Question about Polaris Pb4 - 60 Booster Pump
I have a pb-4 booster pool pump,3 wires, 2 black one green where do they connect at in junction box
  • David Spradling
    David Spradling Apr 16, 2016
    that sounds like 220 volt motors come wired for 220 volt on back of motor 1 black wire to L1 2nd black to L2 green to ground or case make sure wiring is correct for 220 volt see side of motor
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 72 Answers
What kind of booster you want? we supply vacuum brake boosters.
check here ,may can help you.
http://www.alibaba.com/product-free/151224928/TOYOTA_HILUX_Power_brake_booster_BBT.html
Posted on Nov 22, 2013
4 Suggested Answers
john224
  • 1378 Answers
SOURCE: POLARIS PB-4 3/4 HP BOOSTER PUMP
A motor can run that hot and still be within the temperature it can handle. It likely has an internal overload device that will shut it off if it exceeds that temperature. If you see something like "thermally protected" on the motor nameplate, you are ok. If it is getting noisy as it runs it may need servicing.
Posted on Jun 14, 2009
john224
  • 1378 Answers
SOURCE: i have two wires 1 black and 1 white the third
One to each line. Be sure you set the motor to the same voltage as the line you are connecting. They are 230V out of the box and your wire colors indicate you are likely connecting the pump to a 115V line.
Posted on Jul 05, 2009
john224
  • 1378 Answers
SOURCE: Installed a new 3/4 hp Polaris pool sweep pump.
Those pumps are dual voltage...Are you certain you connected it correctly for the voltage present? If the motor is set up for 230V (as it usually is when purchased new) and you only feed it 115 volts it will heat up and then act as you are describing. The side of the motor will have a diagram for how to reconnect the motor if necessary.
If connected correctly you would have a voltage issue in the line to the pump (unlikely). Check the voltage present at the motor terminals under load and look for a drop of more than 10%. If this is the case you will likely need an electrician.
Like I said though, it is usually because of wrong voltage setup for the problem you describe.
Posted on Dec 19, 2009
How to wire emerson pool pump to switch box
The green is ground. The other two wires connect to white and black. The motor should come on. IF you take the black wire from the power cord and disconnect it from the motor black wire and install a switch there. You can control it.
Jul 24, 2014 | Emerson Pool & Spa
How do I wire up a A.O. Smith 3/4hp PB4 Booster Pump for 230V operation?
Here's some more info diagrams for you http://www.electricmotorwarehouse.com/aosmith/AO_CONNECT.PDF L1 is one hot wire L2 is the other hot wire. L1 can not be connected to a L2 wire and L2 can not be connected to a L1. Ground only to ground.
May 27, 2014 | AO Smith 1.5 hp Swimming Pool - Jet / Well...
My power supply has 3 wires, red, black and white. Pump wiring diagram has 6 posts for 1 yel w/blk, 2 brown, 4 black, 5 orange white 6 yellow. There is no red. what goes where?
see side of motor check voltage between red and black should be 220 red and white 120 volt black and white 120 volt make sure wiring is still for 220 from factory black to L1 red to L2 white to ground make sure white in box goes to green bus
Aug 01, 2013 | Polaris Booster Pump and Motor 34 HP
Replacing Pool pump motor
Which control panel?
White can be Com, and Black Lo, and Red/Blue Hi
But this is guessing without knowing control panel wiring.
For example T106 timer. Wires can be any color.
http://waterheatertimer.org/images/T-106-control-208-277V-4-40.jpg
High connects to terminal 4
Low connects to terminal 1
Com connects to terminal A
Apr 16, 2013 | Pool & Spa
Wiring a Polaris 280 booster pump motor
if connecting 120 volt see side panel for wiring change from 220 to 120 volt move brown and white wires then black to L1 white to L2 then green to ground or case
Dec 01, 2012 | Polaris Pb4 - 60 Booster Pump
I have a 110 Pool Pump and I am trying to wire it into a Tork1103NC timer. From the pool pump I have a black, white and green wire that I need to wire into the timer. Can you tell me what position those...
Here is Tork 1103 wired for single load.
1) The green pump wire and bare copper wire go to green ground screw
2) Pump black wire goes to pole 2, the NO (normally open) pole
3) Pump white wire goes to unmarked screw
4) Black from circuit breaker goes to pole L
The T1103 comes with a removable brass bar that connects pole L and pole 1
If that removable brass bar is not there, then add a jumper between pole L and pole 1 as shown in diagram above
5) White neutral from breaker box goes to unmarked pole (all whites connect to unmarked pole)
In your case, pole X is not used. Pole X is NC or normally closed > which means the power is ON continuously until timer turns on, and when timer turns ON, the NC pole turns OFF
Oct 11, 2010 | TORK Variable Cycling Timer 8601
Hello, I have 2 black wires coming from the junction box, and a copper ground wire. I connected the green wire to the ground. Where do I connect the red, white, and black wires?
The timer should have red, black,blue and green wires. (no white?) If you have only the two black wires coming from junction box, then connect green to ground like you did. Connect the incoming black (HOT) to the black wire on the timer.connect the outgoing (to the light) to the blue wire on the timer. Cap of with wire nut the red wire. This is for a single pole switch installation (Only switch for the light) If this is for a 3-way control (where you have 2 or more switches) then you use the red.
Aug 05, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Wiring pool pump
Unless you have a 2 speed motor you only need 3 wires. Hot (black), Common (white) and Ground (green). The wiring diagram is on the motor
Jul 30, 2009 | Dynamo ABOVEGROUND POOL PUMP - 3/4HP -
I have two wires 1 black and 1 white the third
Jul 04, 2009 | Polaris Pb4 - 60 Booster Pump
Putting new power cord on dryer i have a 3 cord set up a red wire a black wire and a white wire and dont know which wire to connect to which.
on the back of your dryer.
1.connect the white wire to the center of the junction box.
2.than take the red wire and connect it to the left side of your junction box.
3.than take the black wire and connect it to the right side of the junction box.
If you have a green wire on the cord as well. PLEASE make sure it is connected to the dryers back panel. do not leave it to hang.
Please do not forget to rate and comment about your experience today.
Aug 16, 2008 | Whirlpool Dryers
Polaris Pb4 - 60 Booster Pump Logo
220 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
David Spradling
David Spradling
Michael Vincent Cruz
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
