Question about GE PT956CMCC Profile 30" Built-In Double Convection/Thermal Wall Oven - Bisque
Jkp55wov1ww serial no. TM2268800 What does F1 mean
Jkp55wov1ww serial no. TM2268800 What does F1 mean and how can I get a manual
Jkp55wov1ww
You can go to the manufacturer's website, search for your model number and then download a pdf file of the manual if you really need it. F1 usually means you had an interruption in the control panel somewhere, (power failure) and the system board need resetting. When in doubt, turn off the breaker for 5 minutes, then turn it back on. Reset your system clock. That should do it.
Oct 20, 2013 | GE Pk956Drbb Profile 27" Double Electric...
The oven does not work it says turn off when i turn it on and flashes F1 and E1 codes
The E1-F1 error code means per the service manual "safety flip flop" what that means that a internal component of the control board has failed and thusly the control board would need to be replaced
GENE
Oct 25, 2011 | Ovens
F1 error code Kenmore Elite oven I have no owners manual.
Hi.
F1 means defective control module. On manual it will be: "Electronic oven control failure"
From manual:"Replace electronic oven control (also called EOC or clock)."
Try disconnecting power cord or tripping the circuit breaker for a couple of minutes. If the error comes back you will need to replace the oven control module.
Regards.
Ginko
Sep 06, 2011 | Ovens
I had the oven on 350 for 45 min. baking potatoes and then the oven beeped twice and F1 showed up on the screen where it had said 350 so I turned the oven off and the time then showed on the screen. ...
The manual says error code "F1" means a problem occurred in the circuitry and suggests pressing "CLEAR" to reset it. If the problem persists, contact a repair guy.
See page 19: http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257104en.pdf
"This oven is equipped with a state of the art electronic oven control. Among its many features is a full time oven circuit diagnostics system. The control constantly monitors its internal circuitry as well as several crucial oven circuits to insure they are all operating correctly. If at any time one of these systems fails, the control will immediately stop operation, and beep continuously (flashing an error code of F1, F3 or F9 in the display window, if equipped). Electronic control has detected a fault condition. Press CLEAR to clear the display and stop the beeping. Reprogram oven. If fault recurs, record fault number, press CLEAR and contact an authorized servicer."
Mar 14, 2011 | Ovens
LCD displays trouble code F1 alternating with F7. Serial # is MEW6627BAB
Hi
Thanks for using FixYa. Error F1 in your Maytag Electric Double oven means that the control panel has gone bad and to resolve this issue it should be replaced. Unfortunately there is no other way it can be resolved. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 25, 2010 | Maytag MEW6627B Electric Double Oven
Moved into this house. Has no manual on Kenmore glass top stove, on how to use self cleaning oven. Looking for manual or directions on how to use it. Only have model # 790.96011400 and serial # VF50635079
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Apr 13, 2010 | Ovens
Our Fridigaire range oven will not shut off. In
F1 is a bad oven control. (clock).
It must be replaced.
Unplug the range.
Remove the screws from the rear panel.
Remove the wires from the (clock).
Replace the EOC (clock) with a new control and bake me some cookies.
Feb 02, 2010 | Frigidaire Ovens
It shows a code F1
It means the worse. It is the watchdog circuit (tells what the ovens doing at the time) in the ERC (Electronic Range Control) which is the circuit board. It calls to replace both the circuit board and the touchpad. You're looking at about 100 -150 bucks. Sorry.
Jan 28, 2008 | Ovens
GE PT956CMCC Profile 30" Built-In Double Convection/Thermal Wall Oven - Bisque Logo
22 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
