Oasis washer machine model 110 27042603
Chronic out of balance problem during spin
  • 11 Answers
SOURCE: Kenmore Waher spin cycle out of balance
Sounds like your front to back spring is pulling to tight, sometimes you need to replace it and sometimes you can take it off and stretch it. hope this helps
Posted on May 20, 2007
SOURCE: Kenmore Oasis Washing machine makes noise during Spin cycle
with the machine empty see if you can lift up only the tub and see if it drops down.check to make sure there is nothing between the tub and outer tub have you gotten an f-51 error?
Posted on Nov 11, 2008
onthejob5130
  • 640 Answers
SOURCE: Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Posted on Feb 07, 2009
  • 240 Answers
SOURCE: washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Posted on Mar 14, 2009
BIKER T
  • 909 Answers
SOURCE: spin cycle is off balance washing machine is
i dont believe it is the agitator per say. Assuming this problem has just started and doesnt have transportation bolts still attatched. Two conditions cause the imballance. 1)(if unit is a top loader) Check if all 4 shock absorber springs are well lubricated and not sticking. 2)A more involved problem which often happens, Underneath the washer, is the drive motor. on the motor, is a round pulley. this pulley needs to come off and strip further until you see a long spring. If it is not broken, clean it up using a solvent and a rag. reassemble and test. (if spring is defective, it will slip instead of grip on a spin cycle.
Posted on Sep 17, 2009
Washer goes thru cycle ok untill spin cycle gets error code out of balance, but machine not out of balance
That is not to say that the drum is not out of balance. Try running it empty and see if it happens.
Aug 09, 2013 | Kenmore Elite Oasis 27052 Top Load Washer
Noisy when in spin cycle
This could be the drum baring and probably will need professional engineer to do it.
Jun 01, 2017 | Kenmore 24032\24036 Top Load Washer
Kenmore Oasis HE shakes violently during spin cycle
Machine legs should be adjusted so that machine is level and standing on all four legs. The load in the machine should be evenly distributed. Utube has an excellent video on washing machine repair.
Nov 20, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite top loader makes loud knocking sound when spinning
sometimes the agitator gets loose, causing the drum to sway to far all over the place.make sure its tight , remove the softener dispenser (manual nut), then tighten the metal nut that holds the agitator down
Jul 14, 2009 | Washing Machines
Kenmore Oasis top load always out of balance and bangs
First just to let you know, the oasis is very sensitive to the load level and water ratio if its too heavy the load has to be perfectly balanced inside the tub. Next check to see if any of the straps are broke. The next thing is that the newtator has tighted up all on its own so when it spins the newtator grabs the tub while it spins at high speed. I have never had to fix this but i know it is a common problem. I hope i helped a little. Good luck!
Jan 14, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Nov 11, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Loud Sound
bash11385,
Welcome,
You said, during the Spin Cycle it starts thudding very loud as if someone is pounding on it. What's wrong with it?
You must check tht the wheels are properly installed and lock nuts are tight.
Your washer load is more than likely out of balance or over loaded .
Try moving the clothes around so the weight is balanced .
And remember not to over load the washer with to many articles!
let me know how it goes.
Huuum Please remember to leave a rating.
Below is the Kenmore site for your washer manual if you do not have one!
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0512076.pdf
Oct 09, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
