Question about Kitchen Ranges
Oven wont Ignite
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
4 Suggested Answers
james klgr
  • 362 Answers
SOURCE: Kenmore Gas Range - burners won't ignite
its possible your gas regulator is bad or the gas line to the ignitor is stopped up look at the line and see if some type of food has blocked the outlet
Posted on Dec 08, 2007
garing
  • 998 Answers
SOURCE: Whirlpool GS465 stove top burners won't ignite
adjust air hoods
thumbs up
Posted on Aug 17, 2009
jumptrout51
  • 3361 Answers
SOURCE: Amana gas oven not working
The ignitor may be too weak to open the gas valve. If you have a volt/ohm meter capable of reading AMPS you can hook up to a ignitor wire and turn the oven ON. If you read less than 3.5 amps replace the ignitor. If 3.5 amps or more are read,replace the gas valve.
Posted on Aug 30, 2009
Testimonial: "Thanks for the good info."
GAS OVEN WILL NOT GET HOT
see this instructions and fix it. God bless you
  1. eHow
  2. Home & Garden
  3. Home Appliances
  4. Other Home Appliances
  5. How to Troubleshoot a Gas Range Oven That Won't Heat
By Kefa Olang, eHow Contributor
Although gas range oven may prove useful for cooking and baking, they may fail to ignite if they aren't properly maintained and set up. Lighting a gas range often involves simply turning a knob; however, blockages from food particles and debris caught in the burners, improper burner cap installation and gas supply are common problems that interfere with your gas range oven's performance. A few troubleshooting guidelines may solve these problems safely.
Other People Are Reading
Things You'll Need
  • Toothpick
  • Paperclip
Instructions
    • 1
      Check you have gas in your tank if your gas range oven won't heat. Contact your gas supplier if you've run out of gas.
    • 2
      Clean the burners if you have gas but your burners still won't ignite. To clean the burners, lift the burner caps 9b4f010f-be4f-4db6-8a88-4c3fd17e3339.gif
    • 3
      Inspect the small vertical holes on the side of your burners for dirt, food and debris. The gas won't ignite if they are clogged. Scrape dirt, debris and food from the vertical holes using a pointy object such as a toothpick or paperclip.
    • 4
      Reinstall the burner caps properly. If they are tilted or wobbly, the gas may not ignite. Install the caps on the right burners. Some burners are smaller than others, so match the caps to the appropriate burners.
    • 5
      Move the burner knob to the "Lite" position and wait for the gas to ignite. If it ignites, rotate the knob to your desired setting. If it doesn't ignite, contact a qualified appliance technician.
Jul 18, 2013 | Ovens
Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Dec 27, 2010 | Whirlpool Ovens
Model MGR4452BDB range top burners work but oven
The igiter is bad and needs replaced . The glow bar has a crack and is not getting hot enough to open the oven valve allowing it to ignite.
Nov 01, 2009 | Maytag MGR4452BDW / MGR4452BDQ /...
When the oven is turned on, only 1 burner will ignite and it will sometimes ignite and then go out and then ignite again. THe other burner is not getting gas and does not ignite. I have found the situation...
The problem is almost certainly the glowstick ignitors. There's two for the oven, replace BOTH (about $70 each). I have to replace mine about every year or so for my VGIC365. There's also a third ignitor for the broiler at the top of the oven.
- bill
Oct 20, 2009 | Viking VGIC365-6B Gas Kitchen Range
Oven wont light
Gas or Electric? If Gas at the bottom of oven where Oven burner is there is a glow plug ,or some might call ignitor. When it get a signal to ignite gas that glow plug gets hot and ignites gas. and that does goes Bad .
Oct 10, 2009 | Imperial Commercial Cooking Equipment...
Burners ignite but wont light
Are you on Natural Gas or LP?
If on LP, you may need to change the jets on the burners on top. Most times, when oven and broiler work and top doesn't, and you have spark, your jets are wrong size. Look on back of unit for a cardboard attached to unit, should have jets stuck to cardboard, if notgo to store where you bought unit and buy jets.
Sep 23, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Whirlpool SF377PEGQ 0 ,Gas Oven not igniting...
if you have 120 v to ignitor then ignitor is bad.
Dec 26, 2008 | Kitchen Ranges
Viking VGIC3064BS top burner work but oven won't ignite
Have it fixed under warrenty. If your asking for help here you don't have the skills to DIY.
Dec 26, 2008 | Viking VGSC306-4B Gas Kitchen Range
All burners won't ignite when knob turn to LITE
how lite a eletric gas oven when power lite dont work
Jul 03, 2007 | Whirlpool GLT3014 Gas Cooktop
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
