Question about John Deere Garden
I have a Scotts 20 HP 48" deck. starts fine, runs fine but bogs down in thicker grass. This is not overly thick grass nor above 4 inches high. It also seems that the speed of the tractor is not great..
  • 36 Answers
Do you have your throttle all the way up? And if so you might want to check if maybe your throttle cable might be stuck on something preventing it from rasing the throttle.
Posted on Oct 20, 2013
4 Suggested Answers
SOURCE: Airens Zoom 1944 ZTR Blades Slow Down In Bahaia Grass
You mention many PM issues but do not mention a blade sharpening. I don't get on my ZTR without a freshly honed blade installed. "That's" what cuts bahia grass...the blade. You can put all the horsepower you want behind the lade but if you're trying to cut grass with a 2X4 it rips more than cuts grass.
Posted on Oct 21, 2009
  • 8404 Answers
SOURCE: I have a troy bilt 42 inch 17 hp lawn tractor. The
One or more of your drive belts is in need of adjustment or replacement, maybe. Possibly, your electric (or manual) PTO clutch could also be adjusted. You do have the spring tensioner on the deck engaged, right? You say the engine doesn't bog when this happens so I am inclined to think "clutch" and/or "PTO belt" to the deck and/or the "deck tensioner" are the things to check.
The tensioner will be the easiest, it is a handle on the left side ON the deck. Has a BIG spring on it. Make sure it is engaged.
Is yours a Troy Bilt manufactured in Troy New York or is it another manufacturer (MTD?). Troy Bilt is actually out of business, having sold the Troy name to a variety of makers depending on the model line. I don't have the run down on who makes what any more (tillers, chippers, mowers, blowers, trimmers, etc.), but Troy Bilt of Troy, NY is no more. :-(
I have a 16 HP Troy with 42 inch deck driven through a electric clutch. I also have a "grass pump" on my deck. Important maintenance tips: Keep the bearings greased, keep the deck clean underneath. The belt on the deck should have the tensioner released when you are NOT mowing. Keep the blades sharp and in good repair. Mow with engine at full speed. When you get to areas of heavy growth, slow the tractor down (hydro drive) or reduce to a lower gear (gear drive). NEVER adjust speed using the "clutch" (hydro drive or gear drive). When you engage the blades (electric or manual) always have the engine just above idle, bring the engine speed up slowly to preserve the belts and reduce stress on all components.
I am sure this is the fix for your trouble. If there is anything else or if I missed the ball, please let me know and we will go further.
Thanks for your question @ FixYa.com
Posted on May 30, 2011
  • 6468 Answers
SOURCE: my john deere L130 with hydrostat won't drive,eng is fine
did you knock the drive belt off?did you pull the lever that allows you to push it when not running?
Posted on Aug 17, 2012
I have a cub cadet zero turn, runs fine but when I engage the blades on grass it bogs down and won't go fast at all.
problem can be caused by dirty fuel (jets in carby blocked) need to clean carby or even put a kit through it.
Sep 13, 2013 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Engine boggs down in thick grass
are the blades sharp?hows the fuel and air filters?is the gas newer than 30 days?when was the last time the oil was changed?
Aug 15, 2012 | Craftsman 24 Hp 48" Deck Yard Tractor
I have a troy bilt 42 inch 17 hp lawn tractor. The problem is when I cut grass and i get in some thicker grass the blades turn off then I back out the blades restart. The engine never bogs down
May 30, 2011 | Troy Garden
I have a craftsman gt 5000 model 917.276220 runs fine but when mowing deck is engaged it wants to die when under a load or cutting tall grass, it will stay running but when i start to cut it bogs down?
not possitive, but sounds like 1 of the bearings on the mower deck is starting to seaze up.I would start with that. Remove the deck and belts and check all the pullys and bearings for free movement.
Mar 08, 2011 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
WHY IS CUT UN EVEN? MOWER LEAVES LINES IN LAWN
My 10 steps to ensure even cutting for any riding mower.
1. The rear tires must be the same diameter i.e. same tread type and the same amount of pressure
2. Level the deck following the instructions in the manual
3. Make sure the blades are not damaged or bent.
4. Make sure the deck nor its attachments are bent
5. keep the blades sharp and don't drive too fast when mowing.
6. Over lap rows about 20%
7. Cut the grass at intervals that ensures you never cut more than 1/3rd the total length of the grass.
9. Make sure the underside of the deck is free from chunks of clippings.
10. Use a blade with higher lift, yes you have to match the blades to the type of grass you cut most often, (commercial mowers use a universal blade and high speed decks).
Jun 18, 2010 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Metro walk behind bogging down
the springs that control carby is there leaves or grass stopping it from moving ,some lawn mowers have bad desinge for air flow off ****
Jun 02, 2010 | Encore EXMARK LAWN MOWER HEAVYDUTY STEEL...
Jun 30, 2009 | Ariens Garden
Bog when trying to mow
you are cutting to much grass & it isn't kicking it out fast enough out of deck which will bog it down it might help if you clean out the bottom of the deck & also dont cut really low if grass is really tall also cutting wet grass will aslo cause the bogging if i can further help e-mail me wade at wadembly@aol.com
Jun 26, 2009 | Garden
Mower bogs down in medium high gras
what is happening is there is tomuch grass in deck & not discharging as fast as it cuts it if deck is ajustable put it on high setting then try if it works then got back over it with a lower setting this is most likely the case to much grass in deck while mowing blade gets cought up alot with alot of grass in deck
Jun 05, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
66 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
