Question about Whirlpool Duet GHW9150P Front Load Washer
Tighten belt on duet whirlpool front loading washer
    Sergeant:
    Champion:
  • 257 Answers
There is no adjustment for the belt of WP front load. If you hear loud noise when the drum is spinning because the drum bearing was loosen. If you have insurance cover tell them to replace. Else, a cost of repair is expensive.
Posted on Oct 22, 2013
aborcass
  • 2651 Answers
SOURCE: washer won't drain Whirlpool Duet GHW9150P Front Load Washer
you can gain acess to the pump cleanout by removing 3 torx 15 screws from along bottom of front panel. justbehind the panel youl find the "bttoun trap. unscrew it and chances are youll find baby socks, bra underwires, etc... )somethings blocking the pump from orkin proerly, be warned scoop water out first, and tip unit back if possible. when oyu unscrew the pump clean out all water above will be coming out
Posted on Mar 12, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool duet front load washer flashes F35 shortly after start
Sud= The unit has sensed there is too many suds in the unit it will flush and pump out for 5 min and restart on its own..This is caused by too much soap use..
From the book :
SUD Code=
If too much detergent was used:
—Run the unit through a Rinse/Spin cycle.
—Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
Posted on Feb 13, 2009
  • 7 Answers
SOURCE: Front load washer fills up with water
Jamesbestor,
The water fill selenoid had junk in it holding the valve open or the seat in the valve is damaged.
Turn off the power and water, remove two screws on the back of the machine and remove the lid.
On the back left top corner are the water fill selenoids. Remove these and disassemble by undoing the 6 or 8 screws ( depending upon model ) holding the unit together. Clean and reassemble, it should take care of the problem. If not, replace the selenoid.
Posted on Feb 15, 2009
SOURCE: Help with Model #GHW9400SU0 Whirlpool Duet Front Load Washer
To unlock the controls
Select and hold END OF CYCLE SIGNAL for 3 seconds until the
CONTROL LOCKED status light turns off.
Posted on May 17, 2010
  • 662 Answers
SOURCE: Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
Posted on May 19, 2010
Fh error code wirpool duet washer
Display shows F20 or FH - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...fh-front-load-...
Whirlpool Home AppliancesQuestion: Display shows F20 or FH - Front-load washer. Answer. Image. or. Image. or. Image. This error code indicates a water supply problem. Are both the hot ...
whirlpool duet error code FH - Appliance Repair Forum
forum.appliancepartspros.com > Appliance Repair Help > Washer Repair
Jan 5, 2009 - 10 posts - ‎1 author
... Repair Help > Washer Repair » whirlpool duet error code FH .... FH No water detected entering machine or Pressure switch trip not detected. Whirlpool Duet diagnostic code C:03 error code FH
1 post
Dec 5, 2014
Whirlpool Duet Washer HF Error Code
Jun 10, 2013
FH Error Code on Whirlpool Duet Washer
Mar 11, 2013
FH error code
Sep 13, 2008
More results from forum.appliancepartspros.com
Stumped on error code FH for Whirlpool Duet front load washer .
Jan 08, 2016 | Washing Machines
Tip
Drive Belt Installation on a Whirlpool Duet or Kenmore Elite Front Loader
This advice is on how to replace the drive belt on Whirlpool Duet and Kenmore Elite front loader washing machines. To replace the drive belt on a Whirlpool Duet washer, follow these steps:
1. Unplug the washer and turn the washing machine around so you can access the back panel. Remove the rear panel by locating and loosening the screws around the perimeter of the panel.
2. Loop the drive belt on the drive motor pulley with the ribbed side on the pulley. Leave a one-groove gap between the belt and the end of the pulley.
3. Take both hands and pull straight up on the belt and place on the drum pulley beginning on the left hand side.
4. Hold the belt firmly in place and slowly turn the drum pulley to the right while holding the belt in place. The belt will eventually align and hold in place on the drum pulley.
NOTE: This may require some effort to get the belt in place.
If you have any questions, or are uncertain if these steps apply to your washer (some newer model Maytag front loaders are now manufactured by Whirlpool) please provide me with a model number and I can let you know if these steps apply. I hope this information is helpful.
on Sep 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Belt keeps coming off
Make sure that none of the pulleys are wobbling, and if they are then you will need to replace. But most likely, you are tightening the belt up tight enough and it wobbles off.
Sometimes, you need a little leverage (prybar) to get it tight enough.
Oct 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Drum will not turn on whirlpool front end load washer when in a cycle, just sits there.
im not competent with the washer you have some use grav forge drive but most are belt driven have a look to see if the belt is broken
Apr 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool duet washer. Drum pulley loose
If the pulley doesn't fit the shaft anymore, it may have sheared a metal key between the shaft and pulley center. If it did, you may have to replace both the key and pulley. If the key is intact and the set-screw is only loose, just tighten the screw and you're home free. Make sure the belt has not been damaged--replace it if so. The belt should be fairly tight when things are back together.
Oct 28, 2009 | Whirlpool GHW9100L Front Load Washer
Whirlpool duet front load washer has standing water inside
take off bottom panel of washer. unscrew front plug to drain pump. clean out
Jun 22, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet model GHW9100LQ1belt slides to back of pulley
DO YOU HAVE THE CORRECT BELT? DO THE GOOVES MATCH THAT PULLEYS? IS UR MOTOR PULLEY ON GOOD? DO YOU HAVE ANY RESTRICTIONS IN UR DRUM /BASKET CAUSING IT NOT TO TURN?
ARE YOU USING HE DETERGENT?
May 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Belt on Whirlpool Duet GHW9200LQ is broken
install belt onto motor pulley first then pull on side of belt onto spinner pulley holding belt onto pulley rotate spinner pulley until belt pulls onto pulley completly
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
70 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
