Question about Dryers
Ler7620lw0 noise when running
  • Dryers Master
  • 2,696 Answers
Your lint filter is on top so unplug it,remove the lint filter and the two screws on top in front of the filter,get a screw driver,stick in into the space where the top and front meet around two iches from each corner and lift up,pop the top up,on the right side you'll see the door switch harness,get a small screw driver,stick into the harness to separate it,pull it apart and then look at the right and left side a few inches down and you'll see a 5/16 inch screw one on each side,remove them and pull up on the front panel,,pull up first on right side then left side.now reach in on the right side,stick your head inside the drum and lift the drum with right shoulder,pull up on the belt pulley and remove the belt,first look at how the belt connects to the motor so when you reinstall it you know how it goes.now lift the top and pull the drum.there's a kit that comes with the belt rollers and new pulley,change out these parts and your noise should be gone,also while you're in there vac up all the lint,put the dryer back together but don't reinstall the two screws on top,pull out the dryer and remove the vent line and back wall,on the left side remove the four screws that hold the metal duct in place,clean out the duct and vac up any lint,put that back together and the two screws on top,if the vent line is long,i use a leaf blower to blow out the vent line,if you clean out the dryer once a year and the vent line you'll hardly have any problems with this dryer,.watch this video and good luck,if you need any other help with any appliance let me know and hopefully we can get it done.
Posted on Oct 20, 2013
The fridge make weird noises some days. Cooling is good, freezer also works well. My concern is if those noises are prelude to a major damage.
This really depends on the type of noise. If you hear a gurgle type noise while running this is usually normal from the refrigerant pumping through the tubing. Fan type noise blowing air in the freezer section is also normal but if it sounds link the fan is rubbing or grinding you need to look into that noise. Also a similar fan down near the compressor area in the lower back section. A low hum from the compressor while running is normal. If you have and icemaker--water running noise about once per hour for around 10 seconds is all normal while the icemaker is filling. Dropping noise from the cubes falling into the bucket is also normal about once per hour. Hope this helps.
Jun 10, 2015 | Refrigerators
Refrigerator noise
cause of this problem is grated shaft bush of compressor. replace compressor
Mar 14, 2014 | Home
My 2004 trailbazer makes a knocking noise whan started, it gets quieter as ou drive it, but does not go away
Hello
Any knocking noise is more than likely due to worn connecting rod bearings, Crankshaft main bearings or piston or piston pin noise. Connecting rod bearing knocks and piston related noise quite some with warm up, piston noise tends to go completely away after about 5 minutes of run time, but there are exceptions to that run like a cracked piston skirt, crankshaft bearings don't quite very much. It would be my best quests without hearing the noise that you may have either a connecting rod or piston related noise. The best thing to do here is have a trained ear listen to the noise, any experienced technician will know very quickly what the noise is and where it is coming from. These types of noises are only common on high miles engines, with at least 100,000 miles on them is the general run or the engine has been run very low on oil repeated times, or the oil not changed at regular intervals or the engine has been severely overheated. My experience? 35 years as a dealer technican. I'm Master certified in all phases of auto and light truck repair.
Jul 03, 2011 | 2004 Chevrolet TrailBlazer
LER7620LW0 dryer does nothing...........worked fine on last load.........door switch makes clicking noise...........what should i try next
If the dryer is doing nothing at all, sounds like you lost power to it or the door switch has failed even if you hear a clicking sound. Check to see if you have power at the outlet where the dryer is plugged in. Use a hair dryer or other portable device. If there is no power there, check the circuit breaker for that outlet. It may have tripped.
Please vote or leave a comment.
Mr Tin Man
Nov 28, 2010 | Dryers
The dryer turns on an spins but does not heat up.
Hello. Sorry for your trouble. On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.) Joe
Jun 12, 2010 | Dryers
Dryer makes clicking noise when running
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
w56w
Jan 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
When running load noise coming from black cylinder
That part you identified is the compressor of the dehumidifier. Compressor is probably bad or going bad. When compressor go bad the valves start making noise and they lose alot of there efficiency.
Dec 10, 2009 | LG LHD65EBL Dehumidifier
I have a wirlpool dryer mod#LER7620LW0 the elements heat but the motor will not turn seems to turn freely by hand is it the motor or is their a start relay somewhere
maybe a broken belt, or the motor is locked put but i recommend you looking for the belt and then turn the motor by hand.
Jun 05, 2009 | Whirlpool Dryers
Dryers Logo
Top Dryers Experts
