Question about LG Cell Phones
Default password for karboon k34 - LG Cell Phones
Brian K34 range hood switch removal
What do you want to know?
Apr 02, 2016 | Kitchen Ranges
I forgot the pattern of locking and i tried too many pattern on my karbonn a2 mobile how to open thesame
my mobile andriod karbonn A2+
plz solution my problem show problem Too many pattern attempts
Username(email)
password
I have forget this
Mar 22, 2013 | Cell Phones
Karbonn mobile full reset codes
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 29, 2012 | Cell Phones
I dont know my karbonn k15 reset code
karbonn k 15 input phone password
Aug 19, 2012 | Lands Phones
I have a 2005 dodge magnum with check engine light on and i got a code that is P406 what does it mean and how do i fix it
EGR POSITION SENSOR CIRCUIT HIGH.
Possidle Causes:
(K34) EGR POSITION SENSOR SIGNAL CIRCUIT SHORTED TO (F857) 5-VOLT SUPPLY CIRCUIT.
(K34) EGR POSITION SENSOR SIGNAL CIRCUIT SHORTED TO BATTERY VOLTAGE.
(K34) EGR POSITION SENSOR SIGNAL CIRCUIT OPEN.
SENSOR GROUND CIRCUIT OPEN.
EGR SOLENOID ASSEMBLY.
PCM.
Sep 15, 2011 | 1998 Ford Taurus
2004 dodge 1500 4 x 4 the engin mlight came on and the code is p0404. What does P0404 stand for?
SYMPTOM
P0404-EGR POSITION SENSOR PERFORMANCE
WHEN MONITORED
Engine running.
SET CONDITION
The EGR flow or valve movement is not what is expected.
POSSIBLE CAUSES
- Good trip equal to zero
- Excessive resistance in (F856) 5-volt supply
- (K34) EGR sensor signal circuit shorted to ground
- EGR assembly
- (K35) EGR solenoid control circuit
- Intermittent condition
- (K34) EGR sensor signal circuit open
- (K900) sensor ground circuit open
- EGR assembly (ground)
- PCM
var classElements = new Array(); var node = document; var tag = 'a'; var els = node.getElementsByTagName(tag); var elsLen = els.length; var pattern = new RegExp("(^'\\s)specs_note(\\s'$)"); for (i = 0, j = 0; i
May 28, 2011 | 2004 Dodge Ram 1500
Mujhe adobe photoshop7.0 ka serial number chahia
S/N: QT0473FE-K34-FF07
or S/N: 104512001432010400002517
or 1045-1209-6738-4668-7696-2783
May 19, 2010 | Dell Optiplex Desktop Side Panel w/ Button...
Cell Phones Logo
50 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
