Question about Home
Looking for intake fitting for a pompeii whirlpool 72x54
  • 717 Answers
Can you email me photos of the fitting in your tub?
uspartscenter@gmail.com
I will find your suction cover.
US Parts Center
Posted on Nov 15, 2013
125 tw intake manifold, does other models fit bike
It is very common for a manufacture to us the same engine in many models. take a look at a Yamaha TTR 125 on line or on a parts breakdown. I would bet it has the same motor as your BW.
Jan 06, 2013 | 2001 Yamaha TW 125
1999 Alero : Fuel leaking at a fitting where fuel line goes under intake manifold. Does manifold have to be removed to remove or tighten this fitting?
IF FUEL LINE FITTING LEAKING UNDER INTAKE YOU HAVE TO REMOVE TOP INTAKE MANIFOLD TO REPLACE FUEL LINE FITTING O RING.
Sep 15, 2011 | 1999 Oldsmobile Alero
I am having trouble with my washer. It is showing the F28 error code and then when I get that fixed, it shows the F20 error code. Can you please tell me what to do to get it running again. Thanks
F20 I believe is low water flow. On the intake fitting on the back of the machine where the hot and cold hose hook up there is a fine screen inside the fitting on the machine. My cold water screen was clogged from stuff in old pipes. Cleaned it and no more e F20
Feb 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Saturn Sl rpm at 2000
Have a mechanic look at it for leaks between the intake manifold and the head. Have them run an OBD 2 scanner and check for cylanders misfiring. Probably a bad intake manifold gasket or other broken or cracked hoses/fittings connected to the intake.
Feb 27, 2010 | 2002 Saturn L-Series
2005 chevrolet z71 loosing coolant with no sign of leaks
Check the waterpump. You need to look from underneath for signs of leaking. Also check the radiator along the edges of both tanks. Lastly, check the aluminum coolant bypass fitting on the rear of the intake manifold as well as the intake itself in the very back. Th fittings always leak and usually break in half when you try to remove, then you have to drill it out and tap the threads on the intake.
Feb 07, 2010 | 2005 Chevrolet Silverado 1500 2WD
Whirlpool duet f28 code
Turn off the power. Remove the detergent tray. Reach in the slot where the detergent tray fits and look for a lever. Pull it and replace the detergent tray. Turn power on. Good luck.
Oct 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
1997 ford expedition 4x4 leaks coolent above transmission.
Check the connection at the left rear of the intake manifold. The thermostat is located in the front right, the connection to your heater core is in the left rear. The fitting is a pipe that is pressure fitted into the intake manifold. You should be able to check for a leak with a flashlght and an extended mirror. Look for a silver pipe about 1/2" in diameter. The leak will increase as you increase the RPMs.
Jun 05, 2009 | 1997 Ford Expedition
Need unlock codes for HP Games
What are unlokc codes?
If you mean CD keys, they should have been delivered with the game. If not, contact your supplier and demand one.
I hope this helps,
Yannick
Apr 14, 2009 | Video Game Consoles & Games
1998 lincoln towncar coolent leak
look at the brass tube fitting at the back of the intake that heater hose hooks to ,it will usually crack at the intake around that fitting. If so intake will have to be replaced.
Mar 03, 2009 | 1998 Lincoln Town Car
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
