Question about Minka Aire Ceiling Fan
How do you connect the wiring of the Minka Aire Concept I and II to existing multi-switch that has a separate function for the light and fan? The unit has just 2 wires (black and white) and the ground, and our previous ceiling fan had a black, white, red, and ground. The red was for fan control and the black was for the light. What do I connect the switch red wire to the Concept I or II fan so that the multi switch fan portion will operate correctly or separately?
    Problem Solver:
  • 16 Answers
I will like to have more details about your multi-switch (circuit diagram/ no. of conneting wires left out with its color/ and its fuction ie function of the multi-switch). The same will be required for you bot types of fans --- old and new one.
Please send it.
Posted on Oct 20, 2013
3 Suggested Answers
mcgyver468
  • 710 Answers
SOURCE: I currently have 2 switches on the wall for a ceiling fan(this was pre-installed when I bought my new home, but my Minka
The red and white should be hot all the time for the fan to run even when the light is not in use. The black and white wires are used for the switch on the wall to turn the light on. Hope this helps.
Posted on Apr 25, 2009
SOURCE: minka aire concept II ceiling fan bulb replacement
The glass dome is tightened firmly in the factory, so removal is difficult. When removal is attempted to, the metal housing to which the dome is attached will spin with it, making removal impossible. To see what I'm talking about, look in the small space between the dome and the bottom of the blade housing - it looks like a metal flange, but this is only the bottom of the reflective metal canister that holds the light. Note that there are 4 "dimples" around the circumference of this housing, facing inward. These dimples are what hold the glass dome in place. The trick is to use a rigid piece of wood or metal about the size of a 12" ruler and place the corner of that ruler in one of those dimples - FIRMLY. Then, a second person can get some leverage on the glass dome and "unscrew" it from the housing (counter-clockwise). The purpose of holding the ruler-sized material against the dimple is to keep the housing from spinning with the dome. This is easier said than done, but it will work.
Posted on Jan 23, 2011
How to bypass a Concept II fan receiver?
SURE you want to do this? A REPLACEMENT Receiver is just $36 bux...
Minka Aire P001021500S Receiver 6 5Uf Dl
[Brand & Part #: Minka Aire P001021500S SKU #: minp001021500s UPC #: 706411042003]
This APPEARS to be your manual:
https://www.1800lighting.com/documentation/Installation/Minka-Aire-Ceiling-Fans/F518.pdf
>>> See Figure 4 <<<
The big question IS ~ how will you switch the fan and lights after your mod?
*** DO THIS AT YOUR OWN RISK! POWER OFF FIRST ~ have a DEPENDABLE/BRIGHT flashlight ready!! ***
MARK BOTH ORANGE WIRES at "both ends" with small strips of masking tape: "1" and "2"... )so you should end up with 4 strips). #1 at the Receiver and then #1 at the fan. #2 at the Receiver and #2 at the fan.
Looking at figure 4 ~ "I" would connect WHITE to WHITE.
Then connect (two) ORANGE + BLUE + BLACK wires together... TWIST them tightly-TIGHTLY together. Now TRY a YELLOW wire nut to bond them all together... if that is not large enough use a RED wire nut.
CAREFULLY strip more insulation jacket ~ if needed... then trim to required EQUAL length.
YOU DO understand this will put your LIGHTS AND FAN into a constant ON condition? And I suspect your FAN will be at high-speed?
Anthony
Dec 20, 2017 | Dryers
Newly installed Minka aire concept II ceiling fan is poorly lit. Installed in my son's bedroom and it's useless, dim.
probably not the reason for the dim light. It probably has more to do with the installation where you have wired the light before or after the fan so that power so the bulb is reduced by the resistance in the fan.
lights and fans are wired in parallel so that one doesn't affect the other
Might pay to talk with an electrician on the issue
There is a limit on the size of the bulb that can be used and a 100 watt halogen bulb will probably melt the surrounds and set fire to the fitting
get a desk lamp for his homework
May 24, 2016 | Minka Concept II Flush 44 Ceiling Fan by...
Can I use an incandescent bulb in a MInka Aire Concept II with light & remote? What is the highest wattage I can use?
Take the bulb to a bulb store & show it to them. They should be able to find a different bulb you can use.
Feb 26, 2015 | Minka Concept II Flush 44 Ceiling Fan by...
Light ON Fan ON. Cannot operately sperately by remote.
Do you have a Fanaway or Minka Aire Concept fan? Anyway it's usually wired this way; Black to black, white to white & red to blue.
Apr 14, 2014 | Minka Concept II Flush 44 Ceiling Fan by...
No light or fan minka concept ii ceiling fan
You need a new receiver or tyr resitting the one you have and see if that works.
Mar 24, 2013 | Minka Concept II Flush 44 Ceiling Fan by...
Light does not work
did you checked the circuit borad..?
or did u see if in the mains any switch is down/off
are u sure the light is not fused..?
Oct 02, 2012 | Minka Concept II Flush 44 Ceiling Fan by...
My Minka Aire conceptII ceiling fan comes with a 100w bulb. where I can buy a brighter bulb?
most well stocked hardware stores will carry bulbs that are larger then 100watts -- or a specialty lighting shop will also have a higher wattage bulbs.
c...
Feb 24, 2011 | Minka Concept II Flush 44 Ceiling Fan by...
Apr 25, 2009 | Minka -Aire Brushed Nickel Remote Control...
Minka Aire Ceiling Fan Logo
217 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
