Question about GE Pk956Drbb Profile 27" Double Electric Wall Oven With 3.8 Cu. Ft. Pr
Jkp55wov1ww What does F1 mean? I do not have the owner's manual
  • 54 Answers
You can go to the manufacturer's website, search for your model number and then download a pdf file of the manual if you really need it. F1 usually means you had an interruption in the control panel somewhere, (power failure) and the system board need resetting. When in doubt, turn off the breaker for 5 minutes, then turn it back on. Reset your system clock. That should do it.
Posted on Nov 23, 2013
What does E2 -F 1- mean?
It helps to know make and model in such questions.
Whirlpool Oven...what does E2 F1 mean on the clock/control panel ...
https://www.shopyourway.com/questions/1183452
Aug 27, 2012 - The "E1 F1" fault code indicates an Electronic control board malfunction. This means that the control board will need to replaced. I'm not able to provide a part number because there was not a model number submitted.I added an image of from the technical data sheet in reference to the "E1-F1" fault code. Whirlpool Gold Oven Error Code F1 E2
25 Jun 2013
Whirlpool Oven (GBS307PDQ0) Fault Code E3 (amber ...
17 Sep 2012
What does error code F1 mean on my Whirlpool ...
1 answer
14 May 2010
What does E2 F1 mean on a Kenmore electric range ...
1 answer
25 Mar 2009
More results from www.shopyourway.com
Whirlpool Oven...what does E2 F1 mean on the ... - Shop Your Way
https://www.shopyourway.com/m/questions/1183452 Aug 28, 2012 - Control panel for Whirlpool Gold double oven. 2 answers. whirlpool range, clock/oven control goes into alarm. 4 answers. Whirlpool Gold Oven Error Code F1 E2.
Whirlpool Gold Oven Error Code F1 E2 ' Shop Your Way: Online ...
https://www.shopyourway.com/m/questions/1218462 The F1 E2 error code indicates an oven control failure. Try disconnecting power to the range for 20-30 minutes, then restore the power. If this does not help, I suspect that the oven control will need to be replaced.
Whirlpool Appliance Fault Codes ' PartSelect.com
https://www.partselect.com/JustForFun/Whirlpool-Appliance-Fault-Codes.aspx Whirpool Oven/Range/Stove Fault Codes (Including 2 and 4 digit codes). Note: Depending upon the brand of appliance, there can be many different names for the 'clock' component. Electronic Range Control, ERC, Electronic Oven Control, EOC, control board, and clock all refer to the same part. 4 Digit Fault Codes. F1-E0 ...
Mar 24, 2018 | Whirlpool Ovens
The ove has a code of F1 and the light is on for LOCK. How do I correct the code and unlock?
Hello, Pamela -
I can only think you do not have the owner's manual for your oven. The F1 error code and what it means will be listed in the oven owner's manual in the Troubleshooting section.
If you wish, you can add the make and model of your oven by choosing Comment and typing that information in the Comment box, so I or someone else volunteering to answer on Fixya.com can provide information for just your make and model of stove.
One thing you can try now, if it is an electric oven, is to turn all the power off to the oven by switching the oven circuit breaker off, waiting one full minute, and switching the circuit breaker back on. That may reset the oven and eliminate the F1 error and unlock the oven door.
Best wishes.
Feb 27, 2018 | Ovens
The oven does not work it says turn off when i turn it on and flashes F1 and E1 codes
The E1-F1 error code means per the service manual "safety flip flop" what that means that a internal component of the control board has failed and thusly the control board would need to be replaced
GENE
Oct 25, 2011 | Ovens
Model 9114803590 Double Wall Oven displaying F1, lost manual.
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced .
The part number for the touchpad incase its needed is For the white color....WB27K5111 for the on thats black....WB27K5112 GENE
Sep 17, 2011 | Kenmore Ovens
F1 error code Kenmore Elite oven I have no owners manual.
Hi.
F1 means defective control module. On manual it will be: "Electronic oven control failure"
From manual:"Replace electronic oven control (also called EOC or clock)."
Try disconnecting power cord or tripping the circuit breaker for a couple of minutes. If the error comes back you will need to replace the oven control module.
Regards.
Ginko
Sep 06, 2011 | Ovens
F1 alarm started last night. Turned off circuit breaker overnight, tried today and still continues to alarm. Repairman wants $76 dollars to walk in the door. Please help
Hi.
The error meaning depends on the oven brand.
On Amana and other brands F1 is a faulty control pad or faulty electronic control.
That may be your case , since the electronic control looks being jammed.
Try tripping the circuit breaker for two minutes (or disconnect power cord). If that does not help, then call the manufacturer at the number listed on the owners manual.
Note: on other brands F1 indicates incorrect temperature , and is associated with a faulty temperature sensor. This normally does not cause the electronic control beeping and not responding.
Nov 15, 2010 | Amana AOES3030 Electric Single Oven
Oven is giving a F1 code and is not working . It beeps even when it is not given a program.
Hi.
Regards.
Mar 02, 2010 | Ovens
GE Pk956Drbb Profile 27" Double Electric Wall Oven With 3.8 Cu. Ft. Pr Logo
76 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
