully flip the Xbox back over and remove the DVD button arm assembly to keep it out of your way. You just need to pry it off the black plastic guide. 11. Next, remove the top cover. Watch the DVD button latch. 12. Disconnect the SATA connector and power connector from the DVD drive and lift it out of the case. 13. To remove the white plastic air guide, locate the notch on the top outward side, insert your probe/small screw driver, and leverage the air guide out. It should lift straight out very smoothly. 14. Disconnect the power for the cooling fans. Now, use your probe/screw driver to pry the fan catches out from the metal guard. This will allow you to remove the fan device from the Xbox case. 15. Look at the front of the Xbox on the RF module, and remove the white plastic power button. It is held in place by a clip on the top and bottom. 16. Remove the three screws from the front circuit board (RF module). 17. Once the screws are removed, you will be able to slide the front circuit board off the Xbox with a slight pull. Notice that it is connected on the lower left side. You should now be able to pull the entire circuit board right out of the case with relative ease. Be careful not to touch any exposed circuits. 18. The next step is to carefully lift the motherboard out of the Xbox case. With the motherboard removed, flip it over and locate the two X connectors on the bottom. These are what hold the heat sinks on the processor. You can remove this; just be careful. It takes a little bit of force, which could destroy your Xbox if not applied properly.
on Jul 12, 2008 | Microsoft Xbox 360 Console
I dont need yahoo becuase i have a twitter
You have made a statement, where questions are normally asked, which indicates either a problem with computers and understanding how they are used, or a problem with language. But, that aside, you would be wrong in that assumption. Twitter is simply a broadcast mechanism. Yahoo Messenger is an instant messaging system, as well as a VOIP (VOice over the internet) system. Of course, there are a range of IM (and VOIP) - everyone is out to build a better mouse trap, just not one that is good at catching other animals.
Apr 05, 2014 | Yahoo Messenger
How do you set up a mouse trap? I lost the instructions...
It really depends on the type of trap you have, but maybe this video will be helpful:
Jan 16, 2013 | Home
Need to change battery, can`t get it open
Up end, should be a tiny little slide button, if I am right? two hands, one slips button while other hand attempts too slide two parts of micky apart? only needs a slight but firm pressure?
Otherwise give to ***** to play with, set trap for another?
Nov 14, 2009 | Logitech MX1000 Laser Cordless...
Lost instructions for mega bloks 'Build n' Play Kitchen'
Try this site, if your product isn't listed in the instructions list, try the requests lists and they should be able to send you the instructions you need after you request it.
http://www.megabrands.com/en/customerservice/servicecenter.php
Jul 21, 2009 | Mega Bloks Toys
Instructions for Mouse Trap game
Is it the new Mousetrap game or the old one?
If it's the old one you can find a PDF file online. For the new one call Hasbro on 01632 278770 and they will email instructions.
Gill
Jun 05, 2009 | Destination Software, Inc. Mouse Trap,...
It does not work
Try all the usb ports. Also you need to restart the computer for it to detect the mouse often. You don't need drivers for a mouse, so it should just simply plug and play.
Apr 12, 2009 | Computers & Internet
GBA games instructions needed!!
hey. the best thing to do is to go onto any browser like google or dogpile and search what problem you are having with each game.
Jan 14, 2009 | Nintendo Video Game Consoles & Games
1025 wireless mouse
no software needed for a mouse ,,should be plug and play....to test it go under control panel and click on mouse u might just need to change it from ur default one.
Sep 13, 2008 | Microsoft Wireless Optical Mouse
Hasbro U-Build Mousetrap Logo
Top Hasbro Toys Experts
thegtw
Spidey28
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
