Question about Intel Motherboard
I have a Toshiba satellite L655 - SW5096. went to turn it on but will not start. No fan, no screen. Only the power light indicator and a steady orange light . The orange light goes off if I remove the battery. The white light will go off if I unplug it. its almost like the on off switch is not working.
  • 28 Answers
The orange light shows the battery is charging. It will turn green when the battery is fully charged. The white light shows there is power entering the computer.
The usual problem with a computer when there is no response to pressing the power button is that the motherboard has failed requiring the replacement of the motherboard.
If the computer is still under warranty there should be a free motherboard replacement, if not, and you are able to do the replacement, you can find motherboards for sale on various websites. Be aware that motherboard replacement for laptops can be expensive if done by computer repair shops.
Posted on Oct 21, 2013
3 Suggested Answers
map9966
  • 2351 Answers
SOURCE: packard bell imedia 3034
After reading a ton of posts you may be correct, your board is dying or is dead.
An easy way to get your data off your old Hd to your new Hd would be to connect it directly into the new PC internally.
Just like you would a new drive only you would set the old drive as a slave. Here is your 3034 link.
http://support.packardbell.com/uk/item/index.php?pn=P842025601&g=1400
The motherboard in this 3034 is Gigabyte, GA-8SIML-NF7, shown at this link: http://support.packardbell.com/uk/item/index.php?i=spec_columbia5p&ppn=P842025601
There is almost no chance of you finding this board its just too old. There are boards at this link that will handel all of your imedia 3034 parts, motherboards.
http://computers.pricegrabber.com/motherboards/p/40/form_keyword=motherboards+478+socket/rd=1/mode=g_us_b_s/skd=1
Hope this helps you Jim!
Please vote...
Posted on Jan 19, 2008
SOURCE: Intel Motherboard Problem
Hello ezinash ,
replace ur hard disk with a new one and than try
Posted on Jul 21, 2008
Toshiba satellite l655
battery problem...same problem here...got fixed when i changed the battery
Sep 13, 2013 | Toshiba Satellite L305D-S5881 Notebook
Sound not working
You need to set the the Default audio device to the speakers in the Control panel and make sure the sound is not "muted" (turned off)
Feb 18, 2013 | iTEKIRO Laptop AC Power Adapter Notebook...
Toshiba Satellite L655 Not Switching on
You mentioned that it won't turn on with the charger (without the battery). Does this mean that it turns on if the battery is in?
If it turns on with the battery, then you need to replace your AC adapter.
Feb 13, 2013 | Computers & Internet
My L655 Satellite won't start up
Is it plugged in? Is it getting power? Can you be more spectfic?
Dec 17, 2012 | Toshiba Satellite L655S5058 Notebook PC
L655 Satellite won't start up.
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
Replacement Toshiba Satellite L655 AC Adapter 65Watt 19V 3.42A
Replacement Toshiba Satellite L655 AC Adapter 75Watt 19V 3.95A
Dec 17, 2012 | Toshiba Satellite Pro A210-EZ2202X...
LAPTOP SCREEN WILL NOT TURN ON TOSHIBA SATELLITE L655 MODEL # PSK2LU-02Y00D
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Sep 30, 2012 | Toshiba Satellite L655-S5101 Laptop
When i plug my charger in to my satalite L655 and turn it on. An orange light flashes.
Hello, stoneyless
The orange flashing you are referring to means that your battery is currently out of power. I would recommend trying a friends laptop charger (same brand and model) to rule out the charger, if you know the borrowed charger is in working condition and your pc still doesn't power on then you may blame the battery. From that point i would send it in Toshiba for a replacement battery AND charger (if still under warrenty). if warrenty is no longer viable you would have no choice but to find a suitable replacement for either the charger or battery. OR you can buy the same Laptop and take out the battery and laptop cable and return the laptop with the faulty equipment.
Feb 15, 2011 | Toshiba Satellite(R) L655-S5115 Laptop...
How do I replace the keyboard?
next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
Nov 22, 2007 | Toshiba Satellite A135 Notebook
Intel Motherboard Logo
56 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
