Question about Pentair Prowler 720 Pool Cleaner
I have a Prowler 720 pool cleaner. While the light comes on the device does not move, the fan on top is not spinning. I'm assuming that the drive motor is not working. Since the mechanism is basically two sealed parts is it just a function of replacing the motor? And if so, since the electric/wired connection is a water tight connection, is it reasonable to assume that a fairly capable home owner can do the replacement? If so is there also a way to determine with a meter which of the two components is not functioning.
The problem may be simpler than you think, Patrick. The robot's power cord must be plugged into the power supply port in a particular way. The male prongs on the robot's power cord are numbered, 1 through 4. Each of these male prongs must be plugged into the power supply port's corresponding number (e.g., 1 must be plugged into 1, 2 into 2, etc.). Do anything else and you get a motionless robot. I hope this helps.
Posted on Dec 13, 2013
PartsCenter
  • 125 Answers
SOURCE: Pool pump won't prime. Impeller replaced, worked
sounds like a priming problem. look at the check valve in front of the pump in the suction line. sounds as if it is loosing its prime so you don't have enough water close enough to the pump to get it primed.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: do i have the right size pump for my 10,000 +/- inground pool
Bruce,
the cartridge element system you have is designed to be used for at least two seasons before needing to replace the elements. You are correct thinking that the pressure going through the filter is causing the problems with the cleaner.
if you take the elements out of the filter and see if cleaner works that will show you whether or not it is time to change the filter elements. That filter is very expensive to replace. cheaper to just change the elements.
Posted on Mar 04, 2009
  • 990 Answers
SOURCE: Legend pool cleaner wheels not moving
You might want to pull the drive wheels and see if their might be a small pebel stuck in the drive gears on the wheel.
Posted on Oct 04, 2009
jharwell668
  • 640 Answers
SOURCE: My Pentair legend pool cleaner is not moving
On this automatic pool cleaner, this is usually an easy thing to fix. First, make sure that your filter bag is clean and free of obstructions. Next, take of your head float and shake it. If you can hear water inside, you will need to order a new head float and install it. They are usually inexpensive and easy to replace. Make sure the hose floats are evenly placed and make sure that the cleaner is not getting too much pressure from the return lines.
Posted on Jul 20, 2010
jharwell668
  • 640 Answers
SOURCE: Pentair Great White pool cleaner not walking
Make sure that your automatic pool cleaner is getting the proper pressure from the return lines to move the wheels. Also, make sure that the filter bag is clean and the the impellers are free. Both of these can restrict movements. You might also want to check your hose and make sure that there are not blockages/knots/etc.
Will the prowler 720 work in cold water
cold water yes but not frozen , caution if water is cold, it might get to below freeze point at nite , this will dammage pool pump and filter and possibly in ground pipes
(moving water will not freeze till 28 degree's)
Dec 06, 2014 | Pentair Prowler 720 Pool Cleaner
Why do the tracks not run on my prowler 720
ck the small rubber drive belt thats along the one side, i'll bet it's loose and slipping , happens due to water chemicals distressing rubber
Jun 09, 2014 | Pentair Prowler 720 Pool Cleaner
Prowler 720 power box will not stay on. I hit the green button and the light stays on for only a second before shutting off.
try running with out cord connected to unit in pool if still pops then shorted transformer in control box
Oct 11, 2013 | Pentair Prowler 720 Pool Cleaner
Troubleshooting
motor overheating replace
Jun 06, 2013 | Pentair Prowler 720 Pool Cleaner
My pantair 720 prowler is not working. I have tried just about everything. The green light comes on for about 3-5 seconds and shuts off the unit.
unplug part that goes into pool plug in if it does the same bad control box if it works without unit in pool bad cable or inpool unit
Feb 21, 2013 | Pentair Prowler 720 Pool Cleaner
Prowler 720 won't run
either bad cord or bad motor or both
Jul 14, 2010 | Pentair Prowler 720 Pool Cleaner
Pentair Prowler 720 Pool Cleaner Logo
278 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
