Question about Intel Computers & Internet
I have Intel Centrino Advanced N6250. My Windows 7 PC shut down in the middle of updates and now my wireless adapter is not connecting. I've disabled and enabled several times and it still gives me the big red X with "no connections are available." When I click on the Troubleshooting option it tells me it couldn't identify the problem. What am I missing? I'd prefer to not uninstall as. I don't have the DVD with me as I'm traveling. HELP PLEASE!!!!!!!
  • 85 Answers
Delete the current driver and reinstall driver.
Posted on Oct 22, 2013
tom19511
  • 1601 Answers
SOURCE: Wireless network connection
Try these first:
Make sure that the wep password is correct.
change channels to 1-6-or 11.
check is to make sure you are NOT using "IEEE 802.1x authentication for this network."
You can find at setting under "Wireless Network Connection Properties" and then under "Authentication" tab of your network properties.
This particular authentication method is periodically logging you off the network and re-authenticating.
Check the adapter in device manager to make sure that windows is not shutting the adapter down to save power.
Cordless phones1.gif and wireless ethernet cards use overlapping frequencies.As a test, you can unplug the AC cords from all the cordless phones in the area and see if it helps.
Posted on Feb 18, 2008
Tom Marvolo
  • 708 Answers
SOURCE: Windows 7 driver update for Belkin F5D9050
Im Not sure this will Work
But in most Cases it will So I think its Worth a try
You will need to find the version of the Adapter
And After that Goto www.belkin.com/support
On the top right hand side on the search type F5D9050
On the results select the Link that has the Drivers
Download the Driver for the version of your Adapter
Right click on the downloaded file and select Properties
Click on the compatibility tab
Select Run this Program in compatibility mode for Windows Vista SP1
Click Apply
Now install the Drivers
Posted on Jan 12, 2010
Testimonial: "It´s working fine now, thanks!"
SOURCE: problems with WiFi netgear WNDA3100
the drivers should be installed in windows 7 by default, their so called "smart wizard" has some compatibility issues with windows 7, I get it to load up and it will shut down or glitch out. What I did was uninstall the downloaded driver and use the default windows drivers, flipped the switch off to my built in G wifi adapter and the netgear automatically kicked in and took over as the default wireless adapter.
Posted on Feb 11, 2010
puertobori
  • 7733 Answers
SOURCE: I bought AE1000 wireless N
When you insert the setup disk on your computer, you can exit from the setup and then connect the adapter to the computer and a new window will popup "Found New Hardware Wizzard" and in that select the option "Install the drivers Automatically" and click on next, so it will automatically search for the drivers and install it on your computer... Once the drivers are installed on your computer then you can try to connect to your wireless network.
Setup
The Linksys AE1000 Wireless USB Adapter helps you connect your computer to a wireless network for quick Internet access. Installing the Linksys AE1000 is fairly easy. Just follow the steps below in setting up the Linksys AE1000 on your computer or laptop.
Minimum system requirements
- A computer with 1 GHz or faster processor.
- 512MB or more RAM.
- An available USB port.
NOTE: The Linksys AE1000 is supported for Windows 7, Vista SP1 and XP SP3 but NOT for Mac.
Step 1:
Insert the Setup CD into your CD-ROM drive.
Step 2:
Click Set up your Linksys Adapter. Proceed to Step 4.
If you do not see this, click Start on your computer and click Computer. Double-click on your CD-ROM drive. Continue to Step 3.
NOTE: For Windows XP, the file may be known as Setup.exe.
Step 3:
Read the License Agreement and click Next.
Step 4:
Insert the Wireless USB Adapter into a USB port on your computer or laptop.
Alternatively, you can also use the USB Extension Base to connect the Wireless USB Adapter. Plug the Wireless USB Adapter into the USB Extension Base and connect the Base to a USB port on your computer or laptop.
Step 5:
If you have an Easy Setup key, select Yes, I have an Easy Setup Key and click Next. Proceed to Step 8.
Otherwise, select No, I don't have an Easy Setup Key and click Next. Proceed to Step 6.
NOTE: For more information on Easy Setup Key, click here.
Step 6:
Select your wireless network and click Next.
Step 7:
If prompted, enter the wireless password for your network. Proceed to Step 10.
Step 8:
Follow the on-screen instructions. Click Next once you have completed the on-screen instructions.
Step 9:
The installation is complete when you see the screen below. Click OK.
Step 10:
You are directed to the Cisco Connect screen. Click Close to exit.
Posted on Nov 04, 2010
SOURCE: I have Belkin's Play Wireless
I don't think it's a belkin issue I have the same one and I did buy another type and ended up taking it back because it wouldn't even pick up a signal whereupon I was told windows updates messes with them to which I thought er right but as it turns out it my belkin played up si I restored to before a critical update and hey it works again.
Posted on Jul 16, 2011
Fix wifi association problem
(a) Ensure the Wireless Device Switch is On. Just throwing that out there. Your WiFi adapter is noting down some kind of signal strength as well, yes?
(b) Try uninstalling the WiFi Adapter (Intel Centrino Advanced-N 6205 (802.11abgn 2x2), or, Atheros XSPAN HB116 802.11abgn) in Device Manager, then rebooting and let Windows reinstall the device.
(c) Try updating the drivers from here.
http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADS There are Windows 8.1 x86 and x64 driver packages there.
(d) If the device is working fine (according to Windows) but is still not receiving or sending, then it may be some antenna problem, and you'll have to contact Fujitsu Support for repair. Make sure you've registered your new tablet with Fujitsu.
Post back with how this goes.
Jan 04, 2014 | Fujitsu STYLISTIC Q702 11.6"" Tablet PC -...
Can't connect to Thomson TG 712 router Intel Centrino Advanced-N 6205
Reset the router to factory. Also, be sure there are no IP address conflicts on your network. It might be that one of your routers already is using an address. DO you have multiple routers on your network?
Jan 22, 2018 | Dell Alienware M14x Notebook
Problems with WiFi netgear WNDA3100
Nov 06, 2009 | NetGear RangeMax Dual-Band Wireless-N USB...
Hp530 notebook w/intel centrino.WLAN shuts off
do a power drain . Then update the wireless drivers and a bios update .
Oct 20, 2009 | Computers & Internet
Every time I connect to an older netgear router with my brand new Sony Vaio laptop (downgraded to XP) the router ''crashes'' and denies service to any other device in the house. I have already added the...
I have a similar problem with my laptop which also has an Intel wireless card. The only way I can get a stable connection to my Linksys router is by disabling the Intel utility and letting Windows manage the wireless connections. Open up the Intel utility and press the Fn10 key to disable the Intel utility or from the menu select Advanced and than select disable Wifi Control. You will find you wireless connections to be stabler and faster when you do this, you should also check to see if there is a driver update on Sony or Intel's site for your wireless card. I have had my laptop for three months and there have been four updates so far. Face it, Intel makes crappy network adapters and should stick to processors.
Jul 06, 2009 | Sony Computers & Internet
PC shuts down when accessing wireless network
Check in Device Manager to see if there is a problem with the Wireless Network Adapter. If you see a Yellow! or a RedX, then right-click on the network adapter see what the status of it is. It has a troubleshooting section. The only part of your wireless adapter that could possibly shut down the computer would be the driver.
Dec 27, 2008 | Motion Computing M1400 CENTRINO 1.1G 512...
Computers & Internet Logo
46 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
