Question about Maytag MGR5770 Gas Kitchen Range
My Maytag convection oven has the heating elements on the top. It doesn't matter if I use convection or not, metal, nonstick, or stone pans, or lower the temperature or cooking time, it doesn't cook/bake the middle of my food. I put items on the lower rack and the middle is still doughy when the outer food is done cooking/ baking. Any suggestions? Thank you!
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Stick a thermometer inside the oven. Compare the them inside the oven to the temp you see on the control panel; are they the same?
You must do this first. You will note a disrepancy. If the oven temp and yours do not match, that you have solved the problem.
Your oven sensor or thermostat might be at fault.
Posted on Oct 21, 2013
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
  • 198 Answers
SOURCE: Maytag cook top too hot!
Remove cooktop and check to see how much insulation is below the top, on top of the oven cavity, You may want to install some more insulation. The specs for this range probably allows this to happen. you should not put anything on the top after cooking in the oven, as glass breakage may occur.
Posted on Dec 04, 2008
garing
  • 998 Answers
SOURCE: lower element of top oven does not heat on Maytag Gemini
replace the control
Posted on Aug 06, 2009
SOURCE: My bake burner on my Maytag gas oven is weak,
Probably need to replace the igniter. Swap the broil and bake igniters and see if the problem follows the igniter. I just had this happen to mine. Glow bar/igniter appeared to be working properly but was weak causing the regulator valve circuit to keep the flames very low. Swapped ingiters as instructed and problem went with the bad igniter to the broil/top burner.
Posted on Sep 11, 2009
  • 969 Answers
SOURCE: I have a Maytag Gemini, top oven burns everything on the bottom
RAISE OVEN RACK SHELF, BOTTOM ELEMENT MAY NOT BE TURNING OFF, NEEDS REPLACEMENT
Posted on Nov 12, 2009
Maytag MIR8890AS0 6.2 cu.ft. induction range w/true convection. Takes an hour or more for oven to pre heat, doesn't maintain heat. 4 yrs old. Induction top OK.
I don't know, but it sounds like one of the heating elements are burnt out/no longer working. I had a similiar problem 5 years ago.. they're pretty easy to replace yourself if you are handy and have a screw driver. I think the one for my stove cost $18 to replace (5 years ago) here's the trouble shooting guide online for you model:
Maytag Range Stove Oven MIR8890AS0Troubleshooting Repair Help
Dec 07, 2016 | Maytag Kitchen Ranges
What kind of cookware is recommended for glass top stoves
Glass ones work best, but any heavy metal will also work. Heavy gauge not heavy weight. The lighter metal tends to bend and warp after a lot of use. If the bottom of the pans are not absolutely flat, these stoves will not heat the pan very well, which is why the glass cookware is the best to use, since it will not warp.
Feb 27, 2015 | Maytag 6.2 cu. ft. capacity electric range...
I need the manual of my haas microwave oven HMW 43 W I want to know can i bake in my oven or not
m/w do not bake they heat up water molecules in the items that you put in them . unless it is a m/w, convection oven that has a heating element and a convection fan in addition to m/w components in it usually a metal fan visible protruding from back of inside the cavity. also m/w , convection ovens are ether over the range or together with convection oven in the wall combos and cost quite a bit more then counter top. $250 +
Jan 22, 2015 | In Microwave Ovens
F23 err
Good Morning Edward - Typically error code E-21 indicates an issue with the preheat temperature not reaching within 30 minutes. This often occurs due to heat loss around the oven capacity. At this point, the convection heating element, convection heater thermal cutout, oven thermal sensor, and wiring connections may be faulty. Regrettably, this is not a simple DIY job. I would strongly recommend connecting with a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 09, 2013 | Electrolux ICON Designer E30SO75ESS Oven
Convection oven doesn't heat
Possible that the relay is faulty or there is fault on the control panel. It can also be related to problems on the thermocouple or sensors which can cut off prematurely the element.
Feb 11, 2013 | GE JES1290 Convection/Microwave Oven
I want to bake a salmon loaf in a glass loaf pan in my Jen Air mincrowave/convection oven. The 4 pg. instruction manual does not give me sufficient info. In fact, there's onloy a half page relating...
I have a Panasonic Convection Micro. Yes, If you are using convection you can use metal pans. Microwave energy cannot pass through metal pans so that is why it is not good to cook in them. It could also cause arcing or reflect the microwave energy bak to the mag and over heat it. So, when possible use corning ware or Pyrex when using the microwave
Aug 17, 2017 | Jenn-Air JMV8166B 950 Watts Convection /...
I have a panasonic inverter model no. NN-C784MF/WF. I want to bake cake in convection mode can i use metal tray like nonstick, alluminum etc can you please guide me.
There is no problem using metalic utensils in a microwave oven AS LONG AS IT IS ONLY ON CONVECTION as it is only a standard oven cavity in that mode.
I make cakes in my Panasonic Invertor and get excellent results as one can see what is going on!
Enjoy your cooking.
Nov 15, 2010 | Panasonic Computers & Internet
Wierd problem with ge eletric oven / no heat
check the electrial connection at the back of the range, also check the breaker
Mar 31, 2008 | GE JKP15 Electric Single Oven
Gaggenau oven won't heat on convection setting
this could be due to more than one cause selector switch faulty elements faulty. however this would mean both elements gone - there is one at the top and one at the bottom also worth while looking at the wiring to the convection elements. does the thermostat neon come on when convection is selected?
May 18, 2007 | Gaggenau EB294/295 Electric Double Oven
Maytag MGR5770 Gas Kitchen Range Logo
123 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
