Question about Hitachi EC510 6-Gallon Oil-Free Pancake Compressor
Motor on ec510 burning up/ sparks ..smells electrical. Less than 2 years old / low to moderate use
My dehumidifier smells like its burning when I turn it on. It is about 5 years old, does this mean I need a new one?
Judy, the fan motor or the compressor motor may be failing. It's cheaper and less of a hassle, to replace a 5 year old unit, than it is to repair it.
Hope this helped you.
Jun 02, 2011 | Whirlpool AD25BSR Dehumidifier
My washer keep shorting out why is this
It may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell.
If the washing machine is old (15 - 20 years) you could have nuisance tripping on aGFCI outlet, however that doesn't mean you get rid of the protection of the outlet, it means you probably should consider replacing the washing machine for a newer model.
Apr 30, 2011 | Washing Machines
Vehicle smelled like burning brake fluid when backing out of a parking space. battery light came on. vehicle acted fine, didnt lose power or anything. tranny is 4 years old, engine is 4 years old. both the...
Is the alternator and/or all accessories turning when the engine is running?One may be seized and the belt is sliding across it producing a burning smell.
Jul 01, 2017 | 1988 Pontiac Grand Prix
Vacuum cleaner makes a burning smell
spark is from brushes not to worry it's normal but you should change the belt
thumbs up
Aug 17, 2009 | Vacuums
My hoover dual v steamvac make loud noise and sparks
Be careful. This could be a shorted wire inside where the motor is. If there is sparks , something is exposed and touching. The motor also may be ready to give out. Unless your daring enough to open the whole thing up I would bring it to a shop or replace it.
Jul 13, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Burning smell when used
No need to oil it. The carbon brush maybe sparking already it is located inside the motor. It is due to damaged Armature or overloaded motor.
May 25, 2009 | Waring BB160 2 Speed Blender
Smells like burned
Since power outages aren't always polite and absolute, your fridge may have been subjected to low line voltages for an extended time and gee, Whirlpool still hasn't figured out how to protect their product from this kind of damage. We lost one the same way years ago in CA; we came home after being gone for hours, smelled the fridge, checked the line voltage which was wandering around 25 volts +- ~2 volts. Enough to burn the compressor windings but not enough to start it.
In that case, the electric company paid for the compressor replacement on our two-year-old Whirlpool. If you can dig up anyone who was noting the line voltage, maybe you can file a claim with your utility.
Sep 23, 2008 | Whirlpool GS6NBEXR Side by Side...
Freezer motor has burning smell
disconnect from mains. take cover off compressor electrics. check starting device - easy to replace
Aug 09, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Burning smell and distorted picture
One of the components in the horizonatl deflection circuit went bad like a capacitor,the price will depend on the actual part that went bad and your location,the service call in NY could be 300.00 but in pittsburgh might only be 150.00.I still belive is wort repairing.
Oct 18, 2006 | Akai PT4799HD Rear Projection Television
Hitachi EC510 6-Gallon Oil-Free Pancake Compressor Logo
87 people viewed this question
Top Hitachi Air Tools & Compressors Experts
John Trevino
Jim Thurston
Are you a Hitachi Air Tool and Compressor Expert? Answer questions, earn points and help others
