Question about JVC Car Audio & Video
When i put it on it corectly why doesn't the music start
Music does not start
    Problem Solver:
  • 16 Answers
Check the audio cords connected correctly and its healthiness. It may be possible the actually music was coming out but not being heard through the audio speakers. If there is any provision for ear-phone, you may check out.
Posted on Oct 20, 2013
My 77 Honda cb400four will not start. It makes a low putting sound when I try the electric start. Kick start doesn't seem to work either.
TRY To Verifie That The Points Are Opening. Points Are Criticle On This Engine.It Has 2 Sets.1Set For 2 Cylinders(1&3) Other Set For 2 Cylinders(2&4). They Are Located Under Chrome Cover On Right Side Of Engine.It Will Help To Drag A Dollar Bill Between The Contacts To Clean Them. Make Sure Gap Is Corect, Should Be Around .018. These Engines Are Very Complicated And Fragile Be Careful With It. If Your Not Sure Dont Mess With It. Its Not A Novice Mechanic Project.The Bike Is Beutiful In The Video. Dont Chance Damaging It.
Apr 10, 2013 | Motorcycles
After the GE JVM1190BY002 Microwave stops its microwave sequence the fan motor above the touchpad just sits and hums but doesn't shut off.It still heats food corectely and it stops humming when I open...
You should first be sure your filters are clean and that your ductwork is clear.
See this link for a bulletin that may address your problem.
Otherwise, see this link in case you have a sticky door switch or relay.
You can find helpful GE exploded views and order GE parts here, and download GE owner's manuals and installation instructions here.
Oct 20, 2011 | Microwave Ovens
I Have a Casio Privia Digital Piano and a Roland DP-10 pedal. The pedal function is inverted. When I press it stops the sustain and the effect comes back when I release the pedal. The pedal does not have...
Yep... Roland pedals are reversed, that is, normally closed contacts. Unlike some Yamaha keyboards, the Casio doesn't have an inversion function available. You have two choices to solve this: 1. Buy a pedal with the corect sense 2. Open the Roland pedal and MAYBE with a soldering iron you can move a wire to select a contact with the opposite sense.
Aug 05, 2011 | Casio Privia Px330 Px-330 88 Key Digital...
Hi, My Samsung YP-U3 has been really great up until now. But now, When I put it into my Computer (USB"s), it doesn't show up on "My Computer" (where it show's C, D, Drive etc) only...
Have you tried booting into safe mode and seeing if the problem persists? If it can be detected in safe mode, then there is a possibility your USB drivers are corrupted, and will need a re-install. To do this, remove all USB devices from ports, disable USB in your Start/Settings/Control panel/System, and reboot. Windows will then detect them at boot, and install the drivers needed to get them back up and running again.
Hope that helped.
Cheers from NZ
May 07, 2011 | Samsung YP-U3 MP3 Player
8985 ibm desktop window xp sound drivers install but some eror hda not found how to install audio drives
First remove the win_xp sound driver u install
restart ur computer
install the corect cd driver of ur sound card it comes w/ the sound card
restart ur computer
check the device manger if ur sound card is corecly installed and adjust the corect settings
play a music
Feb 25, 2011 | Computers & Internet
I recently replaced the clutch cover gasket as well as the center gasket i have put it all back together it cranks up and idols but when i put it into gear the clutch doesnt catch or something because it...
HI THIS IS BECAUSE THE CLUTCH IS NOT RELEASING FULLY, CHECK THE SIMPLE THINGS FIRST, CABLE AND CLUTCH WORM FREE PLAY YOU MUST HAVE AT LEAST 3 MM FREE PLAY AT THE CABLE AND THE WORM TO PUSHROD CLEARENCE SHOULD HAVE SOME PLAY ALSO. IT IS MORE LIKELY THAT THE OUTER CLUTCH PLATE IS NOT FITTED CORECTLY, REMOVE THE CLUTCH COVER WHEN YOU ARE SURE YOU HAVE CHECKED THE ABOVE REMOVE THE CLUTCH COVER AGAIN AND CHECK TO SEE IF WHEN YOU PUSH THE BIKE IN GEAR IF THE CENTRE OF THE CLUTCH ROTATES AND THE OUTER DOESN,T, IF THIS IS THE CASE YOU WILL HAVE TO REMOVE THE OUTER COVER AND SPRINGS AND CHECK IT IS LOCATED CORECTLY, WHEN YOU REFIT IT BEFORE REPLACING THE SPRINGS BOLTS, LOOSLY HOLD THE COVER WITH 1 HAND AND GENTLY PULL THE CLUTCH LEVER WITH THE OTHER, YOU SHOULD HAVE A SMALL AMOUNT OF MOVMENT IN THE LEVER BEFORE YOU FEEL THE PUSHROD &PLATE CONTACT, DID YOU HAVE TO RE ADJUST THE CLUTCH CABEE AFTER YOU REBUILT IT THIS MAY ALSO SUGEST THE OUTER PLATE IS NOT FITTED CORECTLY, CHECK THIS HOPE YOU FIND YOUR PROBLEM, PAUL
Dec 12, 2010 | 2000 Suzuki LS 650 Savage
I want to put some music into my mp3 player and it doesn`t work
well actually you do need a software called iTunes to transfer songs..this happens in some Mp3 players..you can download this software at http://download.cnet.com/1770-20_4-0.html?query=iTunes&tag=srch&searchtype=downloads&filterName=platform%3DWindows&filter=platform%3DWindows..! ok
May 27, 2009 | iLO (2 GB) MP3 Player
A88 phone
return it, best thing to do, made in china! so do not hesitate.
Apr 03, 2008 | Cell Phones
Car Audio & Video Logo
24 people viewed this question
Top JVC Car Audio & Video Experts
Radames Pagan
Radames Pagan
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
