Question about Sharp UX 108 Roll paper Thermal Fax
Fax user manual
What kind of toner or ink for UX175
How to replace in k
Your machine is a laser type fac (not inkjet). It does,t use ink, but toner. To learn how to replace the toner cartridge you should read the User's Guide.
You can download it from here: Brother FAX-2920 User's Guide
manual.
Look for section "Troubleshooting and routine
maintenance" / Replace the Toner Cartridge / How to replace the toner cartridge and Replacing the Drum Unit (pags. 112 and following of the User's Guide).
Oct 02, 2010 | Brother FAX-2920 Plain Paper Laser
Require users manual
Hello
OK, at the l;ink below you will be able to download the manual in PDF format free of charge.
Click HERE to navigate to download page.
Fell free to contact me if you need any further assistance.
Kind regards
Andrea
Sep 25, 2010 | Samsung SF-330 Plain Paper Inkjet Fax
Need instructions on how to set up recieving faxs...and is toner the same as ink ?
Hello
As far as the first question, i always find that the manual explain this situation the best, you will be able to download the manual HERE.
Secondly, toner is not exactly the same as ink. Click HERE to read.
Hope this can steer you in the right direction.
Kind regards
Andrea
Aug 31, 2010 | Brother MFC-5840CN All-In-One InkJet...
Fax machine Samsung Inkjet Fax SF-360. Ink was finished so ordered the correct ink cartridge and replaced it now on the screen it tells us to install ink cartridge. I have tried severeal times and i know...
If the Toner Low/Empty message does not automatically clear when a new cartridge is installed, use the following to clear the message manually:
1.Press MENU # 1 9 3 4. The machine should display TECH.
2.Press MENU, and ENTER. The machine should display TECH Mode.
3.Press the left arrow < once. The machine will show NEW CARTRIDGE.
4.Press ENTER, the machine will show YES.
5.Press ENTER, there should not be any Toner Low/Empty message.
6.Exit TECH MODE, press MENU # 1 9 3 4. The machine will no longer display TECH.
If Toner Low/Empty message continues, there may be a problem with the toner cartridge or the machine.
Jul 21, 2010 | Samsung SF-5100 Plain Paper Laser Fax
Replaced drum and toner and showing need new toner
More than likely, if you look in the users manual, there should be instructions on how to reset the drum and toner count.
Oct 20, 2009 | Brother IntelliFAX 2800 Laser Fax
How to change the ink toner ?
Go to the Brother web site and download the user guide. You'll find all the info you need there.
Sep 13, 2009 | Brother IntelliFax-2820 Laser Fax
Toner alarm stays on with new cartridge
Printhead is dried up and may need to be replaced. The printhead usually has a life kinda like the inks. You should be able to find a printhead from your local fax repair shop and installation should be simple. Once replaced you may install inks and run several cleaning cycles. Please let me know if this helped.
Jan 23, 2009 | Office Equipment & Supplies
Message on fax machine says change printer drum?
You need a toner cartridge which includes the drum. Go to a store like Staples, they will have what you need.
Jan 04, 2009 | Brother IntelliFAX 2600 Fax
Sharp UX 108 Roll paper Thermal Fax Logo
14 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
