Question about General Electric WBVH5300KW Washer
Washer starts then stops after about 2 min - General Electric WBVH5300KW Washer
Washer runs great for about 3-4 min than shuts down. Motor runs as long as I do not ingage the nozzle.
Recently I have a similar problem, with a easy solution, just don't push the accelerator nob all the way, leave a 1/4 before reach full power. Apparently some times there is a bad calibration an make the carburetor over flow and lost power.
Sep 11, 2014 | Garden
My maytag dishwasher will run for a short then stop running, I'll push on the door the machine will run again then will stop again
your door is not staying latched.. imagine if it did stay running and the door came completely open, what a mess that would be. so there are safety switches that help stop the washing if the door opens. not too sure how to fix your exact washer.. but the problem is the door not staying closed. maybe you can jamm the door shut while it is running? its not the best answer, but probably the most free way to fix it
Oct 29, 2013 | Dishwashers
Kenmore elite calupso washer starts and runs for 2 min then stops then starts then stops and C1 flashes
The CI and CA error codes indicate that current (amp draw) limits for the drive motor were exceeded. Since you indicate that these codes were displayed even though the washer is not overloaded, it is likely that you have a problem with the motor, motor controller or the universal joint. An item stuck underneath the nutate plate or between the spin basket and the outer tube of the washer could also cause this problem.
Nov 21, 2012 | Kenmore Washing Machines
Calypso washer starts runs for 2 min stops then starts then stops the starts and c1 flashes
The CI and CA error codes indicate that current (amp draw) limits for the drive motor were exceeded. Since you indicate that these codes were displayed even though the washer is not overloaded, it is likely that you have a problem with the motor, motor controller or the universal joint. An item stuck underneath the nut-ate plate or between the spin basket and the outer tube of the washer could also cause this problem.
Nov 21, 2012 | Washing Machines
Iwde12 indesit, not selecting programmes not releasing water, not drying
Hi, I have an indesit IWDE12, I programme the washer which then starts to spin with no water, after 2-3 mins the rinse light, the clock light and the door lock light start to flash and tha washing stops. Does anyone know what this problem could be?
Jun 15, 2010 | Indesit W 123 Front Load Washer
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
General Electric WBVH5300KW Washer Logo
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
