Question about Sony KP-53HS10 TV
Hi, I had a problem with my Sony CRT television.
Hi, I had a problem with my Sony CRT television. When I switched it on, the picture got brighter and brighter until it switched itself off and flashed up the error code for over current protect. Also, when the picture was working, there were faint purple lines across the screen (barely visible). So, I took it to be repaired and they told me that the flyback had failed and needed replacing. I've now had the repair done and after a day, it's doing exactly the same thing again. Obviously I'm going to take it back to the repair shop but does anyone have an idea of what the problem is? Thanks
  • James Kimber
    James Kimber Oct 20, 2013
    I'm not sure of the exact model but it's not the one I clicked it seems. It's a 32" CRT
    Scholar:
  • 33 Answers
The faint background lines are vertical flyback lines. Start your diagnosis by turning the brightness and contrast controls to minimum and view the screen in a darkened room. If you can now see a raster with horizontal lines visible then it is likely that the tubes A1 screen voltage is excessive. The screen voltage is usually within the range of 400v to 600v. Adjustment for this is often part of the flyback transformer. Check all high value resistors
in the screen and focus circuitry. Some of these reistors may be
built into the flyback transformer. As the picture gets brighter the beam current increases, this will eventually cause the X ray protection circuits to trigger shuting off the set. A fault in the video drive circuits to the cathodes of the tube will cause similar symptoms but usualy results in a predominance of one colour, ie
bright red, blue or green raster with flyback lines.
Posted on Oct 30, 2013
  • 124 Answers
SOURCE: sony kv-32xbr400
Hi The problem is dry joints on the vertical output ic for sure(commen fault with sony),ime in the uk and 99% of the time i get a call about sony tv its allways switches itself off, caused by dry joints.
Posted on Mar 27, 2006
  • 14 Answers
SOURCE: Sony KV-27S42 Television won't turn on
NO -the tube will be fine . The TV is in 'protect mode' . THis means that it has shutdown because of an internal fault condition. THis TV needs a technician's love..
Posted on Sep 18, 2007
SOURCE: SONY - TRINITRON 26" TV (PICTURE TUBE TYPE)
I have the exact same problem! I'm assuming it's time for a new tv.
Posted on Oct 25, 2007
Coldcut
  • 1554 Answers
SOURCE: GREEN AND PURPLE LINES ACROSS THE SCREEN
This is a symptom of the circuit failing.
it will soon be much worse.
You need a tech.
you can verify it is the tv circuit.
remove cable or input another signal such as dvd
bring up the TV' menu. does it have the lines.
Posted on Jan 26, 2008
  • 4 Answers
SOURCE: Television switching itself off with red light flashing.
Had same problem on a 50inch wega tv. It needed lamp replaced,not hard to replace about $180.00
from Sony.
Posted on May 07, 2009
Blue picture
hi you sony tv have bad picture tube driver right by crt board. good luck!
Sep 04, 2012 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
My SONY KDF-50E3000 turns on but it looks like its weak, color it not bright and I already have it to 100 on the brightest level. Any idea on what it could be ?
Some televisions have a Power Saving Mode; the picture will become brighter if the Powers Saving Mode is turned off.
Some televisions have a Light Sensor; the picture will become brighter or lower depending on room lighting conditions. Turning off the Automatic Brightness Control may increase picture brightness.
Jul 28, 2012 | Televison & Video
Sony kv 27V15: No picture but sound
Hi! the trouble indicates that your television's picture is the culprit, have your unit check by a qualified technician for verification.
Sep 12, 2009 | Sony KV-27V15 27" TV
MY SONY KP41T35 PIC FLASHES ON OFF ON OFF AND GREEN PROJECTOR IS ON BUT NOT SENDING PIC JUST GREEN LIGHT
Sony PTVs do get bad CRTs, to confirm you can pull the front cover and tap on the middle CRT (green) neck with a plastic handle if the green screen flashes back to normal or brighter and causes the TV to shutdown then the CRT is bad. sometimes you can make it stay working for awhile, but eventually the CRT will need replacing. if this doesn't help you can turn the bottom middle control counter clockwise to lower the green .
hope this helps
Eric
Aug 17, 2009 | Sony KP-41T35 41" Rear Projection...
Just wondering when to replace the blulbs on my Toshiba 57H81 CRT
Hello, Im Ismail A, and I would love to help you with your problem. Ok, well you should change your bulb every 2 years.
Jan 12, 2009 | Toshiba 57H81 57" Rear Projection...
Dark picture
pls adjust G2 voltage of picture tube. picture will be brighter.
Jun 14, 2008 | Televison & Video
Won't turn on - comes on and goes right back off
Is the picture good or is it dull and dark?
A dull aka weak picture tube will cause low beam current and blank the screen. Last set I had do this I turned up the screen control to make it brighter. Use caution and don't turn it up too high were you see vertical retrace lines in the picture.
Feb 22, 2008 | Sony KV-27S42 27" TV
Sony kv-32xbr400
Mar 26, 2006 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony KP-53HS10 TV Logo
63 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
