Question about Kenmore 63683 Stainless Steel 1200 Watts Microwave Oven
Fuse replacement Kenmore microwave - Kenmore 63683 Stainless Steel 1200 Watts Microwave Oven
  • 2,113 Answers
Unplug. Remove the top/side panel. The fuse will be obvious near the power cord it is a special non glass fuse used in microwaves. (i save many fuses from microwaves others placed at the curb so mine are always free)
Posted on Oct 21, 2013
Replace fuse Kenmore microwave 72163683300
Unplug remove cover the fuse is near the power cord replace with card-board type non-glass fuse as original.
Oct 20, 2013 | Kenmore 63683 Stainless Steel 1200 Watts...
Replace fuse Kenmore 40188523011
If you know that a fuse is open, you need to find out why it went out before replacing it. There are typically three fuses in any given microwave oven. Line or monitor fuse, cavity temp fuse and magnetron temp fuse.
Oct 07, 2013 | Sharp R-1750 Microwave Oven
Kenmore elite model #665.61683101, has no power, plug works but microwave has no display, is there a fuse in this model?
There is a line fuse for this oven. Remove the cabinet and the fuse should be close to the line cord. Replacement fuses should be found at your local appliance supply house.
Apr 19, 2011 | Kenmore 62622 Microwave Oven
Where is the fuse in my Kenmore Over the stove Microwave oven
The fuse is located under the keypad in towards the high voltage capacitor "silver rectangular in shape" before you take it apart "unplug and discharge capacitor" there are dangerous high voltages present, the fuse is a ceramic type and must be replaced with the identical size and rating. Now if the fuse blows again it is more than likely one of the door switches is defective.
Feb 09, 2011 | Kenmore 62702 Microwave Oven
Microwave turns on but doesn't cook
There is an inline fuse that is accessed by removing the outer casing. Follow the power line in to the magnatron and you should see the fuse. Make sure the fuse that you replace it with is the same as the one you removed. If this doesnt work then the magnatron has gone out.
Dave
Mar 31, 2010 | Kenmore 80012 Microwave Oven
Kenmore microwave model 721-63252301 - no heat turns on - but nothing is getting hot
we are going to try to find a fuse and replace that or just buy a new microwave
thank you
Jun 05, 2009 | Kenmore 63252 Microwave Oven
Kenmore microwave model 665.61629100
Usually, when your microwave oven doesn't work it all, the internal fuse (thermal fuse) is blown. This fuse protects both you and the oven. When it blows, you need to have a qualified appliance repair technician replace it.
Door switch If the fuse isn't the problem, check the door hooks and the door-release button. When these are broken, the door switch doesn't activate, so the oven can't work.
May 29, 2009 | Kenmore 63792 Microwave Oven
Microwave has stopped working after being run empty for a short time. Is there a fuse that needs to be replaced or is the microwave dead?
There is a fuse inside the oven. The rating of the fuse may be 8amps. It is not suggested to run the oven without load inside.
May 04, 2009 | Kenmore 63252 Microwave Oven
All lights went out and no buttons will work.
the protection circuit has operated, this is not uncommon on microwaves. the fuse is inside the unit and therefore require dismantling. replace fuse and all should be fine, if it blows again then you have a more serious problems
Feb 18, 2009 | Kenmore 80412 Microwave Oven
Kenmore 63683 Stainless Steel 1200 Watts Microwave Oven Logo
325 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
