Question about Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome...
Leaking from the sprayer nozzle to connection hose
Garden hand pump sprayer not presssurising
There is probably a leak somewhere in the hosing or gasket. As you try to pump it up, take some soapy water and pour it around sealed areas of the sprayer. Look for bubbles as the sprayer leaks air. Also check the nozzle of the sprayer for a clog. Rinse it thoroughly with hot water until it has cleared any blockage.
Feb 22, 2014 | WD-40 Foaming Bike Wash 1L With Sprayer
Window sprayer will not spray onto window for 2003 Mecury sablewhat happened
by using a pin to clear the nozzle all you are doing is pushing the obstruction back into the hose which immediately comes back into the nozzle blocking it again. Take off the hose to the nozzle and use compressed air to blow the obstruction out of the system
Jan 10, 2014 | 2003 Mercury Sable
Sprayer hose leaks at the base of the faucet after sprayer replacement and thread tape application
Make sure the internal washer is intact and there is no damage to the parts that you are connecting together. Also, do not use too much tape....one or two winds is enough and wind in in the direction of the action of the female connector (clockwise) so you don't bunch it up in one spot.
May 05, 2012 | Plumbing
Only one winshied wiper spray works
Check the rubber hoses to the sprayers. If they are on the hood they can come unplugged when you open it. Have a friend work the sprayers as you watch for leaks. An old toothbrush can be used to clean spray nozzles by scrubbing over the hole.
Feb 13, 2011 | 2004 Chevrolet Cavalier
Winshield wipers dont work
To troubleshoot car windshield wiper problems, you need to thoroughly investigate problems with any of its operating parts. Here are some of the things that you need to check to determine why are your car windshield wipers not working.
Check Wiper Motor
The wiper motor is the driving force of the windshield wiper. Feel the motor and listen to a humming sound. If there is no humming, the motor is the problem. Check if the motor is working properly and see to it that its electrical connections are made properly. If you find that the motor is dead and beyond repair, get it replaced immediately.
Check For Break in Connecting Wires
The connecting wires of the motor sometimes go loose and that may cause the windshield wipers to stop working. Also check the battery plug connection which the motor has. Connecting the loose wires properly or fixing/replacing the plug might solve your problem.
Check Wiper Switch
Another wiper assembly part that can malfunction is the wiper switch itself. Check for switch malfunction and if you find that is indeed the problem, get it replaced from a mechanic.
Check for Bent Wiper Arms
Bent wiper arms can cause the operation of the wipers to be hampered. If the wiper arms are bent beyond repair, get them replaced immediately.
Check For Blown Out Car Fuse
A blown up car fuse could be the culprit that has stopped the windshield wipers from working. Check the fuse assembly under the dashboard of the car. Replacing a blown fuse might fix the problem of windshield wipers not working.
Windshield Wiper Sprayers Not Working - Things to Check
Sometimes the windshield wiper sprayer stops working which can be very annoying. The washer mechanism is a self cleaning mechanism for the windshield. Here are some of the things that you need to check in case it is not working.
Check Windshield Washer Motor
The windshield washer mechanism might have been impaired due to the malfunctioning of the wiper washer motor. Check if its working and get it replaced if it is beyond repair.
Check Windshield Washer Fluid Level
Sometimes the washer doesn't work because the washer fluid levels are not filled to requisite levels. Filling in fluid might restore normal functioning.
Check For Broken Washer Hose
The connecting washer hose that connects the reservoir to the nozzle, might be broken or worn out stalling the overall operation. Check the hose for leaks and get it replaced.
Check Washer Nozzle For Clogging
Last thing to check is the nozzle of the washer for clogging. An obstruction in the washer nozzle might be the reason for windshield wiper sprayers not working. Using a pin, clean the clogged nozzle. This might restore the sprayer to the normal working condition.
Jan 05, 2011 | 1999 Mercury Mystique
My widshield wipers dont work and the fuses are fine
Check Wiper Motor
Check Wiper Switch
Jan 03, 2011 | 1992 Honda Accord
Renualt megan wipers not working
Check Wiper Motor
Check Wiper Switch
Dec 25, 2010 | 2006 Renault R5
My wippers stoped working on my way home
Check Wiper Motor
Check Wiper Switch
Dec 10, 2010 | Nissan Altima Cars & Trucks
Herbicide sprayer stopped working
sometimes the tube/straw on the inside of the sprayer where the water comes thru falls off its connection.If you put the end of the hose in the sprayer you may have knocked it off.Depending on sprayer it can be easy or a pain to put back on
Apr 11, 2010 | Chapin Spectracide Sprayer
Immediate pressure loss
your dip tube inside the tank has come loose or has a leak near the top. instead of fluid being pushed up the dip tube into the wand hose the air in the tank is just escaping. You will have to remove the wand hose and figure out where the leak is and fix the dip tube.
Nov 18, 2008 | H.D. Hudson 2g Yard N Garden Sprayer
Danze D403412 Melrose Single Handle Kitchen Faucet with Spray - Chrome... Logo
20 people viewed this question
Top Danze Plumbing Experts
David Wiebe
Level 1 Expert
Donni Steen
john h
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
