Question about Samsung Dryers
Samsung Dryer only 16 months old. Making a terrible loud noise. We had a repair man out who said the seal around the motor was weak and about to tear making the motor rub against the drum. He said to replace the motor it will cost 389 (this is after the $150 service call just to come out!). REALLY??? It is just out of warranty and this is happening? Anyone else with this issue?
  • Samsung Master
  • 2,694 Answers
Without being there to see this it's hard for me to say what's happening but if the drum is somehow hitting or rubbing down on the motor the drum had to have dropped maybe from a bad roller or something like that,the motor is screwed to the floor of the dryer so if the drum is somehow down that low i would say the drum has dropped down somehow.if you send the model number it would help but like i say if you had a tech out there he could be right but i've never heard of this.
Posted on Oct 20, 2013
4 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: dryer makes squeaking noise
If it has not been squeaking for an extended time you can get by with just changing the rear drum sleeve bearing (WE3X75). To do this, open dryer door, remove screws going up into top, allowing top to swing up and back. Remove screw holding front panel to side panel near top just under where the top was. Tilt front panel forward and lift off bottom pegs. Swing to side (you don't have to remove wires). Pull drum forward about 6 inches. (you don't even have to remove the belt.) Change sleeve at center back of drum. Make sure to inspect the front drum support slides WE1M481dark ones and WE1M333 white ones (about 1/2 inch x 2.5 inch strips at the top of the front panel which support the front of the drum), as about the time the rear bearing goes, these may be wearing also, especially the one on the left side.
Posted on Nov 18, 2008
onthejob5130
  • 640 Answers
SOURCE: Lady Kenmore Dryer Making Loud Screeching Noise When Drum Turns
defective rollers..replace
Posted on Jan 29, 2009
pumpkinman
  • 1147 Answers
SOURCE: Ge Dryer making loud rumbling noise
drum bearings are going up
Posted on Jun 19, 2009
Loud Noise when dryer is running.
Don't run the dryer until it is repaired iot will damage a lot of other things if you do. depending on the make and model . most are repaired through the front of the dryer the top comes up and front panel pulls off the blower is screwed onto the motoir shaft some are clockwise and some counterclock wise most are counter. always unplug before working on
Dec 01, 2013 | Whirlpool LEW0050P Electric Dryer
Refrig making noiise
Ask them cover deforst heater
Aug 09, 2017 | Samsung Refrigerators
My dryer started making a loud noise - Amana model alg443raw - then I opened the door and the felt seal and a metal piece were inside and wrapped around my clothes. I know what the felt seal is, but what...
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
fsgfgf
Sep 25, 2010 | Amana ALG443RAW Gas Dryer
My Maytag dryer model # LDE7314ACE has been making a terrible noise. We think the belt is breaking. We have waited for a few months and now it is making an even louder noise. How can you get into this...
go to sears.com, click on parts and service upper right corner, click on parts, enter your model number it will list a parts breakdown/schematic this wy u can determine whhich parts are removable and how its put togetherr and also get part numbers and prices, shop around though prices might seem low but they get you on the shipping check any local appliances stores if any are avaialbe in your area....
I persoanlly would check the belt, the rollers, or an idler pulley,, also maybe any glides or seals if your model has any........replace any defective parts you find hope this helps good day let me know whut u find
Feb 02, 2010 | Maytag PYE2300AY Electric Dryer
LG DLE2516W Dryer suddenly making loud vibrating noise
Until you know how serious a problem you have, I'd advise against continued use. If you are in the USA, go to http://www.lge.com/us/support/repair/support-repair-provider-lookup.jsp
to find a service provider for in warranty service, or call LG USA at 800-243-0000.
Aug 18, 2009 | LG DLE2516 Electric Dryer
Pool filter making a loud noise
The sound you are hearing is most likely rust forming on the inside of the motor. It tends to happen when a pump seal starts to fail. Water travels up the spining shaft from behind the impeller into the motor. The high pitch is a direct result.
Solution. Replace the pump seal, and find a motor repair shop/ Pool pump repair shop to take a look at the motor. Have them check the brushes and bearings. Once clean of rust the motor should be quiet once again.
Jan 25, 2009 | Harmsco Pool and Spa Cartridge for Filter...
Loud Noise
heatman101
879dgyj
Dec 18, 2008 | LG DLE5932W Electric Dryer
Dishwasher Making Loud High Pitched Noise.
debris caught iside pump assy is what it sounds like
Feb 24, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Dryer making very loud noise.
We had the exact same noise all of a sudden start coming from our 2 year old dryer. We checked everything, rollers, pulleys, motors, etc. I was certain it was coming from the upper left. Finally we found a loose screw had fallen into the front felt ring. Problem solved!
Good luck.
Jan 20, 2008 | Kenmore 63942 Dryer
Dryers Logo
131 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
