Question about Onkyo Audio Players & Recorders
There is no sound coming to the speakers but everything else is on
When I first got my phone the alarm was working fine but now it just sounds muffled and I tried everything what can I do to make it louder again?
How does everything else from the speaker sound? If everything else sounds muffled, then there might be an issue with the speaker itself, which isn't readily repairable. If everything else is fine, check and see if the sound is coming out of the correct speaker. I am assuming you've adjusted the alarm volumes and rebooted the device...
Sep 02, 2015 | Cell Phones
My Kenwood KVT-516 has no sound, everything else works on it. Has video, plays cd's, plays radio, switches through everything all normal but doesn't have any sound coming out. Have check all speakers, amp,...
Check to see if you have a speakers A button and a speakers B button. Cycle them both on and off one at a time with something playing. This may turn the speakers back on. In addition you can check to see if you have a second room speakers feature that somehow got turned on- if so turn it off and the sound should come back. In addition you should download the manual and search for these features to show you have to deal with them.
Sep 16, 2014 | Car Audio & Video
My ASUS K50IJ sound comes from only one speaker. I've tryed everything and the balance seems ok
One of the speakers failed or it has a bad connection.Most likely the non working speaker will need to be replaced.
Mar 29, 2013 | ASUS K50IJ-C1 Notebook
Everything coming through my computer speakers sounds high, like elves are speaking. I have insignia speakers.
Try adjusting the equaliser settings in ur system. Then check with ur speaker volume! Also keep the volume in moderate level. That will sound good wen compared to sound at high levels
Jul 31, 2010 | Audio Players & Recorders
No sound from speakers
Check to see if one of the speakers are grounded out, disconnect 1 speaker at a time from the deck and see if the sound comes back on. Itsa protection feature.
Jun 02, 2009 | Xtreme Sound WMS303CS CD Player
Only 2 speakers working
on your computer if you go to
  • start
  • control panel
  • sound and audio devices
  • click on change the speaker settings
  • click advance in speaker settings
  • and change it to 5.1 suround sound
Apr 11, 2009 | Audio Players & Recorders
No sound coming from speakers
just check connectivity to the system, and also check drivers properly installed
Mar 23, 2009 | Audio Players & Recorders
There is no sound coming from my speakers..
Check to see if the speaker s are plugged into the GREEN jack on the back of the computer.
It sounds like it might be plugged into the input jack.
Hope this helps. Bud
Jan 10, 2009 | Dell HK395 Computer Speakers
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
Sound not coming out of the rear or center speakers
Sort of confused a bit I understand you buying a new system you say the sound does not come out the rear and centre speakers does the sound come out of any spearkers other than the two you mention if it is then your wirings are wrong if the sound is not coming out of any speakers then its the sound card BUT you will know this immediately you disconnect that system. The sound would be coming out of the laptop ordinaryly? which is it?
Sep 04, 2007 | Logitech X-530 Computer Speakers
14 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
